Question about GE Spacemaker JVM1640SJ Microwave Oven
Panasonic Microwave Problem
What ever setting l have on my combi microwave it cuts off after 21 seconds! microwave shuts off a few seconds after starting,it is only 2 years old and cost alot what could be wrong with it?
  • clarky84 Sep 23, 2008
    panasonic inverter microwave. shuts off after three seconds
  • GE Master
  • 9,086 Answers
Even though these are different symptoms, the same part may be causing both.
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Posted on Sep 27, 2008
  • Mario Monfette Nov 15, 2011
    Very fast and useful answer, Thanks
Panasonic microwave combi oven model nn a772 sbbpq. I set the microwave for 12 minutes but forgot to put the meal in. It now works for a few seconds then stops. Any help would be appreciated
A thermal cutout on many ovens is black with two terminals. It's usually held in place by a bracket and one or two screws. Many ovens now use a thermistor instead of a cutout on the magnetron.
Based on the symptoms you describe, it seems unlikely either would be the cause of the problem. If a microwave is run empty, the magnetron will draw excessive current. The excessive current can take out the magnetron, high voltage rectifier, high voltage capacitor, fuse, or a few other components. If this is an inverter oven, check for a fault code of "H98" or something similar. That would indicate a problem with the inverter board, or something else in the high voltage circuit.
Feb 09, 2017 | Panasonic Microwave Ovens
Panasonic genius1300w cuts off after 3 seconds
see this causes and fix it. God bless you
Door Switch If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently.
Main Control Board If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpa
High Voltage Transformer If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermoprotector If the microwave runs for a few seconds and stops the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Thermostat If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostats.
Oct 09, 2012 | Panasonic TK-929SA Stainless Steel...
Panasonic microwave began arcing and now shuts off after a few seconds
Your wave guide cover and magnitron need to be replaced.
Apr 10, 2012 | Panasonic Microwave Ovens
Panasonic NN-T994SF Microwave Oven quits after 15 seconds
my microwave shuts off after a few seconds. is there a fuse that needs replacing?
Feb 01, 2010 | Panasonic NN-T994SF Microwave Oven
My GE microwave will only run for 21 seconds and then it shuts off. Even if I try to heat something by running it for 21 seconds multiple times, it doesn't get anything warm.
I've heard of this is Panasonic microwaves but not in GEs.
To allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, as well your symptoms "only run for 21 seconds and then it shuts off".
For those readers with a a Panasonic that stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In Canada, you can find an authorized Panasonic servicer here.
Nov 27, 2009 | GE Profile 1.5 Cu. Ft. Mid-Size Microwave...
Kenmore Elite microwave Combi funtion not working
Unplug the unit for 1 minute to clear the ECU.
re-plug, and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 29, 2009 | Kenmore 62622 Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
Panasonic NN-CS596S Convection Combi Steam Oven
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If you do indeed have a problem, Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 16, 2008 | Panasonic NN-SN657S Microwave Oven
In most cases, this is a problem with the inverter or a bad magnetron.
You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Oct 24, 2007 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
368 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
