Sony lbt v702 hifi system stack
Hi
I purchased 2nd hand but not sure where the ac cables go. The main ac cable to the mains is from the tuner. Then you have 3 ac cables which somehow connect up from the amp, cd player and equaliser. not sure where these go. Any suggection, please
  • jd510
    jd510 Sep 22, 2008
    Thanks
I have a sony stack system i had put away for a couple of years, i have now put it back together, but when i wire both speakers up, the sound go s to a point then cuts out, whith a mesage on the front saying protect, it i take one speaker off! nothing happens, can any one help please?
thak you for your time.
Steve.
Posted on Jan 26, 2010
I have a remote which doesn't work anymore. (20 year old sony LBT-V502 hifi installation and it's standard RM-S530 remote.) What can I do? is it possible to buy a new one?
That is really old. Once you have tried fresh batteries there is not much more to do.
Amazingly there is one for auction on eBay. Good luck. Personally though, I would not buy it used at that price, I'd get a nice new hifi, maybe DAB radio,
http://www.ebay.co.uk/itm/Original-RM-S530-SONY-Remote-Control-Audio-system-for-HiFi-video-CD-Tuner-Tape-/200986250606?pt=UK_AudioTVElectronics_Video_RemoteControls&hash=item2ecbb6cd6e
Nov 11, 2013 | Cell Phones
My sony hi-fi lbt-sh2000 component sound volume does not increase after long hours playing
example you play music high base and thin you give a high volume.have a automatic sensor inside the player to low the high base.
Feb 06, 2013 | Sony Main Body Of Lbt-Sh2000
I have an old Sony LBT D505 (with a SONY TA D505 amp) its abundled system but for some reason it automatically sets source to tuner and i cant change source. I have checked the system control cables and...
it must be due to a bad connection if the cables are fine it may be the connectors or where they solder on to the amp or radio board if the amp with out the radio cables attached still will only select tuner its the amp fault, even worse i could be a faulty integrated circuit eg faulty micro chip good luck with finding a replacement
Jul 04, 2011 | Sony Audio Players & Recorders
Have isolated problem to vhf/uhf connection point. white lines flash in pic. w/a popping sound & if they stay for very long there is a buzzing as in over white or over modulation. problem shows when...
Problem seems with main tuner in this tv as other AV inputs working fine so please replace main tuner (TU2) to solve this issue.
There are two tuners mounted on A board TU1 and TU2, please replace TU2 and part number would be written on tuner itself.
TV is approx 10 years old so I would recommend that do not spend lots of money on it.
Thanks.
Feb 27, 2011 | Sony KP-53HS30 53" Rear Projection...
Hi there I have a Sony LBT XG100AV Stereo System, at the moment it keeps flashing Protect push power, we were listening to music at the time when this happened is there any chance you can give me advice on...
I have the same unit, although it's a bit old now. I used to get that problem, and the protection system is to protect the unit from over-heating, and the main cause is its because the unit is getting hot and/or there isn't enough air going through the rear of the unit. I found a fan or better air flow helps.
Dec 28, 2010 | Sony Multi-System Mini Hifi Systems / DVD...
Sony midi Hifi switching itself off
These digital amps are very prone to blow if the speaker wires are shorted so Sony appear to have put in a protection system that mutes the amp when this happens. You have to unplug the amp for a minute till the light goes off, make sure no speaker wires are touching each other and then it should work ok. I found the same problem with one I bought 2nd hand.
Feb 03, 2010 | Sony Audio Players & Recorders
Main screen showing "no signal"
KP-43HT20 has 2 tuners, one is main (TU2) and 2nd is called sub tuner (TU1). Both tuners are mounted on A board located on right side of TV.
In my opinion, main tuner (TU2) is not working and causing No Signal message.
Let me know if you want to repair tv by yourself.to provide you more technical info.
Feb 21, 2009 | Sony KP-57HW40 57" Rear Projection...
P-301 onkyo pre-amp
Hi juicer, If you use the switched outlet, then everything will be turned on/off when you operate the preamp power switch. Use the unswitched, then you have to turn off each unit separately. You choose which one you want. It wont matter.
What connection do you intend to use to connect the LBT zx6 to the Onkyo preamp??
Mar 20, 2008 | Audio Players & Recorders
Open Questions:
1,238 people viewed this question
 Grubhead
Grubhead
