Question about Kitchen Ranges
Flashing bake and probe indication on GE JD968S
I had a boil over on this range. There was steam inside the electronic control panel. I disassembled the controls and dried out the panel with low pressure air. After reassembly and repowering the range, the probe and bake indicators flash alternately. I recall that when I initially installed the range, there were instructions on a decal with directions on how to clear this. Unfortunately, that decal was paper and was destroyed upon removal. There is nothing in the installation or use and care manual on how to clear this. Of course, GE is more than happy to send out a technician at $100 per hour to perform this simple step. How do I reset this?
  • Anonymous Dec 11, 2008
    Same problem I will try your instructions.
    thanks
    New Friend:
I found the Mini-manual inside the control panel area of the range. I followed the instructions for resetting the control. Instructions are shown below:
Glass touch models only- Lock Reference Command
When the control panel is accessed, the signals used by glass touch panel may be adversely affected. To compensate for this change in signals, the following procedure must be followed every time the control panel is accessed.
1. Make sure power to the range is turned off.
2. Completely close the range control panel and return range to it's normal installation.
3. Apply power to the range.
Accessing the the control panel area but not replacing the control.
4. Enter Special Functions area by pressing BAKE and BROIL keys at the same time for 3 seconds.
5. Reset the control by pressing the 9 and 0 or the HOUR DOWN and MINUTE DOWN keys for 3 seconds at the same time.
6. Approximately 20 seconds after the time is displayed, press the 1 and 5 or the TEMP UP and MINUTE UP keys. The control should briefly go blank, briefly display all segments, briefly display LOC REF, display all segments for 30 seconds, and then display LOC REF.
7. Acknowledge LOC REF command by pressing the 6 and 8 or the HOUR DOWN and MINUTE UP keys at the same time. the control should then display the time of day.
8. The oven should then be ready for normal operation.
9. Test the functionality of the glass control panel, especially the CLEAR/OFF and/or CANCEL key(s).
Steps 4 through 7 are appropriate if you have not opened the control panel area. I had to open mine to clean up moisture caused by a boil over.
Judging from the number of inquiries on this same issue, this is a common problem. GE is more than happy to schedule a service call for this issue, but not so happy to give the information over the phone. This is a fairly simple procedure for most people to accomplish.
The ERC on my range appears to be a fairly common unit. I hope this information helps.
Flashing bake and probe indication on GE JD968S - moz-screenshot.jpgmoz-screenshot-1.jpg
Posted on Sep 23, 2008
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Probe and bake is blinking onmy ge oven how do I stop it ?
I had the same problem today (my wife overflowed a pot of chicken stock last night, so there was liquid all over the cook-top, and some probably got down behind the control pannel). Based on the solution to a problem that seemed similar, though definitely not as exact as your description, I checked the probe connection (unscrewed the retaining nut, then unscrewed the two sheet metal screws holding the housing in place, then gave the probe connection a gentle tug to ensure that it was still properly connected). Finding nothing wrong, I replaced the housing and retaining nut, and the lights were no longer flashing.
Try this..
thanks for rating good luck
Feb 15, 2011 | GE Profile JS968SFSS Electric Kitchen...
Error code f31 flashing
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from www.searspartsdirect.com website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 03, 2009 | Kenmore 96422 / 96424 / 96429 Electric...
Our kenmore 790 built in oven keeps flashing an F30 code after we turn off the oven, or sometimes when the oven is on, it shuts off and then beeps the F30. I keep hearing it is the RTD probe, but where is...
Mar 06, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Microwave power lost to unit. unit is above the electric range. while using the range the micro shut itselt down. is there a reset button or a internal fuse that micht of opened. or could the steam from...
The hot steam could have caused the microwave oven's thermostat to open. Or it may have gotten into the controls.
You should always use the vent or hood fan when boiling on the stove top.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jun 17, 2008 | GE Microwave Ovens
Re.probe and bake
I had the same problem and pulled off the contorl panel and removed the ribbion looking thing. You might have to do this a few times and wiggle it a little. It took me about 4 trys to get it to stop. also you can lock the control panel and the beeping will stop...this was my temp fix until I figured out how to get the control panel off and what to do.
Oct 11, 2007 | GE Profile JTP56 Electric Double Oven
Range problem
the control bord may be bad or the receptical where the probe connects may be bad and grounding out agenst the body of the oven. I would remove the plug and make sure the wires are good and its not grounding out. If it checks out ok replacement of the control bord should solve the problem
Jul 19, 2007 | GE Profile JB968 Electric Kitchen Range
Probe light
Jan 01, 2007 | GE Profile JGS968SHSS Gas Kitchen Range
Kitchen Ranges Logo
1,506 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
