Question about Sony Handycam DCR-DVD101 DVD Camcorder
Can't open DVD Drive
I click on the open/access button but all it does is click 3 times.
  • bikerjames Oct 07, 2008
    Yeah, same problem-says "preparing to open", then goes into "disc access" like you put a new disc in. I considered just prying it open, but that seems like a bad plan.
    James
Try using the Reset button.
Reset button is inside the door/viewfinder, need paperclip or something small.
Power ON and Eject.
Now you have to Set your date and time.
Most likely cause, scratched disc.
Don't use disc again.
Posted on Apr 07, 2009
I did this and it didn't work, but when I held down the power while it was on it just ended up ejecting after about 8 seconds. Maybe scottshelly had something to the post
Posted on Nov 10, 2008
I just fixed this on mine!  you need to remove the battery and unplug it from the charging cable if applicable, and hold down the power button for 30 seconds.  replace the battery and turn it on.  this should solve the problem!
Where is the button on my laptop to open disc to put dvd in
Make sure it actually has a cd/dvd drive and it appears in the devices and drives (usually accessed from my computer).
If so, then right click on the CD/DVD drive in the windows explorer under devices and drive and click eject.
Feb 12, 2015 | Toshiba Computers & Internet
HOW DO I OPEN THE DVD ON MY ACER ASPIRE E1-472P-6860 OPEN DVD DRIVE
On the DVD drive door there is a very small rectangular push button. It is about 5/32 inch wide by 3/8 inch long. it may take several several attempts at pushing the button but it should open the drive. If it does not open up the My Computer icon of your computer and left click on the DVD icon. When the drop down box appears select eject and right click on it. That should open your drive. I hope info this helps you.
Jun 28, 2014 | Acer Aspire 5610-4648 Notebook
Gateway dx4200 09 dvd drive will not eject?
Unable To Eject DVD From DVD-ROM Drive With The Eject
The DVD-ROM drive will not open to release the DVD when the button is pushed on the drive. RESOLUTION:
  1. Shut down the program that you are installing or running that uses the DVD-ROM drive.
  2. Wait 10 to 15 seconds, and then open the DVD-ROM drive by pushing the eject button on the DVD-ROM drive.
  3. If the DVD-ROM drive door still does not open, do the following:
    • Insert a paper clip or small pointed object into the small hole near the button on the DVD-ROM door.
      Gently push in the paper clip until the DVD-ROM door opens.
    • Remove the CD from the drive.
To prevent the DVD-ROM drive from exhibiting this behavior again, follow these steps:
  1. From the Start menu, point to Settings, and then click Control Panel.
  2. In Control Panel, double-click the System icon.
  3. In the System Properties dialog box, click the Device Manager tab.
  4. On the Device Manager tab, double-click the CD-ROM category.
  5. Double-click Toshiba DVD-ROM.
  6. In the Toshiba DVD-ROM Properties dialog box, click the Settings tab.
  7. On the Settings tab, clear the Auto insertion notification check box, and then click OK.
  8. Click Close.
Dec 03, 2013 | Gateway DX4200-09 PC Desktop
My dvd wont play on laptop
b> Copy-protected DVDs prohibit people from copying them, which is piracy. Copying a DVD to sell or even to give away is illegal. You can play copy-protected DVDs in a standalone DVD player or in your computer's DVD drive, as long as your computer's software is up to date. These DVDs will play the same as DVDs that are not copy protected
Press the "Eject" button on your DVD player to open the DVD tray. Set the DVD into the tray, and push the "Eject" button to close the tray. Press the "Play" button on your DVD player, and the DVD will play. b> On a DVD Drive on a Computer Press the "Eject" button on your DVD drive to eject the DVD tray. Set the DVD into the DVD drive, and push the tray in to close it. Click the "Start" tab on your computer's home screen to open the "Start" menu. Click on "My Computer" to open it. Click on the DVD drive to open the DVD. Click on "Autoplay" to play the DVD.
Jan 28, 2013 | Compaq Computers & Internet
External hdd not working as should
Hi, click on the "Start Button," open All Programs, select the Icon for the (Name) of your Computer; example "Toshiba," next after opening it, choose "Utilities." Once the window open, click to open the by the name you see: CD / DVD Application, or DVD-RAM Utility; now you can [Format] the DVD-RAM Disc accordingly. "If this was helpful to you? Rating the solution is apprecaited, thanks."
May 20, 2010 | Western Digital My Book Essential 1TB...
Iomega select portable external 320GB 2.5" Hard drive not being detected on the PC with windows 7
  • Hi, there are (3) three areas that you can search to find: Hard Disk Drives. 1. From the Desktop, click on the Computer Icon to open the "Hard Drives (window)," next find the Hard Disk Drive (1), this is the "Primary" (C:) Drive. 2. Next, in the Devices with Removable Storage (1)below is the "Secondary" Drive, this will be the (CD or DVD Drives (D:), for "External Drives" the drives locations will be (E: or F:). 3. "If the CD, or DVD Drive is present in this area?" Right click to open, select the Properties "icon" the window opens; in the "All disk drives" (block), select, and "highlight" the CD or DVD Drive, next click on the Propertie's button below! 4. In the Device Status (block), see: if the device is "working properly?" Next, click on the Drives button, select to "Update Drivers." Note: The computer screen may "blink' (3-5 times), this means the update has taken place, Click on the "Apply and OK buttons, to finish. "You may be ask to "Restart the computer, if not? Restart the computer." *The "Second" area is the "All Programs" in the Start Menu, scroll to find: Media Disk Player. Select to open, click on "Setup, and Install." Follow all instruction carefully! *The "Third" area is in the Control Panel from the Start Menu; find in the (right pane). Open the "Contol Panel" go to, and select Hardware and Sound, in the next window, click to open the Device Manager; scroll to find: DVD/CD-ROM drives. Click to open; do the same as above instructions, step by step. "Did this solution help? If so, Helpful Ratings Feedback is appreciated, thanks paul7of9"
  • Feb 17, 2010 | Electronics - Others
    It will come on but it says primary hard disk drive 0 found and secondary hard disk drive 1 not found
    Feb 15, 2010 | Dell OptiPlex GX110 PC Desktop
    DVD won't eject from Dell m1330
    1. If the CD/DVD drive tray not open.
    Open "My computer" windowsand select the CD drive . "Right click" onthe CD drive.You will get apop up windows with the "Eject" option.
    If it open that's means the power supply is ok
    2. If the DVD drive is not showing on my computer windows or the DVD is not detect the CD/DVD disk
    Tofix the problem we need to delete the UpperFilters andLowerFiltersregistry key for more details about the troubleshootingstep please follow the below link.
    No longer access the CD drive or the DVD drive
    3. Make sure the cables (IDE,SATA) etc are seated firmly and jumpers are set correctly (slave master...etc).
    4. After follow the above steps if you still face the same problem then need to contact the local hardware vendor.
    Regards
    http://ithelpdesksupport.blogspot.com/
    Aug 09, 2009 | Dell (0F146) Internal DVD Drive
    DVD OR CD not drive by CD-ROM
    Option One:
    To fix it, open “My Computer”, or “Windows Explorer”, find the drive icon for your CD/DVD player/burner and right-click on it. When the popup menu opens, choose, “Properties”. Click on the “Auto Play” tab. Click on “Select an Action to Perform”. Click on the “Restore Defaults” button and click on the “Apply” button. Then click on “Prompt me each time to choose an action” and click on the “Apply” button again. (Note: If you want it to open in a particular program each time you put in your music CD, instead of clicking on “Prompt me…” choose the program you want it to open each time you put in your CD. Now click on “Apply” and “OK” and restart your computer. Now put in a music CD and see if it works as it should.
    May 30, 2009 | Acer Aspire4720 14.1-inch Notebook PC PC...
    Multibay/cd/dvd access
    If you look on the side edge of your laptop (more than likely the right side) you should see a CD/DVD drive bay with a small button. Just press that and it should pop out enough for you to finish pulling it out.
    The other way to do it is to open "My Computer", right click on the icon that says "CD/DVD" and select "Eject".
    Let me know if that helps.
    Mar 11, 2009 | HP Compaq nc6000 Notebook
    Sony Handycam DCR-DVD101 DVD Camcorder Logo
    303 people viewed this question
    Top Sony Video Cameras Experts
    Larry Stiles
    Larry Stiles
    Are you a Sony Video Camera Expert? Answer questions, earn points and help others
