Question about Eureka Atlantis 2591A Upright Steam Vacuum
Leaking when plugging in soap dispenser the liquid leaks out immediately over everything. The soap unit itself is not cracked or broken in any way.
Could be that the despensing tank has melted and deformed at the connection point. This is what happened to me when I put in really hot tap water. The heat allowed the connection (where the water/soap outlet is) to deform when using it. Now when I fill the tank and place it in the machine the water just leaks out all over the place with no control.
If you look at the bottom of your tank, where the water comes out, you may be able to see that the plastic is mis-shaped or deformed slightly. It probably doesn't take much for the seal to be broken.
TEA
Posted on Oct 20, 2008
My Hoover F7452900 uses up the detergent in about 30 seconds and doesn't use any water. What can I fix?
The water and the soap are supposed to mix as they are dispensed. Check for a leak or crack anywhere in the water line. Any crack would make the vacuum-operated delivery of water quit working!
Apr 23, 2017 | Hoover Vacuums
Leaks water or cleaner when setting upright
Turn the setting knob to the rinse cycle when not in use, and you have leftover cleaning solution. This is the standard setting when storing , it blocks the soap from dispensing.
Empty the water tank and rinse after each use, and store empty.
If still leaking check the lid on the soap dispenser, make sure the gasket is even before tightening down and or the gasket between the water tank and the body, make sure they seal , check if they are straight and flush where they connect..
Mar 17, 2014 | Bissell 8910 ProHeat Clear View Upright...
Soap not dispensing
It's losing pressure due to the leak. need to fix the leak first.
Dec 23, 2013 | Techtronic FH50240 - Hoover MaxExtract 77...
My soap is leaking out of my "bissel pro heat.2x". Is there a way I can fix it?
You have a build up of solution on the rubber gasket. Clean both parts where they screw into the container and also where the dispenser connects to the unit. If it still leaks, check for small tears ont he rubber gasket and replace as needed.
Aug 27, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
It isnt puting any liquid down
I have a Proheat 2X and had the same problem. I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying somethign else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 24, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Black water leaks from bottom of ProHeat 2x
Probably be a rubber seal leak or crack at the soap water dispenser pump.
If you can take it apart and it is the seal you should be able to reseal it with gasket seal from an auto parts store.
Jan 17, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Flip it not dispensing detergent
soap probably dried up and clogge the ports,always run clean warm water through the unit till the soap is cleaned out
Dec 02, 2008 | Bissell 52889 Flip-Ease All-in-One Vacuum...
Model F7441980 Hoover Dual Action Spin Scrub Wide Path
You will have to replace the tank, and it will come with the soap dispenser attached.
Mar 30, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Cleaning Solution leaks out around bottom
Most likely the opening under the seal has cracked or is starting to break away. You will have to replace the water bucket, the soap dispenser come with it, not separately.
Oct 20, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Will not dispense soap from handle
The soap dispenser, on the side, make sure the seal is on the bottom of it and not in the hole. You may have to replace the valve asm for the dispenser part # 2101795
Sep 30, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Eureka Atlantis 2591A Upright Steam Vacuum Logo
319 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
