Question about Hitachi Televison & Video
Hitachi 6IUDX10B rear projection TV I have a blue line curving down from the top of the screen and the rest of the blue in the lower picture appears shadowed underneath the other colors of the picture
  • mytvbroke Sep 24, 2008
    This certainly appears to be the problem and the fix even for a non electronics type guy looks less laborious than carrying the set out of my basement.
    This is the second time this has happened and I think probably when I had it fixed last time only one STK chip was replaced
  • 4,234 Answers
THis is a convergence problem that can be either poor solder connections on the convergence ICs or defective ICs. If you can solder, try resoldering the pins first. If that fails to resolve the problem, replace the ICs. These ICs are large, black and attached to a heatsink. THey should be marked STK392-110.
Keep us posted.
Dan
Posted on Sep 22, 2008
Color is fine but in top right corner have blue and yellow distortion but the rest of the screen picture is ok
The tv have a problems known as a convergence problems,it dead.Any colors lines R,G,B mis alignment anywhere in the picture screen.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced on the tv convergence board to solved the tv picture convergence problems.
Oct 09, 2010 | Hitachi 60DX10B 60" Rear Projection...
Mitsubishi WT-42413 Blue Green and Red Line
there is a section in the tv working just to keep the screen fitting top to down (vertical section) some capacitors are dry now in that area. this one has not to be a expensive job in the workshop. Try estimates
Apr 14, 2009 | Mitsubishi WT-42413 42" Rear Projection...
Blurry picture and 3 lines on tv curving down
what colors appear on those lines...
you need to take it to a rep shop your convergence outputs are bad...where are you located at?..are you access on yahoo messenger...I can direct you to your problem you can fix it yourself I will show you how pin point on web cam..step by step...email me my email addr is jpactech@yahoo.com
Jan 11, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Blue lines appeared near lower half of screen
Hello... This sounds like a convergence issue, but I didn't think they made rear-projection TVs as recently as 2013? Also, your post says you have a 32"? If it's a 32", then ignore the following.
If it is a convergence issue, parts will need to be replaced. There are usually two STK ICs and maybe some resistors that can go bad.
I hope this helps!
Nov 24, 2017 | Panasonic CT-32HX41 32" TV
Screen has 3 lines at the top
you need to get a conversion done to correct this problem
Oct 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Samsung rear projection 42" green curves causing distortion just started
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Dec 02, 2007 | Hitachi 50UX57B 50" Rear Projection...
Screen is curved inward on all 4 sides and there is a red, and a blue line that is curved at the top of the screen
This is a convergence problem.. possible deflection problem... you might need a tech to look at it...
Nov 19, 2007 | RCA HD56W66 56" HDTV
Blue and yellow curb on top of my 43" hitachi
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
Oct 14, 2007 | Hitachi 43FWX20B 43" Rear Projection...
Televison & Video Logo
16 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
