I have a magtag neptune TL washer that stops after each spin cycle and gives a LL or LO on the timer screen. I can open the machaine and fix the clothes. Sometime this works snd then again it does not. I do this several times during the wash cycle. When it gets to 8 minutes left it will go no futher. I have been drying the clothes a little more damp than usual. I don't know if the machine is spinning up to it's normal speed or not. The washer is only about 3 years old.
  • Washing Mach... Master
  • 16,248 Answers
There is a service brochure inside the machine and you can access the info on the self tests by finding this brochure. It may be that one of the springs or balancers on the drum holder is bad, loose or broken.
Posted on Jun 09, 2017
Junoon007
  • 1011 Answers
SOURCE: Admiral Washing Machine (Model LNC6760B71)- clothes remain damp
Sir,
The motor on this washer turn one way to wash and the other way to spin and drain.
So if the washer is spinning and not draining you have a pump problem.Take the front panel off and watch to see what is happening.
You will have to check for power to the motor in spin. Either the motor is bad or the timer or both. Refer to the schematic for this.
Thanks
Good luck
Don't forget to rate the solution
Posted on Jul 25, 2008
SOURCE: Maytag neptune tl displays LL and stops during the rinse cycle
We just moved into a house with this washer. I have been noticing that things smell if you don't take them out of the washer immediately. I now read some reviews and understand the problems and most original owners had it fixed or replaced. We are out of luck. I was doing a wash last night and it's been stuck w/ 9 minutes left on code LL. I am not sure how to fix this as I don't have the manual. Any suggestions??? HELP!!! ~ KNA
Posted on Aug 14, 2009
FAV6800AWDIY
  • 526 Answers
SOURCE: Code LL flashing. Will not complete a cycle.
The LL error code is not documented very well.
Can you tell me what point of the Wash Cycle the Cycle Status LED is in when you error out with the LL error code?
I believe it will be in the Spin Cycle of the wash cycle.
You could try a Quick Spin test and see if the wash basket will spin up to 850 RPM with no laundry in the Wash Basket. See Page 14 of the Service Manual and see if the Wash Basket will spin up to 850 RPM.
You could also check the TDS for proper range of motion using the SM or this typed out process.
Tub Displacement Sensor Diagnostics check.
It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
If you fail this test it would be time to remove the machine front cover check if the TDS sensor has fallen of its mounting position between the Tub and the washer frame.
Posted on Jul 12, 2010
caroldon
  • 17130 Answers
SOURCE: my 4 year old roper washer leaves grease on clothes. On spin cycle the machine makes a screaching noise, and the clothes don't spin dry.
Possible that the belt is slipping and also there is some issue with the agitator as the gaps within seems to bring up the dirt or grease mix to the clothes.
So it is important to remove the panel and check the play on the belt, replace if the play is high and check if the agitator bearings are worn out. If so the agitator assembly must be taken out and checked.
Posted on Dec 09, 2011
SOURCE: maytag neptune tl washer spins during wash cycle
lid switch is bad
Posted on Feb 15, 2012
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
My Magtag Neptune TL 6800 started making a horrible squealing noise then smoke started coming out of the washer. What do you the problem may be?
You need to replace the belt needed to spin the drum. It sounds to me like you may have been overloading the drum, putting too much stress on the belt. Over time, it has begun to " burn rubber" as it spins, causing smoke, or worst case scenario, the motor that turns the belt is locking up as the drum spins causing friction on the belt.
Aug 17, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag Neptune TL washing machine, it runs almost all the way through they cycle but on the last spin cycle it stops and the digital display shows LO. Can you help me?
LO error code:
Locked: Lid has failed to unlock -
the machine has repeatedly tried to
unlock the lid. Push lid closed to
make sure nothing from the inside is
pressing against the lid, preventing
unlocking.
Is that the issue? Have the Lid locks failed to release and you can't open the Lid?
Or have the Lid Locks released so you can open the washer lid but the error code LO remains?
If you want to DIY I will help you.
Google this Neptune TL Washer FAV6800AWW
This is a DIY Appliance repair forum no cost and you can get the Service Manual from this site.
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues with the machine.
In that Sticky are other what I find to be common Service Repair notes for issues with the machine.
If you need help post in the Maytag/Magic Chef/Admiral/Jenn-Air forum with your issue and we will try to help. No cost to you for the support..........D*ick
Mar 03, 2011 | Maytag Neptune FAV6800AW Top Load Washer
The washer stops after starting the spin cycle
Google "Sticky: Neptune TL Washer FAV6800AWW"
You can get the Service Manual from that site 5 post down. At that post I discuss how to DIY the fix.
Feb 26, 2011 | Maytag Neptune FAV6800AW Top Load Washer
e. Press Hand Wash.
Jul 11, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Unbalanced load
your un-balance switch may be getting bad/loose,need part # AP4027385 by whirlpool
Sep 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Sorry chukenne,
Having not experienced this issue on my FAV6800AWW I missed this error code in the manual is that your machine type? Error code “LL” is documented in the troubleshooting part of the SM as Large Load detected. Does this happen with all wash load sizes? I would go into Service Mode and step thru and document Diag codes form page 17 of the SM and see if you find any recorded error conditions. I would be curious to see if error code block 16 indicates a fail condition. I'm thinking of a possible high motor torque condition detected that may have triggered the LL code just a WAG at this time. You may want to clear all error codes and start collecting from your next wash cycle but I would make a list of all codes before you clear them for reference of fail events of past wash cycles. I’m going to assume the LL code happened during a spin cycle. What caused you to drop the clutch out and re-lube/ Were you taking dc/UC errors in spin cycle? Rich
May 27, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Error dc,uc and bangs during spin
Vic
I have posted many times on this forum my fix, if you have basic mech. skill sets you could try my maintenance fix. There was no real out of pocket cost I had a can of WD-40. If you can’t tackle, direct the service tech to a possible troubleshooting solution. See my post of 12/15 at this link, it has worked for a few forum members.
http://www.fixya.com/support/t350953-code_dc_appears_trouble_draining
Also have te svr tech read my comment of 1/19 in my trying to understand why the machine gives dc/UC errors in spin cycle.
Found clutch on ebay for this machine; http://cgi.ebay.com/12002211-NEW-MAYTAG-Washer-Pulley-and-Clutch-ASSY_W0QQitemZ110334944433QQcmdZViewItem
There are supplier links at this site for parts,
Good luck.
Jan 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Problem Magtag TL
UC means the washer cannot spin. There's a bulletin out this.
The clutch is likely the cause of these error codes, preventing the unit from spinning freely. A new clutch was introduced in production in March 2005 to improve performance and should reduce these error codes.
1. Visual verification can be made of a malfunctioning clutch by observing the lifter operation in spin. The lifters will rotate up to one complete rotation just prior to the tub starting to spin counter clockwise. Should the lifters continue to rotate while the tub spins, examination of the clutch will be necessary.
2. Inspect the 14 wire plug in the control console for loose red\white- pink- blue\white from the P3 connector. Also inspect the wires and connection point on the Tub Displacement Sensor for corrosion. Measure from PK to Wh/Bu at the P3 connector. The voltage should be approximately 1.5vdc when the tub is centered, 3vdc when the tub is pushed to the right rear of
the cabinet and 0vdc to the left front. Any variances of these voltages, the 14 pin harness connection, tub displacement sensor, and sensor connector should be checked.
Jan 05, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
