Question about Frigidaire 20 cu. ft. / 566 liter Upright Freezer FFU20FC4A
Ice build-up Upright frost free freezer has a build up of ice (not frost) on the bottom.
  • 1 more comment
  • tinnocker Dec 15, 2008
    Bottom of my frost free upright freezer fills with frost and i have to turn it off to thaw it out.
  • BJ Kalandos Apr 19, 2012
    Check out your drainage hole, underneath the coils could be clogged, and that is why ice is building up at that area, if the drainage hole is clogged the water will get iced as is not getting drained outside as is supposed to be.
    BJ
  • Anonymous Mar 24, 2014
    The frost free upright freezer is frozen in the back and the bottom part of the freezer is working not the other two shelves.
  • 2,071 Answers
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Posted on Sep 22, 2008
2 Suggested Answers
  • 385 Answers
SOURCE: ice building up on bottom of frost free upright
You have a plugged defrost drain line.Lokk on the very bottom and way way back to see if yu can see the drain. Also check underneath you lmay be able to get to it from there or else in back of freezer.Hope this helped.
Posted on Jun 26, 2011
Ice building up on bottom of frost free upright freezer
Jun 26, 2011 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Icing up
I've just had a similar problem. I fixed it by removing the large panel on the back of the inside of the freezer. I found a large build up of ice at the bottom of the freezer which seems to have developed because the drain hole at the bottom of the freezer was blocked. I defrosted the ice, cleared the drain and now the freezer is working fine.
Jul 23, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Ice in bottom of frost free whirlpool freezer
Most likely the drain (located behind the lower panel rear wall) is obstructed. You will want to clear out the ice build up and use a turkey baster with hot water to clear the frozen drain tube.
Jun 12, 2010 | Whirlpool 20 cu. ft. / 566 liter Upright...
Upright freezer,automatic defrost. problem: ice build-up in the bottom.
get down on the floor and look along the bottom of the door to make sure that the door seals are touching.if not and you have an air leak it will cause frost.if its ice and not frost then check all vents/drains are clear.
Mar 17, 2010 | Freezers
Ice build up in the bottom of my upright freezer
If it's a frost free model, it could be caused by a plugged defrost drain. Every time it goes through a defrost cycle the water is supposed to drain into the compressor compartment. You can defrost it by unplugging it for a day or two and then remove the panel covering the evaporator coil. You should be able to see the drain tray under the coil and find out whats blocking it.
Aug 15, 2009 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have an upright freezer and replaced the rubber gasket around the door. It is not sealing correctly and ice is building up and also, water is leaking from the bottom of the door. It is a Fridigaire...
ice on top of freezer door they came out with a fix but does not work two vent holes on bottom of door seal mthem off with silicone moisture getting in if that don't work you need to take liner off and spray foam the liner cavities
Jun 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Kenmore freezer upright frost build up on door
first just take it out and clean that one carefully .And then set correctly and observe it,s working condition.then also it's not working means show it to ur near by worker those who repairs it
Jun 20, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore upright freezer Model # C675-287140J Serial # 08462430AJ water is freezing in bottom tray and building up.
defrost drain may be plugged.shut freezer off,melt ice with blowdryer,and unplug drain.drain probably located behind inner back wall beneath coils.
Mar 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Nov 11, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Frigidaire 20 cu. ft. / 566 liter Upright Freezer FFU20FC4A Logo
803 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
