Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
My TV makes a loud buzzing noise whenever there is a bright picture on
The noise quiets down when the screen gets darker, but depending on what i am watching depends on how loud it is. if its a dark movie its kinda suttle but if i am watching a football game its loud.
    Scholar:
  • 188 Answers
This is usually caused by video signals overdriving circuits. Too much video causes what you are describing. This is sometimes caused by a bad cable or connection, either a TV cable or a video cable. Hopefully it's not a projector problem. If you can check the connections from your receivers and VCR with the projector on you might be able to pin point the problem. Be gentle and if there is adoubt about a cable, just replace it.
Posted on Sep 24, 2008
MY TV PICTURE HAS GONE A LITTLE DARKER AND ADJUSTING BRIGHT, CONTRAST, COLOR,ETC. DOES NOT HELP
How long u have this RCA analoge tv?Around 10 years or more and used it like about 5 or 6 hrs everydays?Yes,than ur tv it is losing CRT tube radiation cohetion.As times go bye years in years out the tv CRT-(tv tube) radiation will slowly dying out,Tv actual pictures will lost some of it luster and it brightnesses to the tv auctual pictures.Brightnesses of CRT tube will get darker and darker until the tv actual pictures barely it is watchable anymore.Contrast,Brightness and Colors adjusting more will help some.But u have to take this tv aparts and take a Flat scerw driver turn up a little bit more of the tv HV-(high voltage) SCREEN button on the FBT-(flyback transformer) to make any big differences of the CRT tube brightnesses.The FBT-(flyback tranformer) is the big block of plastic with a red wire with a black cap hook up to the tv CRT-(tv tube).This adjustment on of the FBT,HV-SCREEN button will help the tv CRT-(tv tube) last another year or two.
Aug 16, 2011 | RCA TruFlat 27F520T 27" TV
A buzzing noise coming from inside the tv but still buzzes when on mute but doesnt buzz when tv guide is up on the screen or when a channel is showing what time it starts
plasma tvs buzz a lot, depending on screen brightness. its probably normal but if you can hear loudly over your volume, may be a bad board or plasma panel. from behind tv, left side = y board, right side = z board, middle = power board ---- bad panel can buzz from anywhere... if you hear all parts buzzing, its probably normal plasma noise
Jun 01, 2010 | Samsung Televison & Video
My samsung 42 inch hdtv is making a buzzing noise
First. The whirring or buzzing sound you hear is the Color Wheel and it needs to be replaced. Second, since I do not know when and if the original lamp has been replaced it is a good idea to replaced the lamp. The bad Color Wheel is the one causing the set to shut down.
Apr 04, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
TV Making a Loud Noise
this can happen with the flyback transformer's brightness which can be adjusted , also the power transformer can make humming or buzzing sounds which can't be adjusted , also this can happen with the picture tube or the CRT board failing , and sometimes chips with heat sinks or the IC's themselfs
Oct 07, 2008 | Symphonic ST420FF 20" TV
Toshiba 56HM195 56 in HD DLP Loud Buzzing and color distortion
If the sound, sounds more like a Hum with some vibration chances are the Cooling fan located behind the lamp is going bad, about $20 to repair, if its a high pitch hum most likely the Color Wheel and if thats the case about $30.
Good luck, my fan just went bad now seeing green dots everywhere, so debating on just junking it out or fixing it, with winter coming on might just breakdown and buy LCD and say the heck with DLP from now on.
Good luck to you..
Jan 27, 2008 | Toshiba 56HM195 56" Projection HDTV
Loud Buzzing Sound
since you changed the lamp my next thought is that the color wheel has failed,,,most good road techs can replace it in the home..the cost would be between 220.00 and 350,00 depending on the company...
Nov 27, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Sony KP-53N74 Rear Projection TV won't power up
how was the picture before ? nice and bright if was ok it may worth fixing probable just power board get the hit ..
May 16, 2007 | Sony KP-53S35 53" Rear Projection...
Buzzing
The noise is caused by dust on one of the toroidal transformers(usually a round looking thing with wire wound around it). Go to the back of your television and try and pinpoint were the sound is coming from. Turn your television off and blow it out with compressed air if it is close to air vents in the television. If you cant see it you might have to open your television back panel.
Nov 23, 2006 | Panasonic TH-37PE30 37 in. Plasma...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
97 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
