Green staticy looking outlines
All channels have green staticy looking outlines covering the entire screen, mostly all the outline of screen and all dark colors. These lines outline every persons body.
    Master:
  • 763 Answers
Did you try to check the manuals for the configuration of it? it must be have settings on it. try to use it in a dvd player and see if still the same happening.
CHARCOIS
Posted on Sep 23, 2008
    Master:
  • 505 Answers
Ok turn the tv of for 40 minutes by the power point and back on that way it will reset all picture - and should go back to normal please let me now how this goes's
Make sure you un plugged it by the power point
    Guru:
  • 1,894 Answers
You mean like shadow in all the objects you see in the screen??
correct me if i am wrong
    Genius:
  • 1,550 Answers
What is model no and brand of your tv ?
How old is your TV?
Have you changed or replaced any parts recently ?
post back this details
SAM ANDERSON
  • SAM ANDERSON Sep 23, 2008
    Thanks for providing the details
    It sounds like the convergence settings for the TV may not be adjusted properly.You should get the owners manual out and go to the convergence section
    which will have specific instructions on how to adjust convergence.
    Convergence will need adjustment once in a while to compensate for
    aging of the circuits and other changes.
    If you still need help feel free to ask .
    SAM ANDERSON
Tip
How to reset nokia mobiles life timer to ''0''
Nokia life timer is a counter that keeps track of the Total call time of your phone. It will show how much the phone has been used, and it?s the best thing to check if you?re planning to buy a used Nokia Mobile.
To see the Total Call Time or the life timer counter, On the standby screen type the following code *#92702689# (Easy way to remember this is ? *#war0anty#). And it will pop up a message that shows the life timer in hours and minutes.
Here is a detailed procedure to make this life timer zero.
REQUIREMENTS:
The following files are required to reset the life timer:
  1. Nemesis service suite link: Download from Here
  2. lifetimer.pm file: Download Here
PROCEDURE:
1. Download and Extract the lifetimer.pm file, and Download Nemesis Service Suite.
2. Install Nemesis Service Suite on your Computer, It won?t take much time.(select the first option)
3. Install Nokia Cable Drivers (No need to install, if you have Nokia PC Suite already installed)
4. Connect The Phone in ?PC Suite? Mode to the PC
5. Open Nemesis Service Software
6. Click on ?Scan for new Device? Button on Top right Corner
7. It Will take a few seconds to scan, and it will load up the software interface after communicating with the Phone.
8. Click the ?Phone Info? Button.
9. On the Bottom, Select and open the ?Permanent Memory? Tab, which is next to the Fbus info.
10. Click the ?Write? button on Below right, and open the Extracted lifetimer.pm file on your PC.
11. After the lifetimer.pm file is opened , it will immediately start writing it to the Phone?s EEPROM Area.
12. The Procedure will end when the progress bar reaches 20%. This is normal , and on the bottom right side, it will display its done.
13. Unplug the Phone, and Restart it.
14. After boot up, Check the life timer .
Note: This method has been tested on following devices: Nokia 6630, 6670, 6680, 5500 sport, 5700XM, 6110 Navigator, 6120 Classic, N70, N72, N73,N76, E50, E51, E61i, E65, N80, N91, N95, N95 8GB, 5800XM Mobile devices. If you want to try it on other S60v3 or S60v5 mobiles, do it at your own risk.
Caution:
  • Power Failure During Writing will cause damage to the Phone, And there is a chance that it might brick the phone as well.
  • Loose, worn out Data Cables Might fail the Writing process, and there are chances of damage to the EEPROM area of the phone.
  • Do not attempt this with phones that are not included in the confirmed list.
By:- Mohammed Abdulhadi
on Jun 21, 2010 | Cell Phones
Outliner keeps shutting off
let take look inside your trimmer make sure your power cord is disconnected before you do this.take the 2 top cover screws off, now open the cover like a book. Look at the coil, if the coil looks dark color like if it was cook, your coil is burning, these coils should look white and pink color. if this is the case you need to replace the coil. I recommend a professional for this. Their are other precaution when installing these type of coils. Try mannyssharpening.com they have 22 years in the business
Mar 07, 2010 | Andis 04603 Hair Trimmer
Red color outline and double vision
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 05, 2010 | Sony KP-51WS520 51" Rear Projection...
Projection lights don't line up
Projection TV sets have several common problems listed below.
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
Example Photo:
You can see more examples and find a fix here...
Jan 04, 2009 | Hitachi 53SBX59B 53" Rear Projection...
2001 Philips 43P8341Blue outlines on images
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Aug 10, 2008 | Philips 43P8341 43" Rear Projection...
Sony kp57hw40
Reset RGB screen controls....located behind lower front speaker
grill & access cover.....turn down ( CCW ) green screen slightly
and other two colors as needed.....T.
Mar 05, 2008 | Sony KP-57HW40 57" Rear Projection...
Color problem green and pink
I had a very similar problem - the picture would get garbled, the black colour would turn into dark or bright blue tones, and i would get wiggly/jaggy outlines on the picture wherever contrasting coulours' edges met. After 2 service calls (replaced video boards both times), i gave up and popped the back cover on the TV. I wiggled a cable that connects the video board (it is on the top left quarter of the TV if you are looking straight at the front of it), and noticed that the picture improved right away.
I found that there is a bad solder on the cable connector, and simply keep the cover off now, as the connection will get flaky once in a while (especially in warmer temperatures).
Dec 05, 2007 | Televison & Video
KP-53s65 multipule problems, hoping for single solution?
sounds like 2 different problems here. first problem sounds tuner related. second sounds convergence related. third issue (cost effective to repair ?) at this point i would replace the set. i hope this helps
Mar 12, 2007 | Sony KP-53S65 53" Rear Projection...
Televison & Video Logo
185 people viewed this question
Top Televison & Video Experts
Electro Med Services...
