Question about HP PSC 2210 All-In-One InkJet Printer
Printer stopped working
Would make a loud screeching noise after printing and then I would open the top and push enter to reset. worked for a while, now it will not reset at all. Noticed a black belt type thing hanging over paper tray at this point. Is this repairable?? Please help.
ruth@matplumbing.com
  • DLW1295 Sep 28, 2008
    I see A SMAL BLACK LOOKS LIKE A BELT BROKEN CAN THIS BE REPAIRED
  • cfairgrieve Oct 22, 2008
    My printer too is makig a screeching noise and keeps reporting a paper jam when there isn't one. It won't reset.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
Sure it can be fixed; anything can be repaired, if you’re willing to spend the money. These Ink Jet Printers are designed to be thrown away. You can replace it cheap then you can have it repaired. The average life expectancy of modern electronics is 4 years or less.
One of these sites might even have the parts you might need?
http://www.all-laser.com/
http://www.sphere.bc.ca/test/hpparts.html
Good Luck
Posted on Oct 25, 2008
How to reset error e4
The reset method work for canon printers that using PG-40 and CL-41 cartridge. After doing this reset method canon printer will not display low ink notification anymore and will not show error code “E4′ or “E5′.
Here How to Disabling Low Ink Level Notification for Canon IP and MP, the method to reset ink level notification:
  1. Push “resume” for 5 seconds for canon IPXXXX. For canon MPXXX you must enter to service mode.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Enter to service mode for canon MPXXX
  • With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
  • When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
  • When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
Apr 15, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
My printer reset button keeps flashing. i have switched it on and off and still does not work 1p3500
Hi there
Ink level notification:
1. Push “resume” for 5 seconds for canon For MPXXX you must enter to service
Mode.
6. Push colour button 2 times
7. Push Power switch again, Printer will print 1 page
8. Open cover
Button while pressing and holding the Stop/ Reset button.
Holding the Power button.
Order), the printer will move into a service mode. (Waiting for menu selection)
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 20, 2010 | Canon PIXMA iP3500 Printer
Canon pixma mx700 error code 5010
5010 is a scanner error from the scanner on top. Canon has no parts for these and you can only replace the entire top of your machine. If you can get it apart, you might clean and lube, but it's not made to be opened.
Jul 03, 2009 | Canon PIXMA MX700 All-In-One InkJet...
When I print with my bother 1450 hl laser printer, the printer ma
Hello sir; Before we go further I suggest you replace a new cartridge see what happen.
May 18, 2009 | Brother HL 1450 Laser Printer
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
Samsung CLP300 cover pops open while printing
if you used a non samsung toner cartridge replace it with another of a different brand or a samsung one. when it pushes the cover open look to see which toner cartridge is pushed out and replace that one
Feb 24, 2009 | Samsung CLP 300 Laser Printer
Screeching noise from the carriage return after printing
Hi mothermoon,
This could be coming from dirty rollers. Raise the top of the unit and take some Q-tips dipped in isopropyl alcohol (rubbing alcohol) and start cleaning all the rubber rollers and especially all the steel rolling pins that are in front of those rubber rollers. Spin the rollers around, by hand, to make sure you clean all around them, not just one spot. You'll be surprised how much residue you'll get off these parts. Even if this doesn't help your particular problem it should be done as standard maintenance.
Aug 20, 2008 | HP PSC 2210 All-In-One InkJet Printer
Carriage jammed
first open the door and ckeck out any optical in carrage moving area are not shigted if the carrage movoing area are free then ckeck in service station it is working properly or not if it is working properly then ckeck the endcoder strip and if it is also ok then reinstalled the mecanism your problem will be solved
Jul 05, 2008 | HP PSC 2210 All-In-One InkJet Printer
Loud Screeching noise when printing.
if i was you just phone HP and get it replaced, thats if its still in warrenty.
Apr 18, 2008 | HP LaserJet 2840 All-In-One Printer
HP PSC 2210 All-In-One InkJet Printer Logo
77 people viewed this question
Ben Johnson
