Question about Uniden TRUNKTRACKER III
Bearcat bct 15
Hi, I am getting a lot of noise on my scanner in our car while driving nothing comes in clear, also does your company in put the scanners codes, if so how much would it cost?? Thanks Jeff
Left bolb try it
Posted on Oct 07, 2008
Hi. how can i delete all my channels and then put in new channels
You can clear all the stored information by resetting the scanner. While holding the 2, 9, and Hold, turn the scanner on. In about three seconds the display will show "CLEAr".
If you need a manual you may download a copy here.
Aug 04, 2012 | Uniden Bearcat BC92XLT Handheld Radio...
Uniden bearcat scanner BC148XLT-1 Can't program it because it is locked out
Try manually unlocking each channel by selecting it and then pressing the LOCKOUT key. That will normally clear the channel for programming. If that doesn't fix the problem, power the scanner OFF, then press and hold the MANUAL, 2, and 9 keys while powering the unit ON. That should restore the scanner to its original factory settings.
Need the manual for your scanner? You can download and print it, at no cost, here:
http://www.radiopics.com/1.%20Manuals/Bearcat/Bearcat%20BC148XLT%20%28Manual%29.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
Aug 11, 2010 | Radio Communications
Alot of static very little talking
Check you antenna on the scanner. You are describing loss of signal to the scanner. It could be the antenna, the antenna connector, the scanner its self.
Check everything over, Try a better antenna.
Aug 02, 2009 | Radio Communications
UNIDEN BEARCAT BCT 15
go to menu -hit yes look for new channel and add freq email me a ghe518@yahoo.com
Jan 17, 2008 | Office Equipment & Supplies
Editing a Frequency:
[MENU] �� Program System �� F
�� Select a conventional system �� F
�� Edit Group �� F
�� Select a channel group �� F
�� Edit Channel �� F
�� Select the channel �� F
�� Edit Frequency �� F
Use the [0] to [9] and [.No] keys to enter or modify a frequency. When you press
the first place key, the cursor automatically moves one character to the right. You
can also ��, clockwise or counter-clockwise to highlight any digit.
If this does not help, and you need the owners manual, here is a link to the pdf format manual on Uniden:
http://www.uniden.com/index/manuals_results.cfm?cat=3
Jan 09, 2008 | Uniden TRUNKTRACKER III
Setting up my Uniden BearTracker BCT 8 Scanner
Here is a link to the owners manual:
http://www.rigpix.com/bearcat/bct8_manual.pdf
Here is a link to programming software:
http://www.scannermaster.com/ARC8_Software_CD_p/01-520850.htm
Link to programming cable if your PC has a DB-9 serial port:
http://www.scannerworld.com/content/product/model/780CABLE
If I find any frequency databases for your area I will post them as information becomes available. For one on one programming help I would recommend fixya Live Chat.
Jan 04, 2008 | Office Equipment & Supplies
Uniden # bc145xl scanner
How do I program my Uniden Bearcat BC 145xl? I lost the booklet.....
Oct 29, 2007 | Radio Communications
LS2208 barcode problem on Citrix
You you using USB versions of the device?
What device is hosting Citrix? (Maybe I should rephrase ... what computer is the LS2208 connected to and does it hold a citrix client)
Be advised that Citrix hosted on specialty devices like table pcs are finicky about the keyboard data timing (a synchronous operation)
Possibility #2 is power sag. When that scanner comes on it requires a lot of current, and often USB power (.5 amp max) isn't enough.
If you have a 15 foot USB cable on the scanner try a 6' striaght cable instead of one of the external power supply cables which provides a power pack and more power.
Nov 21, 2006 | Symbol LS2208 Handheld
145 people viewed this question
Top Uniden Office Equipment & Supplies Experts
danielle yancer
danielle yancer
Lawrence Oravetz
Are you an Uniden Office Equipment and Supply Expert? Answer questions, earn points and help others
