Question about Cell Phones
Scandisk miro sdhc works in phone, but not in card reader for windows xp
  • 4,472 Answers
Are you sure that your card reader can handle that type of card? Have you tried a different card reader? It is quite possibly the card reader or an incompatibility. What is the make/model of the card reader? Once I have more information I can assist you further.
Thanks,
Lee
Posted on Sep 22, 2008
  • Lee A.
    Lee A. Sep 22, 2008
    You need an SDHC capable card reader. The old ones won’t read cards
    above 2GB. The SDHC card readers can read the older types though. So you may want to upgrade.
    Thanks,
    Lee
  • Lee A.
    Lee A. Sep 22, 2008
    This should be the solution your looking for and if so and you have a moment I would greatly appreciate if you could accept and rate my solution accordingly. If you still need assistance let me know.
    Thanks and enjoy,
    Lee
How can I get the card reader to recognize sdhc cards
It's not your card reader, the SDHC mini firmware is dead that's why your reader cannot detect it. Warranty, return it to SanDisk for a new one. Every hardware you plug or attach to a PC or Laptop has what is called a firmware, a mini program that communicates with your PC and Laptop that's how they syst
Dec 30, 2012 | Gateway GT5082 PC Desktop
Toshiba type "A" sd card
I beleive the memory that it can read is only limited by the software you are running such as windows XP sp1 and 2 can recognize upto 2gb SD cards but keep in mind that SD cards only go to 2gb anything bigger than that are SDHC and are the same size but designed differently so the reader must be able to read SDHC format. Note if your hardware is capable of reading SDHC cards and your software limits your ability to use anything bigger than 2gb you can still insert and use upto 2gb of space on an SDHC card that is, say 16gb so that is how you can tell if it is hardware or software that limits the use of an SDHC card.
Jun 02, 2011 | Computers & Internet
UNABLE TO ACCESSMY 4GB MICRO SD CARD
Your memory card reader lacks SDHC compatibility. You must either update your pc card reader to one which is compliant with SDHC or use a cheap external card reader to do the job.
SD and SDHC cards look the same and fit the same slots, but they have significant technical differences which older readers cannot handle.
Jul 22, 2010 | SanDisk 4GB microSDHC Memory Card
Windows 7 doesn't read my Dynex usb 2.0 card reader
1. You have to see if the program is compatible with the Windows 7 operating system.
this is possibly due to drivers that the Windows 7 doesn't have in the "cab" files.
this manufacturer of the Dynex is your next step for a Windows 7 driver set.
May 29, 2010 | Dynex External USB 2.0 Multiformat Memory...
System could not detect the pend drive
Hi viveka_sirka,
If you have the 4GB card the most likely problem is your reader is not SDHC compatible. SDHC cards are all SD cards that are 4GB and larger. If your reader is the reason then you must get a new reader to plug into your USB port that will read SDHC cards.
Kingston Tech Support
May 02, 2009 | Kingston 4GB Secure Digital High Capacity...
Compaq SR2041X does not read SDHC card
Possibly a band Reader.. one thing you can do is test to see if it reads other types of memory cards such as panasonic or kingston. If those do not work then it may be a bad card reader..
Apr 17, 2009 | HP Compaq Presario Media Center SR1750NX...
My toshiba laptop doesnt read SDHC card
sdhc cards are not backwards compatible with sd card slots. sd cards however are backwards compatible with sdhc card slots. newer card slots and readers are sdhc and sd ready but i'm afraid your only option is to buy a usb sdhc card reader. normally the 52 in 1 readers and ones like that work well and really don't cost a lot on ebay. the only other thing you could try is to put the sdhc card in an sdhc device (such as a camera) and link it up to the laptop that way.
Apr 04, 2009 | Toshiba Satellite M115-S3094 Notebook
Sd Card reader not recognising SDHC cards
When You Insert your SD card into the internal card reader, then the SD card is not recognised by the system and the SD card drive doesn't show there. The problem can be because of driver issue, system issue and device issue.
To fix the problem you need to go at device manager if there is a yelllow sign in SD card controller, the problem is most probably caused by a driver issue. Then you need to update the driver. You can also download the driver for your card reader.
Also, check if your SD Card is broken. You can also check it into different devices port.
If it is detected then you can backup of your data.
If the problem not resolved by any means and you require you SD Card data then I will suggest you read - https://www.stellarinfo.co.in/services/removable-media-recovery.php
Mar 03, 2017 | Computers & Internet
SD Card Reader Not Working on Acer Aspire 5600 Laptop
Your card reader on your computer isn't capable of reading SDHC cards. You have to use a card reader approved for SDHC use.
Jul 15, 2008 | Acer Aspire 5100 Notebook
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
