Question about Microwave Ovens
How do i replace the light bulb in the kenwood sjss25 microwave.
  • Microwave Ovens Master
  • 9,086 Answers
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 27, 2008
How do I change the light bulb in a magic chef microwave?
  1. Unplug the Magic Chef microwave from the wall outlet.
  2. Remove the screw from the light cover located on the left side of the underside of the microwave. ...
  3. Unscrew the light bulb, then screw in the new light bulb.
  4. Raise the light cover, then secure the cover with the screw that was originally removed.
More items...
How to Replace a Magic Chef Microwave Light Bulb ' Hunker
https://www.hunker.com/13407988/how-to-replace-a-magic-chef-microwave-light-bulb How do change the light bulb in magic chef microwave Google Search
Oct 24, 2017 | Magic Chef Microwave Ovens
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
How do i change the light bulb on a Kenwood Ken GJ/SS25 microwave
The cover has to come off the microwave to access the bulb. There are several screws around the back and sides. Remove these and the cover should lift off, revealing the bulb. For your own safety, make sure that the microwave has been unplugged from the outlet for several hours before attempting this repair.
Mar 02, 2011 | Microwave Ovens
Kenwood microwave SJSS25 not working
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man. Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
Feb 09, 2010 | Microwave Ovens
Kenwood Microwave 564.8568511 Light Replacement
Ifthere's no obvious removable cover over the bulb (and the owner'smanual doesn't address it) some disassembly may be required.
You can usually find Kenmore exploded views and order parts by entering your model number (564.856511) at the Sears parts site.
Ifit's an over the range type, remove the vent grille across the top andsee if bulbs can be accessed there. There may be a panel on the bottomcovering the light(s), instead.
If not, chances areyou'll have to remove it from the wall, then remove the outer cover. Ifso, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph besides the link to the Sears site.
Thescrews you need to remove should be pretty obvious, but a specialdriver (such as a T20H type or GTXH20-100) may be needed.
Oct 14, 2008 | Microwave Ovens
Where does the light (lamp) in a Kenwood SJ SS 25 microwave go? I ordered a bulb but am unsure of how to put it in when it arrives. The booklet that came with the microwave says "don't do it...
I did not fix the problem. I ordered a bulb (lamp) and subsequently saw it is beyond my knowledge to install it. I'll communicate with the store where I bought it 3 months ago and if they won't deal with it, I'll pay a repairman to do it.
Aug 20, 2008 | Microwave Ovens
Microwave Ovens Logo
150 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
