Question about HP Photosmart C6100 All-In-One Printer
HP Photosmart 3210 All-in-One Printer Problem
Would like to get rid ot the Fax_CDA error. This printer doesn't have Fax on it.
Paul Quinney: prqui555@gmail.,com
  • prqui Sep 22, 2008
    need a specific solution
  • prqui Sep 23, 2008
    Sorry, this solution did not get rid of the Fax_CDA message I still get on my computer. I deleted my hp3210 all-in-one printer and restalled it, but the@#$ Fax_CDA came back as usual. I can get rid of each time it comes up with the CTRL-ALT-DEL through Task Manager, but I have to do this time I turn the Computer/Printer on.
    prqui
    Brigadier General:
  • 6,966 Answers
Pls try:
  • run in Safe Mode (hit F8 before Windows boot);
  • click on Start, "Run";
  • alternately, Windows key + "r";
  • in the Run box, type "regedit", click "OK";
  • in the Registry Editor, verify that "My Computer" is highlighted;
  • click on Edit tab, Find or hit Ctrl + F;
  • in the Find box, type "Fax_CDA";
  • delete the entry/reference of Fax_CDA;
  • press on F3 to Find Next, repeat delete of entry/reference of Fax_CDA until pop up Windows says "Finished...."
  • click on "OK", close Registry Editor, restart Windows/reboot.
Pls follow exactly. Any deviation and it is possible to mess up the registry.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 25, 2008
    Sergeant:
    Champion:
  • 435 Answers
Just reinstalling the HP software should work.
cheers,
Posted on Sep 22, 2008
  • 1,800 Answers
Try to uninstall and reinstall the drivers of ur printer and sure its solved 100%
plz do rate this post
    Genius:
  • 3,422 Answers
Did you use the registry cleaner in jv16PowerTools and delete registry entries?
If so, jv16PowerTools makes backups if you tell it to, you may want to introduce these backups into the registry.
Also, go to Add/Remove programs and see if there is a repair option for the Photosmart C-3180 All-in-One Printer.
  • 4,472 Answers
Is the error on the printer itself or on the computer? How long have you been getting this error and how old is the printer? Once I have more information I can assist you further.
Thanks,
Lee
  • 1 more comment
  • Lee A.
    Lee A. Sep 22, 2008
    http://h10025.www1.hp.com/ewfrf/wc/softw...
    Follow this link and select your operating system to download the latest drivers. Uninstall the software/drivers for the printer and reinstall them. This should solve the problem. If you still need any assistance let me know. If you find this helpful please take a moment to accept and rate the solution accordingly.
    Thanks,
    Lee
  • Lee A.
    Lee A. Sep 22, 2008
    Have you read and tried my solution if you need be to give you the steps in further detail let me know. I believe the last expert was doing nothing more then copy and pasting and I am more then confident with a little troubleshooting we can get this issue resolved.
    Thanks,
    Lee
  • Lee A.
    Lee A. Sep 22, 2008
    if you need me* was what that was suppose to say.
HP 3210: Fehler Oxc 18a0001
The only way to fix Oxc18a errors is to reset the printer. You can find the instructions on www.inkbank.com.au website here:
HP ink system failure error HP maintenance error what to do if HP printer...
Jan 01, 2015 | HP Photosmart 3210 Printer
My HP photosmart 3210 skips lines on the black ink only. The other colors print fine.
(The obvious) Replace the black cartridge. Even if ot says you have ink you could have a faulty cartridge, even if it has worked fine in the past. (The not so obvious) Clean your printheads/nozzles. Repeat the process a few times.
Apr 27, 2011 | HP Photosmart 3210 Printer
Problem with all in one not doing the fax, scanner or downloading
Hi Jan,
I would like to know the answers for the below question. Please reply back.
What is the error that you get while scan?
how is the printer fax part is connected?
Are you able to print from computer?
What is the operating system of your computer?
Regards
Riztech
Jun 04, 2010 | HP Photosmart 3210 Printer
Ink system failure error: 0xc18a0007
Look for your specific error. Click the link for reset if your error is not found:
HP Photosmart 3210 Ink System Error
Failing this, your 3210 may require repair service.
I hope you found this document helpful.
Dec 28, 2009 | HP Photosmart 3210 Printer
I have a Hp photoshop 3210 printer ink cartrage error empty or
I installed new cartriges, but my printer keeps giving me an error msg, Ink system has failed. Unable to copy, receive faxes, or print. Refer to printer documentation. Error: Oxc18a0206. What do I do now?
Nov 06, 2009 | HP Photosmart 3210 Printer
My HP Photosmart 3210 won't print
Try this:
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "OK".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
Oct 07, 2009 | HP Photosmart 3210 Printer
Photosmart 3210 - A Printer alignment failed error
Mine has done the same thing.
To fix this you have to reinstall the software, then reboot your computer.
I did that, and the printer alignment function worked fine for a while, then I started getting the same problem again, possibly after I had installed other software not related to the printer -- I don't really know.
In any event, it's doing the same thing again, so I just "cancel" the alignment and continue to use the printer. My prints are fine.
Jul 20, 2009 | HP Photosmart 3210 Printer
Error 0xc18a0207
turn the printer off while pressing the following key (it perform a cold reset )
cancle+ok+color+black for 3210
then swich it on
do it twice the your printer is alive .
Aug 18, 2008 | HP Photosmart 3210 Printer
Error message
If you are getting inksystem failure along with Error 0xc18a0106 then contact HP support, if you are not getting ink system failure along with Error 0xc18a0106 then power cycle the printer and then reset, this will resolve the issue.
Jul 03, 2007 | HP Photosmart 3210 Printer
HP Photosmart C6100 All-In-One Printer Logo
73 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
