Question about Hotpoint FFA60 Bottom Freezer Refrigerator
Replacing regulator on the hotplate of a hotpoint cooker EW62
How do I replace the hotplate regulator on a hotpoint cooker EW62
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Hotpoint ew81n cooker. Non working
Hi.
Unfortunately, the oven thermostat is non adjustable.
However, it is normal for oven temperatures to vary by + or - 10% of the setting.
This is acceptable, so to compensate, set the temp 10% less of the required temp setting.
Make sure you have the sensor fitted correctly inside the oven compartment
Make sure that the thermometer is accurate if you are checking the temperature with one.
Posted on Feb 23, 2011
SOURCE: I would like instructions on
To identify functions of selector switch on Tricity President Electric Cooker
Posted on Apr 07, 2011
I have no power to the oven or ceramic hotplate when the power switch is on
If the cooker has been working on lighter gauge wiring for a long time and then worked for a short while on thicker cable, it may be due to a failing or failed element. With the bigger cable, its just been taking longer to trip out.
Apr 19, 2015 | Ovens
Creda Cooker
It is under the ceramic top. Fixings are at the rear.
Dec 18, 2014 | Cars & Trucks
I would like instructions on how to operate a Hotpoint double oven BD51 and hotplate BE71 as I have just moved to a property with this built in cooker
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 29, 2011 | Hotpoint Microwave Ovens
Hotplate on ceramic cooktop not working, another won't turn down.
If 1 of the plates is not working at all, then it is going to be the plate itself, or a faulty regulator, you will have to take it apart to check the plate.
The other plate that you cannot control, needs the regulator replacing.
Mar 25, 2010 | Ovens
Replacing faulty regulator for hotplate
Remove hotplate and oven control knobs. Under the 2nd and 5th knobs is an extra screw which holds on the front cover. Unscrew these and free the cover then access is gained to the screws (2 on each edge) which removes the plate to which the regulators are fixed.Remove the faulty regulator by unscrewing it from the plate,(2 screws) It is an easy job then to install the new part taking care to put the correct wires on the correct terminals. Reassemble, job done!
Jan 11, 2009 | Belling Cooktops
The hot plate is heating up when the selector is in off position
Hotplate heating up when regulator/selector switched off. Hi ,this is gil1714 in Scotland. Two possibilities on this one, 1) the regulator is faulty:- replace
2) if the control circuit (regulator) is wired on the neutral side the hotplate may be leaking current to
earth, thereby completing the circuit. This would only occur on a supply that was not protected by
an RCD. If so replace hotplate. Hope this is useful,
Dec 15, 2008 | Ovens
Beko cooker model DC211B
Hi
many thanks for your reply ,I suspected that a charge may be applicable for your guidance of how repair the Fault .
Hence enough money spent as I was not happy with the wiring of the appliance as it would not have passed a P.A.T. .
I have purchased a New Cooker Model DW531 as the appliance is for my Disabled Brother & his Wife (Trade Price )
Many thanks
Mginty
Jun 28, 2008 | Beko 24 in. D3421F Free-standing...
How to open
There is one screw to remove and the botton just pops off. NR
Mar 25, 2008 | Oster 4724 Rice Cooker
Hotpoint electric cooker sy36
it sounds like you have had bad insalltion caused by your element becoming open circit try replacing and this should solve your problem regards jason
Sep 13, 2007 | Hotpoint SY36 Style Line Stainless Steel...
Hotpoint FFA60 Bottom Freezer Refrigerator Logo
48 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Gil Shultz
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
