Question about Whirlpool LER4634J Electric Dryer
Electric dryer shutting off
The dryer shuts off after getting hot, then after it cools down it will start back up when start button is pushed, but only runs for about a minute untl it shuts off again
  • 5 more comments
  • rss3081 Sep 22, 2008
    I tried this but the dryer continues to do the same thing
  • rss3081 Sep 27, 2008
    I cleaned what lint there was out of the dryer by tarting the dryer and allowing the list to blow out the back. Then I cleaned out the hose from the dryer to the outside of my home. The dryer continued to to shut off after heating up.
  • Anonymous Sep 29, 2008
    I'm having the same prolem.
  • amyandcliff Nov 20, 2008
    my dryer shuts off after 10min too open dryer door and it is very hot the dryer is overheating.im going to take dryer apart it probably is stoped up and not getting proper ventalation so the thermo switch shuts it off for saftey reasons . if it still does it after i clean it out any other suggestions. I'm thinking the therm cut off could be bad. What is the best place to buy dryer paarts online Thank you for you time
  • Anonymous Feb 06, 2009
    i have the same problem
  • Anonymous Apr 18, 2009
    Did all that. Still have the problem. Even took the back off, cleaned the fan housing, which wasn't that dirty, cleaned lint filter chute, exhaust hose all the way through. Is there some kind of thermostat that might be causing the overheating? Shuts off after a few minutes, really hot and sounds like it has tennis shoes in it while it's running.
  • slaughter700 Apr 26, 2009
    My Electric dryer runs and then shuts off after it heats up. i have to wait till it cools down. before it will run again. Is it maybe the heating element and are they costly to fix. My husband thinks it may be the lint . I think it is the heating element. Any suggestions
    Scholar:
  • 32 Answers
It sounds like a thermal breaker is engaging and then automatically resetting once it cools off. I'm guessing that if you were to feel the dryer when it was running, it is really hot.
The most likely problem is that the exhaust vent for the dryer is plugged up with lint either within the dryer itself or in the part that is in your wall and exits someplace outside (could be as far as the roof). When the hot air can't escape the dryer overheats and shuts off to prevent a fire.
You might have to take apart the dryer to get at the blockage if it is there but try this first. Unplug the dryer. Make sure that it is cool. Pull it away from the wall. Disconnect the vent hose in the back. Stick your hand in the opening and start pulling out lint. Once you get everything out you can, plug the dryer back in - leaving the hose off - and turn it on. A bunch of lint will blow out. Let the dryer run and see if it shuts off. If not, then you know there is no problem with your dryer.
The next step is to clean out your vent lines. Depending on where they run and how long the run is, this could be a difficult.
When you are all done, connect it all back up.
Posted on Sep 22, 2008
  • AndrewWro Sep 23, 2008
    Looks like you must have received both suggestions at the same time. Otherwise, I don't see how you could have marked one as inappropriate.
    You state that you have "tried this" but what exactly did you do? Provide some more information and you may still receive some help.
  • 550 Answers
Most likely cause is the air duct is blocked with lint, some always gets past the screen and builts up in the exhaoust line. not enough air flow, the air gets hotter than normal and trips the over temperature cutout.
for most dryers
clear the fan, and exhaust ducting all the way to the wall, and the outside vent hood, of lint
  • AlmostBob
    AlmostBob Sep 27, 2008
    you may have 'tried this' but obiously you did not complete 'this'
    there is no other cause for overheat and shut down that is resettable on cool down, any other cause the unit will not work until components are replaced
    do 'this' again, properly
    from the drum to the wall, clear all lint from fan housing and impeller
    ducting
    wall exhaust hood
  • AlmostBob
    not suffient, yet, but getting closer
    if there was lint in the outer end of the duct of the dryer, there is lint in the fan housing and impeller, the fan is close tolerance, lint will build up in it and block it
    the fan is blocked
    open the case
    open the fan housing
    clean the fan housing and impeller
    or you can NOt clean out the lint and the dryer looks like this
LG DLE5977s electric dryer drum not turning when warm
Could be one of the "overheat thermostat switches" has failed, or is failing.
Could also be a big buildup of lint inside the machine (where you cannot see it) causing the switches to trip.
In the back or the bottom of the machine are from 3 to 7 "overheat thermostat switches" that are put there to prevent fire.
When the get hot, if they are bad, they will shut off the dryer until they cool off.
Kinda sounds like one is "trippin' ". If you choose to fix it yourself, you'll need a good electrical test instrument and several tools to take it all apart.
A question to "fixya" might get someone to tell you how step-by-step.
Be blessed.
Mar 27, 2013 | LG DLE5977 Stainless Steel Electric Dryer
Shutting off won't start when hot
The windings in the motor are bad and the motor will need to be replaced. Here is the motor to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 17, 2012 | LG Home Applaince LG DLE0442W 7.3 Cu. Ft....
Electric dryer, runs for about 20 min then shuts down, can restart after a period of time, then runs about 20 min and shuts down
you have a bad motor,most likely you don't clean out the dryer,this is the number 1 killer of dryers.the vent line,the duct that the lint filter slides into and the cabinet where the motor is needs to be cleaned out if it's gas once a year,electric once every two years.all a dryer does is move air,when lint starts to build up the dryer starts to run hotter then normal from the lint build up and the dryer can't move the air as easy as when everything is cleaned out and then parts start to brake like the thermal fuse will pop from running to hot or the motor starts to over heat like yours and shuts down.when the motor gets hot the oil that's inside it leaks out,you'll see it stuck to the side wall and on the rear end of the drum with lint stuck to it.there's an overload in the motor that pops when the motor gets hot and after a while when it cools down the overload resets,that's why you can start it again after a while so basicly you have to replace the motor and clean out the dryer,if the vent line is a long run,remove it from the back of the dryer and with a leaf blower blow it out,you'll see all kinds of stuff blow out through the outside duct and clean out the duct that the lint filter goes into and the cabinet where the motor is or replace the dryer.
Apr 08, 2011 | Kenmore 62602 Electric Dryer
Hi, I think I need a new motor. When I push on the start switch, I hear a hum, but the motor doesn't start up. However, sometimes it does start. However, sometimes after running for a few minutes, it...
something could be lodged in the blower wheel, or otherwise jammed up the unit, ie; rollers, idler wheel.
either way something has caused your motor to work harder than it was designed to, or it has just gone bad.
there is a thermal switch within the motor to shut it off if it gets to hot. that is likely the reason it shuts off after a little while and when it cools down will restart.
there is also the chance that your push to start button has gone bad, but highly unlikely.
either way it will require tearing down to find the problem.
best of luck, have fun
Aug 03, 2010 | Amana NED7200TW Electric Dryer
Electric dryer keeps stopping
Most likely, the operating thermostat has failed, and the high limit thermostat turns off the dryer when it gets too hot. When it cools down, it will start again.
Apr 06, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer shuts off when it gets hot but restarts
1.Remove your exhaust duck on the back of the dryer and clean it.
2.Make sure your exhaust going to the outside vent isn,t clog.
3.Check thermostat.
Mar 07, 2010 | Dryers
Dryer shuts off after 15 minutes and needs to cool down then will start again and the cylec continues!!On, off,on, off.
The problem is more likely a high temp limit switch. I don't have a schematic of your dryer, but one should be included somewhere on the dryer. You have to use a voltmeter to test the components in the circuit. The thermostat controls the heat temp, you may want to start there
May 07, 2009 | GE DVL223EBWW Electric Dryer
Kenmore Dryer 90 Series will start but suddenly stop...
Hello , Sounds like your motor is over heating , it will run until the sensor shuts it down from getting to hot , it is most likley because the motor is covered in lint and needs cleaned. Hope that helps.
Dec 30, 2008 | Dryers
My electric dryer will start and just shut off after about 10 min
sounds as if hte motor is overheating, whe nit cools down for a while it restarts, gonna need a new motor eventually
Nov 30, 2008 | Dryers
Whirlpool LER4634J Electric Dryer Logo
2,433 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
