Question about LG LRE30451ST Electric Kitchen Range
Ornery Oven I hope you can help with a mystery my LG electric Range (Model LRE30451ST) is presenting. I recently replaced 1 of the control panels (which I don't think I really needed to do) and it is still doing the same thing, which is, the 2 of the 3 back burners (middle warmer burner is fine) the left and right burners come on, but the touch pad (no matter where I press-on it or around it) won't let me control the ^ arrow up or the down arrow to control the temperature. It is as if the touch pad (for temp. contorl) for both burners are not registering even though the on/off portion of the pad does work. Yesterday, to no avail I tried to get both to do more than just display the 2 dashes, but 2 days prior we got them both to come on with out any problem-this was during and soon after we had the convection oven on. I turned the oven on to see if there was any correlation between the two yesteday and I couldn't get either burner to arrow up or down. I'm not sure that it is an intermitent problem at best. This has been going on since I replaced the control panel, which I and the service tech should have realized that if it came on at all it must not be the control panel. Must be something with the touch pad portion of the burners. What are your thoughts? Is this a common defect in the wiring maybe? My unit was manufactured in 2006- can anything be done about this 'issue'?
  • 706 Answers
Hello mary Jenkins,
Here is a link to the service manual for your stove http://136.166.4.200/contents/Range/LRE30451/LRE30451_Service_Manual.pdf
page 49 and up discuss keypad operation an from the sound of things, yours need to be replaced...
When buying LG products, ALWAYS buy the extended warranty ! They had a great reputation but to be honest, from my experience... they aren't all that great.. Many component related issues and service requirements... Hope this provides some incite... Good Luck
Posted on Sep 22, 2008
HOW TO OPERATE LG STOVE
hi there just visit lg.com support. and there you can download the full user manual. hope this helps
Jan 05, 2012 | LG LRE30451ST Electric Kitchen Range
F-1 oven error keeps coming on. took ribbons out and cleaned them. still no luck.
Hi
Error code F1 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 29, 2011 | LG LRE30451ST Electric Kitchen Range
F-1 keeps coming up on the screen and I am unable to do anything with it. ???? help this all happened after I tried to change the clock?
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Nov 07, 2010 | LG LRE30451ST Electric Kitchen Range
My oven is not working properly Went to bake a cake and while preheating the oven an f 7 code came on and it will not heat up in bake or broil but the convection oven still works ]. How do I fix this
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 31, 2010 | LG LRE30451ST Electric Kitchen Range
My stove has anF-1 code, I was told i need a new control panel
You can find them through us!
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Mar 08, 2010 | LG LRE30451ST Electric Kitchen Range
LG Range LSB5611SS LHS element stays on
I have the same model and there is a recall on that model and others as well. The control panel will be changed for free. There is a site where you can check it out http://www.healthycanadians.gc.ca/recall-alert-rappel-avis/hc-sc/2012/15538r-eng.php then contact LG
Sep 01, 2009 | LG LRE30451ST Electric Kitchen Range
Warranty registration
Open the drawer under the oven door and you will find it on the left side.
Sep 02, 2008 | LG LRE30451ST Electric Kitchen Range
LG LRE30451SW range
The interior oven light in most ovens is a standard 40 watt appliance bulb. Often, to change the bulb, you first need to remove a shield or glass dome. If the bulb isn't burned out, the problem may be with the switch on the oven door frame. If the switch works poorly, intermittently, or not at all, you need to replace it.
Jul 19, 2008 | LG LRE30451ST Electric Kitchen Range
Lg range
wow....me too guys. The oven, one burner and the clock are out.
Oct 30, 2007 | LG LRE30451ST Electric Kitchen Range
LG LRE30451ST Electric Kitchen Range Logo
295 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
