Question about Tools & Hardware - Others
Fein Multimaster not oscillating
Hi Seanfin, Following on from a previous thread. I have a Multimaster that does not oscillate because one of the two arms in which the armature bearing rotates within are broken off. Any idea how you replace that part? Does it come through the whole vacated by the bearing once the circlip is removed and the bearing extracted? No warranty issues here and the local Fein agent has declined the repair . In for a penny in for a pound (i am in the UK). Nothing ventured, nothing gained. Can't resit a challenge.
Any inputs gratefully received.
Cheers
Kevin in London.
  • gtatters867 Dec 10, 2016
    Kev Could you explain the procedure you used to the head?
    Problem Solver:
  • 14 Answers
Hi yes if you remove the gearbox from the armature housing then strip the cutter shaft from the gearbox by the circlip and bearing then the fork will fall out.
Have a look at this web www.fein.de/fein-multimaster/au/en/download/index.html
and follow link to the diagram of your machine may be helpfull.
Thanks. Sean.
Posted on Oct 01, 2008
Fein multimaster
interference suppression capacitor or electric field .
Apr 19, 2014 | Fein FMM250Q Select Multimaster...
Replace the oscillating fork in a fein msxe 636
beware of the materials that are used are usually very soft witch used by Fein in his budget machine class.
puler
Only a dutch version but the same parts positions.
MSxe 636 II 50Hz 230V
Jan 05, 2014 | Fein Multimaster Rs - Msxe 636 - 2 Rs
FEIN FMM250 STOPPED WORKING
an broken connector wire , or powercable, an autostop activated carbonbrush? a broken field connector 1 of the 4 or an armature with a broken collector in the commutator circle. the electronic moduul to see in the last possibillity.
Sep 11, 2013 | Fein FMM250Q Select Multimaster...
FEIN FMM250 NOT WORKING
Check Cable Or Brushes. while tool is not plugged in to wall socket unscrew three 15T torque screws check cable with multimeter for open wires look at brushes pull out of holders.
Fein multimaster repair shops/centers????
Wow, I don't have a multimaster but I want one. I know they make two kinds. One that's 700.00 dollars and one that you can get at the hardware store. I'm beginning to think there might be a problem with the switches in this thing. Go to eReplacementParts.com and view the schematics to order a new switch.
Dec 19, 2011 | Fein FMM250Q Select Multimaster...
Fein multimaster 250Q quick release not working. Spring action worked at first when lever was fully pushed (180 degrees) the tool holder would not release and the spring action was gone. How doe I fix...
either your not holding the pin in the right place or your multimaster was used with the pin in the wrong place to begin with and the lever was forced down causing the holding mech. to wear out.
Oct 21, 2010 | Fein FMM250 Start Multimaster Oscillating...
Fein multimaster sanding attachment broken
Pretty sure things like that are considered expendable. Pat yourself on the back for getting so much sanding done and buy a new one.
Sep 26, 2009 | Fein Tools & Hardware - Others
Blades wear out quickly for the high price of the blades
Joa-liff@hotmail.com supply a range of adaptors to fit the fein Multimaster and Supercut machines that allow you to use both Bosch and Multimaster blades. hope this helps.
Mar 28, 2009 | Fein Supercut with Carpenter Kit - FSC -...
Not oscillating
Hope this helps!
Inside the gearbox there is what should be a 2 pronged fork you may only be able to see 1 of these the other may be broken, the fork goes each side of the armature bearing. If the fork isnt broke it may be the armature bearing that fits inside the fork.
Hope that helps. Sean
Jul 26, 2007 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Tools & Hardware - Others Logo
1,624 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
