Question about Naxa Electronics NX-574 8 in. Portable Television
Code for NAXA LCD tv
I am trying to program my cable remote to control the volume and power of my naxa LCD tv and I can't seem to find them anywhere, any suggestions?
SOURCE: universal remote
call for a factory remote at1-800-736-6837
Posted on Nov 17, 2007
I'm trying to find a universal remote that will work my 13" naxa tv
Hi.
Unfortunately, naxa tv's aren't compatible with universal remotes, as they use a proprietary coding system for their tv's.
Your only hope is to contact Naxa's support department at support@naxa.com to ask about replacement remote.
This is directly from their website about the incompatibility with universal remotes.
I know you were hoping you could use a universal remote for your tv, but sadly that's not the case here.
I wish I could have given you better news, but it is the way they designed their sets, that's why universal's don't work.
I hope this helps you out in knowing what to do now, and have a good day.
May 25, 2011 | Naxa Electronics Nx-540 13 in. Portable TV
My remote doesn't seem to be working to my Naxa TV. I have put in new batteries. The TV comes on with the "green" light in front. But when I click remote "pOWER" nothing happens ??? Thanks
If you replaced the batteries and can turn on the TV manually, then the button is probably not making proper contact with the remote. Try opening up the remote and placing a small piece of tin foil where the power button is, close the remote up and it should work.
Aug 03, 2009 | Televison & Video
Naxa NX-511
Yes, you can. I was able to get my Dish Network remote to work with my Naxa 574 TV. Just follow the directions for the remote and you should be able to use it.
Dec 12, 2007 | Naxa Electronics NAXA NX-571 Television
Universal remote
Nov 01, 2007 | Naxa Electronics Naxa NX-572 7" TFT LCD...
NX-574
Check if u are not on A/V mode, return to RF/TV mode and try tuning again, also check your antenna connexion.
Jul 06, 2007 | Naxa Electronics Naxa NX-572 7" TFT LCD...
Owners Manual...Question pertaining to the programming of TV
You may have SAP turned on by default which will draw in the spanish audio channels of your common off air content. Or the preset might be set to all of the spanish channels. From what I have heard the programming of this device is hard and not user friendly. I would suggest calling the company and getting the service manual. I hope this helps, Thank you,
Jan 03, 2007 | Naxa Electronics Naxa NX-572 7" TFT LCD...
Universal remote code
need coads for naxa tv dvd combo for an rca remote
Jun 26, 2006 | Naxa Electronics NX-517 Television
Where is CATV/Antenna switch?
if its not in the antenna mode settings its automatic or not compadable check with the manufacturer to be sure.
Nov 29, 2005 | Naxa Electronics Naxa NX-572 7" TFT LCD...
Naxa Electronics NX-574 8 in. Portable Television Logo
60 people viewed this question
Top Naxa Electronics Televison & Video Experts
Joseph Gallucci
Are you a Naxa Electronics Televison and Video Expert? Answer questions, earn points and help others
