Question about BenQ (200NSH-LAMP) Projector Lamp for PB6100, PB620
Lamp goes off after 5-10 minutes - BenQ (200NSH-LAMP) Projector Lamp for PB6100, PB620
    Scholar:
  • 78 Answers
Ok then please try out for getting some heat sink for it.
Posted on Sep 22, 2008
2 Suggested Answers
Marrie
  • 563 Answers
SOURCE: Optoma H77 - Lamp shuts off after coming on for 5-10 minutes
Hi SoonerJDP
This is indeed a warning that the hours on the lamp has been used up and that you will have to replace the lamp.
Remember to reset the lamp timer once you've replaced the lamp.
Posted on May 19, 2008
DLP television
Hello. If you haven't changed the lamp lately, or if you used an aftermarket lamp, that could be the problem. If the lamp is ok, the ballast may have a bad capacitor. A bad capacitor will be puffed up on top. The ballast can be found by following the leads from the lamp. If it's not those, then the color wheel could be defective, and you might be able to hear it making a noise. I hope that helps.
Aug 01, 2016 | Samsung HL-S4266W 42" HDTV
Lamp light flashes then stops. no picture. samsung HLS4266WX/XAA
Was the trouble exactly the same before lamp and wheel were replaced?
If lamp comes on for 3 minutes what do you see on the screen?
the more you tell me the better I can assist you.
Mar 14, 2012 | Samsung HL-S4266W 42" HDTV
After set is turned on for 1 - 2 minutes the TV shuts down, no blinking lights just goes out. After a couple minutes it turns back on then goes off again.
It is symptom of dying lamp in tv, replace lamp of tv to solve this problem.
Please note that lamp has not been dead or broken yet but become weak in result and causing problem.
Lamp replacement procedure is written in user manual and it is easy. Please buy Sony original lamp for good picture.
Thanks.
Jan 05, 2011 | Sony KDF-E55A20 55 in. LCD Television
Main lamp Stops working.
it does sound like your lamp due to the led's. Check how many hours you have on the lamp. You should be able to do this in 2 minutes. Also check to see if you if you need to clean your filters.
Jun 07, 2010 | Hitachi CP-S210W Multimedia Projector
Tv goes black after a minute of being on.
It sounds like you might need to replace your lamp.Unless you here some rapid clicking sounds which would indicate more of a ballast issue,but if thats not the case most likely your lamp night need replacing.You can purchase a quality lamp at discount-merchant.com at the best prices.
Apr 01, 2010 | Polaroid FLM-3734B 37 in. LCD HDTV
Tv shut off on its own
Replaing the lamp will fix this problem most of the time.If not count the blinks. This is an error code.
Apr 01, 2010 | Sony Grand WEGA KDF-70XBR950 70" Rear...
2003 chev suburban.battery went dead.replaced battery,now it wont crank and security light blinks
I have ran into this problem many times. Insert the key, and turn it to run. After 10 minutes the security lamp should go out. Turn the key off, and then back to run and let it sit another 10 minutes until the security lamp goes out again. Now repeat this one more time for another 10 minutes until the lamp goes out again. This should be a total of 30 minutes so make sure your battery is fully charged when you start the procedure. After the third time and the lamp going out you should be able to restart the vehicle.
Jan 17, 2010 | 2003 Chevrolet Suburban 1500
Television problem
Try changing the lamp, as sometimes an old or weak lamp will cause this symptom. USE AN ORIGINAL SONY LAMP as the replacements are unreliable
Oct 11, 2008 | Sony KDF-E55A20 55 in. LCD Television
My Sony HD-TV KDF-50E2000 is about 18 months old. The picture went out. The green on light stays on for only a few minutes then goes off and the red lamp light flashes. You can turn the Tv on again and the...
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
Need further help, let me know.
Sep 13, 2008 | Televison & Video
BenQ (200NSH-LAMP) Projector Lamp for PB6100, PB620 Logo
65 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
