Question about Whirlpool Dryers
I have a dehumidefier that runs but does not draw any water in a 24 hr period-- it is set on highest setting for dryness and set on automatic run---i have tried it several times-- my old one pulls a bucket of water in a day.
  • 750 Answers
Hi whitefarm404,
welcome to fixya.com
I'm Huuum .
What is the model and how old is the dehumidefier?
Waiting your response.
Huuum
Posted on Sep 22, 2008
I purchased a LG 24cu ft French door fridge, manual says it takes 12-24 hr to make ice. When I hooked up the water should it have filled the icemaker or will it do that after the 12/24 hr period?
it will take about 12-24 hrs for the unit to be at the controlled temperature that you want -during that time it will be be trying to make ice if you have water hook up turn on the ice maker -but it will take awhile since the unit wont be at temp for the ice to form and accumulate
Jun 29, 2016 | LG Refrigerators
How do i set the system to run 2 times per day
You have multiple start times in 1 or all of the programs A,B,C or D. 1 start time in the A program will run the zones in this program once on the days it is schedule to water. Example: Think of each program as a separate timer. All want to know 3 things What time to water, how long to water for and what days to water. Timer 1 is the A program. Set to water everyday at 8 am for every zone which has a duration. Don't want the plants to water everyday take the minutes out of zone run time in this timer or the A program. Want the plants to water M,W,F add a start time, a run time to corresponding zone and M,W,F in timer 2 or B program. Want the plants to water twice in a 24 hr period add a second start time to each timer or program. and so on. The programs are only used for watering schedules with more or less days per week you want a specific zone to water. Otherwise use only the A program with 1 start time for once a day or whatever days you desire for all zones.
Jan 03, 2014 | Weathermatic ProLine PL1600 Outdoor/Indoor...
My cme 256a8 model scotsman ice melts to fast will not fill my 250 lb. bin in four days. What is the problem? in a hour run time it makes 7 lbs of ice and 4 lbs. water. in one dump cycle it makes 3 lbs...
There are a couple of things to check. The machine must be level. You can remove the front cover and the plastic sheet that covers the plate where the ice is made. Check to see that the water is flowing from the manifold at the top of the plate. You may have to pop the hose off the end of that manifold to clean the water holes out. It must flow evenly over the plate. Probably the most common problem is the radiator coil there the fan draws air through is clogged up so that it can't dissapate heat properly. You should be able to feel a lot of hot air moving through the coils. The fan cycles on and off periodically to maintain a certain pressure in the freon. That is normal. Clean the fan coils and level the machine.
Sep 16, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
I have a Whirlpool Gas Dryer LGR6646BI-12 the clothes feel warm but not hot and they are still damp
The Dryness Level allows adjustment of how damp or dry the clothes are at the end of the cycle.
  1. Make sure the correct Cycle has been selected for the type of fabric being dried.
  2. If the correct cycle is selected and the clothes are still coming out too damp, use the Auto Dry Level button (Kenmore) or Dryness Level button to increase the Dryness level.
  1. If the highest Dryness Level setting was selected and the clothes are still damp, the Customer Focused Drying Mode settings that are built into the machine can be adjusted.
Dryers come from the factory set to Drying Mode 1 (default). Drying Modes 2 and 3, include additional drying time.
Note: This change will affect ALL Auto Dry cycles.
  1. Machine MUST be in Standby mode before beginning. (Standby mode = Plugged in, Power off)
  1. To select drying modes, momentarily press the Auto Dry Level button (Kenmore) or Dryness Level button (Whirlpool) again. The dryer will beep, and the display will flash and show the next drying mode number.
  1. With the door open and the display flashing the desired drying mode number, press the Start button to save the drying mode and exit diagnostics.
  1. Press the Pause/Cancel key at any time to cancel changes and exit from this mode.
Hope this works............
May 01, 2010 | Dryers
GE TBF 17DB 17,2 cu.ft. refrigerator/freezer runs continuously.
Set both controls to their middle settings. Put a glass of water in the frig with a thermometer in it and check the temperature in 48 hours. I is normal for the newer appliances to be on longer than off. Power consumption is highest during start up and it is more efficient to start less often and run longer. When adjusting controls ONLY change one by one number and wait 24 hours before making another change.
Eric
Apr 18, 2010 | Refrigerators
Mira Sport shower running luke warm
Your hot water must come from your coil in boiler and not from a seperate hot water heater - more then likely furnace hasn't been on for heating your house nor has it been on for any draw of hot water. You have to wait till it goes on and brings the water temperature up to your setting or get a hot water tank put in or a new type wall mounted gas instant hot water unit.
Mar 14, 2010 | Home
Welbuilt Refridgerator (old) - Which way is coldest - 0 or 6?
Most controls work with the highest number being the coldest. Keep in mind that once you adjust that setting you should allow 24 hr for the refrigerator to "equalize" to it new set temp. Hope this helps
Sep 09, 2009 | Refrigerators
Amana model LGA30AW automatic setting doesn't shut the dryer off
You can make adjustments to your Automatic Cycles by adjusting the Factory Dryness Level:
Changing the Automatic Cycle settings to increase or decrease drying time:
If all your loads on all Automatic Cycles are consistently less dry or more dry than you would like, you may change the default settings to increase or decrease the default dryness
level.
Your automatic drying settings can be adjusted to adapt to different installations, environmental conditions, or personal preference. This change is retained and will affect all of your
Automatic Cycles, not just the current cycle/load. There are 5 drying settings, which are displayed using the time display:
0 Much wetter clothes, 30% less drying time.
1 Slightly wetter clothes, 15% less drying time.
2 Factory preset dryness level.
3 Slightly drier clothes, 15% more drying time.
4 Much drier clothes, 30% more drying time.
TO CHANGE THE DRYING SETTINGS: NOTE: The settings cannot be changed while the dryer is running or paused. The dryer must be in standby mode (power is off) to adjust the default settings.
  1. Before starting a cycle, touch and hold DRYNESS for 6 seconds.
  2. Touch DRYNESS to select the dryness level shown in the time display: 0, 1, 2, 3, or 4.
  3. Touch START/PAUSE to save the new dryness level setting.
Oct 05, 2017 | Amana ALG331RAW Gas Dryer
The digital clock seems to be set to 24 hr insted of 12 hr time
No Problem here ya go
To change the clock to 24-hour format:
1. Press and hold the CANCEL and Delay
pads for three seconds.
2. Press the More+ or Less - pad to select
12 or 24 hour.
Jan 14, 2009 | Maytag MER5552BAW / MER5552BAQ /...
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
