Question about Delta Luv Madrid 4890 Crib
I have a a crib model 4897 i want to transform that to a toddlers bed but i do not have the rails
SOURCE: converting crib into toddler bed
Call customer support @ 18002951980 and customer support can either email or fax instructions at no charge. I just did it and got the instructions myself. Or you can email me @ shannaboxley@yahoo.com and I'll foward the instructions to you.
Posted on Jun 20, 2008
SOURCE: Toddler Bed Side rail for Delta Luv 5-in-1 crib
Try calling the customer service number (212)-645-9033. I have not called them yet to get the conversion rails for our Delta Luv 5 in 1, but I'm hoping that they will know more than Babies R Us!!
Posted on Sep 29, 2008
SOURCE: Jardine Crib 4 in 1
step 1: detach the front panel (part j) from the front posts h(1) and h(2) using allen wrench
Step 2 if mattress support (part K) is not in the lowest position, unscrew mattress support bolts (Part d) from the post and move it to the lowest position
Step 3: Using the wrench provided, attach the guard rail (part f) using 4 bolts (part a) between the left and right front posts
Step 4: tighten all screws clockwise.
good luck
Posted on Oct 24, 2008
SOURCE: Bed rails for Delta Martine Crib
I have this crib for my own child. I ended up buying a guard rail from Walmart. If you tie a knot in the strap after putting it through the rails and then tuck the disc between the side of the crib and the bottom of it, it seems to work just fine. Child has been using it as a toddler bed for well over a year now and there has never been an issue. Chiild is a restless sleeper too. So, I know it works.
Posted on Apr 07, 2009
SOURCE: Transfer Delta Luv Crib (Poma) into a toddler bed
the instructions should be pasted onto the wooden board that the mattress is on.
Posted on Aug 14, 2009
I have a vickie crib .I want to convert to toddler bed. If I take the front rail off there is'nt anything to hold the bed up in the front. It unscewss from the side. Help! Bed was purchaced 9/2008 ...
Is this a 4-in1 convertible crib? The Toddler bed will need the bottom railing and a half rail to convert from a crib to a toddler bed. The half rail can also be removed to make the 4th conversion to a toddler bed with out railing. But to convert this specific bed you DO have to add the bottom rail that came with the bed at purchase.
Mar 10, 2011 | Sorelle Vicki
How do I convert from a crib to a toddler bed? Do
It is very simple to convert a crib to a toddlers bed. You just need to remove the side railings by folding them under the bed. It would be automatically converted to a bed that a toddler can use
Mar 03, 2010 | Sorelle Regal 310 Crib
Delta Martine crib conversion kit
You can order the crib rails through your local Babies R Us. We have the same crib, and have been having trouble locating them also. I spoke with the store manager today, and she said all DELTA cribs use the same rails. They are a metal pair that cost $69.99. The number for them is: 617153. Hope this helps!! :-)
Jan 09, 2010 | Delta Martine Crib
Graco 3-in-1 crib instructions
Check this CPSC link.
Most if not all of the simplicity brand cribs have been recalled reguardless of whether they had wood or metal mattress supports.
There were 2 different recalls on the wood version but both were recalled for the drop-side issues.
This link specifically includes the Aspen 3 in 1 cribs and model #: 8740
We took ours to our local walmart last summer (we purchased it in a different state almost 8 years ago). I brought to cpsc report with me. They had not issue with the recalled information we has matching it to our crib. It did take the clerk a bit to find our crib in their system because it was older, but once she did we recieved a full refund, without a receipt.
As far as changing them to a toddler bed. When we converted ours to a toddler bed we simply removed the drop-side from the crib. The drop-side parts can be unscrewed from the side rails. Then we screwed the toddler rails to the bottom of the crib. Ours had screw holds for the toddler rails on the mattress support. If you do not have the holes for it, then you may have put the mattress support on backwards ie with the side that has the holes for the toddler bed rails on the backside of the crib.
Dec 04, 2009 | Graco Apsen 3-in-1 8740 Crib
Converting crib to toddler bed
It should have come with the toddler rail when you purchased the crib.  Simply remove a few screws and take the front of the crib off (what would be the footboard).  Then simply slide the toddler rail in the tracks.
A purchase of adult rails is required to make the conversion to a full size bed for the next step.
What color is the crib?  Call at 770-974-8895 if we can help with your toddler rail.
Sep 10, 2009 | DaVinci Emily Crib
Aug 08, 2009 | Delta Luv Delta - Baby Products 5-in-1...
Want to convert my son's delta crib into a toddler bed
If your crib didn't come with the side rails you may not be able to find them. also check for recalls the Delta cribs have been having a few.
Jul 25, 2009 | Delta Luv Delta - Baby Products 5-in-1...
Converting Delta Martinique 5-in1 Crib to single bed
I have the same crib and it can be transformed into a toddler bed by removing the front rail and it can be transformed into a full size bed using a full size bed frame and the front and back rails of the crib.
May 30, 2009 | Delta Martinique 5-in-1 Crib
Need instructions on how to convert my aspen simplicity crib into a toddler bed?
i think this is the same crib that i have. I remove the front rail that slides up and down, then i removed the plastic contraptions that allow it to slid up and down on. I then attached the bed frame on the lowest setting, by first fastening the two back ends first. Then I attached the toddler rails to the bottom of the bed frame and then once they where on I attached the bed frame to the crib with the rails and the brackets for the bed frame pressed together. I hope i explained it so that i makes sense.
Mar 14, 2009 | Simplicity for Children Aspen 3 in 1...
Convert crib to toddler bed
I finally found my instructions!! It's actually really easy to convert to a toddler bed:
Step one: Take out four screws (two on each side) of the front railing and top bar. They are the screws holding the front railing and the top bar to the side of the crib and the dresser.
Step two: Lower the mattress to the lowest setting.
Step three: Place the toddler bed railing in place. It can go either way depending on which side of the crib your toddler sleeps. We put the taller part of the toddler railing closest to the dresser because that is where our son's head usually is.
Step four: You'll need 4 1.5 inch hexagonal screws to screw in the toddler railing. After 2.5 years, I could only find two of them, so I used two 1.5 inch regular screws that came with the crib. On the taller part of the toddler railing -- the screws go into the 1st and the fifth holes. On the shorter side of the railing, the screws go into the 3rd and the 5th holes.
That's it.. You've now got a toddler bed!
Apr 26, 2008 | JCPenney All-in-One Nursery Crib
Delta Luv Madrid 4890 Crib Logo
175 people viewed this question
Top Delta Luv Baby Gear Experts
ray gallant
Tom Chichester
Are you a Delta Luv Baby Gear Expert? Answer questions, earn points and help others
