Question about Intel D845EPI (INTELKD845EPILPAK10) Motherboard
Fuse Locations I have an Intel d845epi/d845gvsr mother board. None of the components get any power but the green light turns on. I think it may have a blown fuse. Can someone tell me the locations of the fuses?
  • Richard Schwartz
    Richard Schwartz May 11, 2010
    What do you mean by "Display Problem"? Without proper voltage getting to the mb yes you would have a display problem. I am looking for the physical location of all fuses if you know.... Thanks
  • 38 Answers
Dear blankslate,
the green light glowing shows that your motherboard is getting power. check your SMPS first. it can be done
by shorting a green and any black wire(not advisable if you are not a technician). if the fan on SMPS fan rotates
then the problem is with your motherboard(Display problem). otherwise it is a SMPS problem(means power good signal
voltage problem).
thanks,
Posted on Sep 26, 2008
Hi, I need Intel mother board Audio video & all drives for a D845epi / D845gvsr. Thanks Arjun
All the drivers for you motherboard can be downloaded from the following link:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+845+Chipset+Family+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D845EPI
Nov 16, 2010 | Intel D845EPI (INTELKD845EPILPAK10)...
The video driver for this board will not load. It
Minimum requirements also include RAM,Power supply,FSB,Processor speed...etc.Intel homesite "should" tell if it's compatible and with what.
Mar 24, 2010 | Intel Desktop Board D845EPI Motherboard
E-Machine PC with only a green LED on MB on Boot attempt
We have repaired many of these systems. The board was damaged when the power supply shorted. You can get replacement motherboards at www.barebonekit.net click on the link on the left side for motherboards and look for Emachine.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 16, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
I have a emachine PC. PowerSupply blew up. changed it still down
try to remove the memory and put it back again make sure put it fit and correctly
May 28, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Emachine T2885 won't start up after I cleaned it with vacuum
unplug and remove the ram and battery remove the jumper on the clear mos for 5minutes Put everything back together make sure everything is seated firmly
Apr 12, 2009 | Intel Motherboard
Dear,
ELECTRIC SHOK OR IMPROPER EARTHING IS DAMAGE POWER SUPPLY,MOTHERBOARD,PROCESSOR,RAM
HOW TO CHECK IT.
(WHEN CHECKING KEEP CAUTION :- REMOVE HARD DISK DRIVE POWER SUPPLY SOCKET)
1. check power supply watt 400/450 and same another power supply install and check it. if power supply change and system is working ok so problem in your power supply.
2. check CMOS cell on motherboard,(3 volt)
3. Bfore power supply changing check on mother board any capasitor is like as damaged or not.
OR check main chipset ic is marked as intel.whenpower on it is very hitting or
normal)if very hitting require to repair your motherboard.(intel chipset ic near cmos cell or pci slot,)
4. checking of ram on other pc (working or not)(one beeps coming or not,if one beep coming ram is working ok)
Feb 27, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
Want to improve mt RAm size
Hi sanbme, you're Intel board can run 2x1GB of PC2700 / DDR333MHz Double sided memory. Two 2.5 V 184-pin DDR DIMM sockets with gold-plated contacts.
Serial Presence Detect (SPD). You can see Intel's web site breakdown of supported memory by clicking on this link.
http://support.intel.com/support/motherboards/desktop/d845epi/sb/cs-017166.htm
Scroll down to, "The following table lists the supported DDR DIMM configurations". Here you'll see the chart.
This next link supports the Intel D845GVSR motherboard for memory.
http://www.1stchoicememory.com/catalog/configurator.asp?b=INTEL&m=1955&p=C019551757
You can also got to this link & Crucial will scan you're system & make suggestions. http://www.crucial.com/store/drammemory.aspx
Enjoy!
Still have questions? Feel free to ask.
Mike
May 14, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Emachine T2742 MB D845EPI/D845GVSR
The diagram for that 9 pin J9G1 is alongside the CMOS battery.
Dec 25, 2007 | Intel Desktop Board D845EPIL Motherboard
Intel D845EPI (INTELKD845EPILPAK10) Motherboard Logo
328 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
