Question about Kenmore 64982 Electric Dryer
No heat I have a kenmore elite dryer style 64982 that is not blowing any hot air. We checked the vents and cleaned out all the lint. Checked the heating element, thermal fuse, thermostat, and thermal cut off and they all seem fine. Also checked the breaker, it was fine. At one point we weren't sure what we did, but the dryer started to blow hot air. It lasted one load, and now it's blowing cold air again...any advise what to do next??? The drier is 5 years old. Thanks!
  • 750 Answers
Vpflueger,
I am not sure why.
But I will tell you that at only 5 years old you should repair it.
This is a fine machine!
Try our premium service and they will fix you up!
Posted on Sep 22, 2008
Dryer putting out hot air but clothes not drying
You have some blockage between lint trap and where the unit vents outside.
Dec 16, 2012 | Kenmore Dryer Sears Elite
It takes several cycles to dry clothers in my Kenmore elite He4 dryer, it feels like hot air is blowing but the clothes are not getting dry any suggestions?
werw
Sorry to read about your problem, I hope this helps you out.
Clean your dryer vents, and lint filters. You may need to clean vent from wall to outside. to test this.. unhook vent pipe from wall..and run dryer and see what happens. or you have a defective heat coil
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 28, 2010 | Kenmore Elite HE4 Electric Dryer
Dryer heats up but cloths stay damp
disconect dryer from electric outlet first before doing anything to it!!
check ur outside exhaust vent on the house, might be full of lint, if is ok then check the duct on the back of your dryer, might be full or lint, take an leaf blower an blow all the lint off the air duct, an also if you are handy, remove the 12 or 14 screws of the back of the dryer , take the back panel off, and on your left side u will see the air port where the hot air comes off the dryer take the aditional 4 screws an clean it
then put it back together
if you still have the problem then u have bad coils
what happens an air restriction will cause the dryer not to work properly, it will overheat an shut off. but am more sure u need coils specially if u never got em replace, maintance doesn't hurt at all......
good luck leave some feedback thanks!
Feb 02, 2010 | Kenmore 73952 Gas Dryer
Kenmore Elite Sensor Smart Gas Dryer - no hot air
unplug the dryer,if you haven't cleaned out the dryer check the thermal fuse located on top of the blower wheel housing,remove bottom panel,then remove lint filter,now remove the duct that the lint filter slides down into,now you'll be able to check the thermal fuse located on the top right side of the blower wheel housing,there's also a thermister there too,the fuse is the one on the left,part number 3392519 or 3390719,remove one of the wires and read it out with your meter.also while your in there vac out the inside of dryer,if you have a shop vac put it on blow and blow off all the lint that's built up on the motor and you can also blow the lint that's in the back of dryer forwards so you won't have to pull the drum,if you have a long run on the vent line from the wall to the outside blow it out with a leaf blower,if there is any blocks in the vent line,the duct or lint inside the dryer you could have a fire so this should be done every year,now if the fuse is good you gonna have to read out the ignitor,the sensor and the gas coils,if you have parcial heat it's definetly the gas coils,when they heat up they stop working when they're bad,if you need anything else let me know,so check the thermal fuse first,then the ignitor,sensor and coils,if they are good check to see if power is coming down to fuse and ignitor,you have a computer board on this dryer but most of the time it's the fuse and a dryer clean out
Dec 16, 2009 | Kenmore Elite HE4 Electric Dryer
Cloths not drying all the way
if you have heat and the clothes take to long to dry you need to clean out the dryer the lint duct and blow out the vent line,also go outside and make sure there isn't a cage or something acting like a lint catch stopping air from blowing out where the flapper is
Nov 02, 2009 | Kenmore Elite HE4 Electric Dryer
My Kenmore Elite HE3 Dryer is not drying. It does not seem to produce any heat. The dryer does start as usual, lint screen is clean. Help!
It may not be your heating element. Your dryer lint vent pipe out the back of the machine or maybe out the side may be plugged. You have to pull the machine out and clear that pipe or rebuild it out to a soffit vent or static vent if it is in the attic, or out through your crawl space. This will make a huge difference. If that hot air and moisture doesn't get out of the machine it just goes back into your clothes.
Good luck!!
Mar 16, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer heats for 10 minutes and turns off
Turn the dryer on, go out to the where the vent exits the house. Feel the air coming out, and it should blow very strong, and for the total diameter of the discharge. If it doesn't, the vent pipe is plugged, or the connection hose from wall to dryer is crimped/collapsed when pushed back to the wall.
Also make sure lint filter is clean, and the grill inside the dryer where hot air enters is clear.
Reply back your findings and I can help you more.
Jan 29, 2009 | Dryers
Kenmore Dyer blowing cold air
Try cleaning out the the vent tube. Sometimes lint gets caught up in there over time. Hope this helps.
Mar 12, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4-lots of heat, clothes not drying
Poor drying problems with dryers generally are attributed to clogged ducting. You have probably heard this before, but the first (and least expensive) fix for any dryer with long dry times is to check the air movement. As well know, dryers require good air flow to ensure proper drying. Now, when you said the air movement is strong, were you checking it at the air vent exhaust outside, or were you checking on the back of the dryer? An easy way to tell if there's a clog in the ducting, or a clog in the dryer is to run one load with the dryer vent disconnected from the back of the machine. Only run one load like this. Not a good idea to blow hot moist air into an enclosed area of your home over a period of time because it can cause mildew problems. If the dryer blows freely and your clothes dry faster, you know you need to check the ducting from where it connects to the wall to where it ends at the exhaust vent. Often it is not enough to just clean the lint trap and the outside vent. You need to check what's in between them as well. Mice and birds are notorious for building nests in dryer vents and clogging them up. Now...if the dryer is blowing poorly at the exhaust port on the back of the dryer, you will need to remove the door kick panel under the door and remove the vent duct housing to get to the blower fan. Make sure you unplug the dryer before attempting this. There are live voltages present even with the dryer turned off. Lint can get trapped in vent housing and restrict the movement of the fan, which, in turn, will cause poor air movement and longer dry times. Last of all, take a temperature reading at the exhaust port on the back of the dryer. A good temperature reading is roughly 140 degrees F. If the temperature is too low, you may have an operating thermostat or high limit thermostat malfunctioning. Check your vent ducting, first and let me know if you need further assistance. I hope this helps you.
Aug 04, 2007 | Kenmore Elite HE4 Electric Dryer
Kenmore 64982 Electric Dryer Logo
264 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
