Question about Frigidaire ATF6000ES Front Load Washer
LTF6000E - Grey residue remains in gasket after wash.
After some washes there is a grey residue in the gasket. It looks and feels like a wet mushy sandy stuff. It appears it is a result of the gasket rubbing against something and these little bits resulting from that. I have observed the wash through the door and I cannot figure out what is rubbing or causing this. I could just replace the gasket I suppose but I do not know if that actually solves the problem or this is just a sympton of the the real problem.
  • 1 more comment
  • Glen Schmidt Sep 22, 2008
    It is not dirt from the clothes. We have not seen it in the last year and now have seen it in three washes over the last several days but not every wash. The stuff is the same color as the gasket, that dull grey color and actually feels like that same rubbery material. Just completed to small washes and no problem. Might it be an overload problem? But why now, in the past I have seen the EFO msg flash and never saw this problem.
    If it is just a matter of the gasket wearing, why doesn't it happen every time? Is there something specific that triggers the residue to form and collect in the gasket?
  • Glen Schmidt Sep 25, 2008
    Your analysis helped me figure out what was going on. I believe you are right in that the bleach and detergent did impact the integrity of the front gasket, but it made it softer and less durable. What I see happening is that sometimes a rag will get stuck between the edges of the gasket during the final high speed spin. This rag rubbing against the gasket caused it to create this fine mushy material. I had to stop the washer just after the high-speed spin because otherwise it goes through a low-speed rocking that then disloged the rag from the seal which is why I did not notice what was happening before.
    Bottomline: New gasket has been ordered.
    Thanks for all your help.
    Glen
    President:
  • 1,952 Answers
The musty odor will dissipate if you leave the door open when the machine is not in use. You can eliminate both the musty odor and the residue by washing with hot water every four or five loads. In hot water, the detergent "optimally performs," removing all the dirt from both your clothing and the machine
Posted on Sep 22, 2008
  • 43 Answers
Dear tcaservice,
its just a simple problem and my suggestion is don't replace gaskets. during each and every wash some dirts gets accumulated in the gaskets.
tats why service people asked you to clean the gaskets at the end of each wash.
so by not doin tat, after some washes those dirts accumulated in the gaskets feels like a muddy stuff... and you can notice this ly if the gasket is wet and not in dry condition.
so just clean the gaskets with plain water, wipe out dust and use it again. you will not see those stuffs.
thank u sir/madam..
  • Arun Kumar Sep 22, 2008
    if still problem exists then replace your gaskets.
    President:
  • 1,263 Answers
Over the life of a front loading washer the seal/gasket degrades largely due to the chemicals in the detergant as well as bleach. you were right in accessing the re-install of a new gasket. most gaskets/seals get hard and brittle therefore the little residue balls that your are finding in your laundry......please rate this ....thanks
  • 4,472 Answers
Residue or lint after washing Improper sorting:
Sort loads properly. Do not dry "lint-givers" (towels, fleece, knits) with "lint takers" (synthetics, textured or nubby cottons and linens).
Paper or tissue in pockets:
Remove all items from pockets before washing.
Overloading:
Overloading is perhaps the most common mistake users make and is at the root of many laundry problems. In this case, overloading will trap lint on your clothes.
Detergent isn't dissolving:
Use warmer water if safe for fabric.
Some detergents do not dissolve completely. If it is a continuing problem, try a different detergent.
Here are the basic steps to check. Though I have seen this issue with other people. It is possible it is the seal. I know on some washers they redesigned the seal to help a problem like that. Though I couldn't find info about the problem on your specific model.
Thanks,
Lee
Also if it is still under warranty I would have it serviced at no cost to you.
  • Lee A.
    Lee A. Sep 22, 2008
    Gasket part
    there is the link to the specific part, that should be what you are referring to. If you still need assistance let me know.
    Thanks,
    Lee
  • 2,071 Answers
That is the result of gasket worn out you better replaced it,so it will works normal again..
Click below for spare part's;
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Hope it may helps you;
Regards,
VOTIT
    Genius:
  • 1,847 Answers
This could be some dirt form the clothes. tty washing the clothes again and check for the second time.
There is gunk buildup behind the gasket, is that normal and should it be removed?
It's common for detergent residue to build up inside of washing machine tubs and gaskets. Use a cleaner once per month to keep high-efficiency washing machines free of odor-causing residue.
Physically remove the stubborn residue remaining after using the cleaner.
Aug 07, 2014 | LG Washing Machines
06 kia optima ....engine was shaking...have changed spark plugs, wires and coil pack...engine ran ok till next day....now engine shakes bad...won't get speed over 40. Engine bogs like it is flooded....
you got oil leaked down the plug holes from the valve cover you will need to buy a tube of ultra grey silicon . try this take all plugs out wash them with carb spray wash the spark plug holes out with rag twisted onto screw driver and gas ect ok when dry put a little smear of the ultra grey onto the spark plug threads near the center of the threads all the way around then screw plug into hole let it dry do all the plugs this way it should top the miss if it come back and theres more oil in the spark plug tube hole youl have to take the valve cover off and clean the gasket with gasoline or carb spray dry the gasket off then clean gasket groove on pan and dry it with rag (tee shirt) put a smear of the ultra grey silicon (get at autozone ) all the way around the gasket both sides wash the head where the gasket go's (seals)with gas or carb spray (also nail polish remover ) put valve cover on see that the gasket is in place proper befor tightening the cover bolts
Dec 24, 2017 | Cars & Trucks
Sludge On white clothes
WASH PERFORMANCE INFORMATION
12.1 Creasing
Creasing can be caused by over loading SmartDrive or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet
clothes to sit in the washer or laundry basket.
12.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash
water. Cold water below 20oC does not wash effectively. Select the wash temperature according
to soil type. For example, blood and mud are better washed in cold water, while sweat and oil
based soil wash better in warmer water. Loads made up of articles of varying sizes will wash
better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent than
soft water.
12.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading SmartDrive can increase the likelihood of linting. Insufficient detergent for
the load can increase linting as there will not be enough detergent to hold the lint in suspension.
Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the
fabrics attracting lint.
12.4 Detergent Residue
Over loading SmartDrive can result in detergent residue being caught in the creases of the
fabrics. If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check
the instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times
may not let the detergent dissolve properly. In these cases pre-dissolve the detergent.
Overdosing of detergent can also cause residue when foam breaks down and will show as white
specs on the clothing. Poor quality detergents can result in residue.
12.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is
recommended that SmartDrive is periodically filled with hot water, plus 1-2 cups of dishwasher
powder and left to soak.
12.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that SmartDrive is periodically filled with hot water, plus
detergent and left to soak.
12.7 Dye Transfer
Wash and dry non-colourfast clothes separately. Non colourfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
12.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load SmartDrive by wrapping clothes around the agitator.
Aug 09, 2013 | Fisher and Paykel Washing Machines
Fisher and paykel washing machine GW703-U leave black spot on clothes during final spin
12 WASH PERFORMANCE INFORMATION
12.1 Creasing
12.2 Soiling
soft water.
12.3 Linting
12.7 Dye Transfer
12.8 Tangling
Jan 30, 2012 | Fisher and Paykel Washing Machines
Smell from water remaining in grey seal
My GE washer model wcvh6400j0ww was leaking. May be standing water under your machine. The repair person thought the gasket. It turned out to be the water in-let pipe (WH41X10118 and you will need seal WH41X10119) and not the gasket. He ordered the gasket and took machine apart to replace and found cracked pipe. Take your machines front off and make sure it is the gasket leaking. Good Luck,
Jul 13, 2010 | GE Energy Star WCVH6260F Front Load Washer
Beko WMA 520 W. how do the wires sequence go on the on/off switch.....2 grey, 2 orange. cant remember
You can try calling this number and ask them
0870 241 0357 (UK Washer Service)
Or Go to this page and send an inquiry
http://www.beko.co.uk/partsandaccessories.aspx
I don't want to shoot from the hip here but I would think orange to orange on ONE set of contacts and grey to grey on the other.
You can use an Ohm meter to read the switch across the terminals to see which 2 contacts open or close on ONE side of the switch then connect grey to grey leaving the remaining two (2) terminals the obious connection for orange to orange.
Jan 20, 2010 | Washing Machines
Clothes come out with stains on them
I had a similar problem with my Kenmore front loader. Turned out that the rubber lining around the door was trapping dirty, soapy water causing a nasty residue to collect. That residue got onto the clothes. I cleaned the rubber liner and now keep the washer door open between uses. I still occasionally wipe down the rubber liner with a wet rag. Problem seems to have been solved.
Jun 13, 2009 | Samsung WF328AA Front Load Washer
Maytag Nepturn TL FAV6800 Grey spots/debris on clothing
Hello davidsonrepl,
I was waiting with someone with more experience to post back on your issue. I haven't experienced this issue it but I would not rule out a transmission seal failure causing your oily grey substance in the wash tub. If you want to investigate further you can get the Service Manual from here
http://www.fixya.com/support/r1655507-found_service_manual_neptune_top_load
take a look at page 38 and on and see if you feel OK with a tear down to the transmission.
Feb 18, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Noise during wash and rinse cycles
Got a response from another site - the noise was due to the recirculation pump (situated low down at the back on the other side from the drain hose) which was working, but clogged with a nasty grey 'porridge' of limescale and powder residue in the pipes either side of it. Dismantled, cleaned out pipes and ran a wash cycle to clear any remaining crud out. Seems ok now and wash jet working, noise gone.
Mar 28, 2008 | Zanussi WJD1457W Front Load Washer / Dryer
Old washing machine is starting to leave grey streaks on clothing
hmmm..let's see..sounds like you have some residue accumulating from something possibly seeping into the tub. That can be old rubber, a metal sheath, or even an leak of lubricant. Like an old car, there are parts of every mechanical device that need to be attended to.
I'd recommend you find the most seasoned person that works on older machines, to come by and assess what is 'leaking' on your clothing. Grey comes from something metallic or rubber/plastic.
Hope you can solve this one, and keep that old machine happy.
Feb 19, 2008 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
121 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
