Question about Kenmore Oasis HE 27082 Top Load Washer
F 2 code on Kenmore Oasis washer?
What does this code mean and what circut board does it involve? Thank you.
  • Anonymous Mar 19, 2014
    changing circuit board on kenmore oasis he washer
  • 750 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello our01gt
Welcome to fixya.
I'm Huuum and happy to assist you,
Sounds like we need to try to reset the system!
Huuum At your service!
Lets try this,
Like with an error code.
This can reset the system if it is electronic!
Unplug the washer and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Let me know how it works! Waiting for your reply!
Please remember to leave a rating when you are done!
Thank You huuum
This is what Kenmore recommends!!!!!!!!!!
Press STOP once to clear the code.
F=_ "F2" code
Press STOP once to clear code. Press START. If code
appears again, call for service.
Posted on Sep 26, 2008
What does code F1 mean for a Kenmore Elite Oasis model 27032?
Here is a link to some good information on your error code. This should explain the error code you have.
http://www.theworldofwashers.com/2009/03/reader-mail-f1-error-code-on-kenmore.html
Nov 21, 2010 | Kenmore 27032
What does F1 code mean
A Sublime Master at the Samurai School of Appliantology recently did battle with one of these newfangled Oasis washing machines. The F1 error code was intermittent, which made it impossible to troubleshoot. Turns out there’s a service bulletin out on this problem. Come, feast your bewildered eyeballs on the wisdom of the Masters.
Read more: Recurring and Intermittent F1 Error Code on a Whirlpool / Kenmore Oasis Washer | Washer Repair | Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2009/01/25/recurring-and-intermittent-f1-error-code-on-a-whirlpool-kenmore-oasis-washer/#ixzz0vdcTKwJA
Get appliance parts at http://parts.fixitnow.com
Aug 03, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Oasis HE 27082 Stainless Steel Top Load Washer: I have KENMORE ELITE Oasis He and it kept repeated...
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!
May 18, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Screen says oL. Kenmore oasis elite he 110.2708,2709
OL, usually means Over Loaded. It is an error code thrown up by the on board computer.. generally when TOO much wet weight is in the bowl.
Jan 29, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Error F51 for Kenmore Elite Oasis Toploading washer??
bad main board or motor possitioner sensor.. most likely motor sensor.
China made junk parts with a million problems
Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
F1 mean on 110.2706
on oasis u have to replace the main board
Oct 04, 2009 | Kenmore Oasis HE 27062 Top Load Washer
Kenmore oasis washer F1 code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!!
Jun 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
F1 error code on Kenmore Oasis He
I think there might be a recall on your washer call to see. I am not for sure that there is a recall but I a m pretty sure there is. So don't quote me on that. the f1 error code usually means that you have a bad board. f1 means that your pressure switch line is failing and this is all in your board. check your owners manual if whirlpool is not going to pay for this repair sometimes there are extended warranties in your manual
May 29, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis Washer Error Code F1
per sears unplug the washer for at least 10 min then plug back in and push pause or stop 2 time.
Mar 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
147 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
