Question about Kenmore 659 Electric Dryer
Kenmore 80's series dryer
My kenmore 80's series dryer is not producing ANY heat and it takes 2-3 cycles to dry clothes, help!
  • 1 more comment
  • hbt12 Nov 04, 2008
    replaced the heating element and still no heat!
    Everything else seems to be working fine.
  • britanymae Jan 27, 2009
    On my Kenmore 80 series, I replaced the heater element in Oct. 08', but the clothes still takes two or three times to dry. I put a new venting on the back, but the lent trap doesn't seem too build up as bad, like it did when it was new, and the vent exhaust comes out, but not real hot outside.
  • Anonymous Feb 18, 2009
    my Kenmore dryer is no producing any heat, it spin but just no heat.
  • 943 Answers
HI thanks for the question. you said it took 3 or 4 hrs to dry a load. check the venting its cheap . clean all venting. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 11, 2008
    Scholar:
  • 32 Answers
Dryers could not be simpler devices. I assume that since all you mention is that the dryer is not heating, everything else on the dryer is working as normal. ie. You could put in wet clothes, set the timer start the dryer and the drum starts turning and air comes out of the exhaust. It just happens not to be hot. I am also assuming that you know how to use the drier and that it is not set on tumble (no heat).
If that is the case, the heating element is almost certainly burned out. Basically this is the part of the dryer that glows red (just like an electric stove) when electricity passes through it. Unplug the dryer and see how it can be taken apart. Many open from the top or the back. They are all slightly different. The heating element will be located near the blower fan typically at the bottom of the dryer. Figure out how to get at this, pull the old element out and then replace it with your new one. There will be two electrical connections. You may even see where the element just slides into position by the blower and can be removed with a couple of screws.
You should only need a screw driver to do all of this.
Plug the dryer in and enjoy the warmth.
Posted on Sep 22, 2008
Why isn't My Kenmore Heavy Duty 70 Series Soft Heat Extra Capacity Electric Dryer drying clothes on any one cycle?
One possibility: Air flow! Make sure that the lint trap is cleaned before each cycle. You likely need to thoroughly clean out the vent piping out the back of the machine- a buildup of lint in here can also restrict airflow.
Sep 04, 2012 | Kenmore 659 Electric Dryer
We have a Kenmore 80 series dryer. When we use it their is no heat and it takes more than 3 cycles to dry the clothes. We can not find the manual to trouble shoot.HELP
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 02, 2011 | Kenmore Washing Machines
I have a kenmore dryer 80 series it only makes a lite sound when I push the start button. I won't come on. The power is good.
The Kenmore 80 Series of dryers are consumer grade dryers for home use. As with most home appliances, the Kenmore 80 series dryers will occasionally not work as intended. If a problem occurs with your dryer, however, you do not necessarily need it serviced by a technician. You can attempt to troubleshoot and fix any problems with your dryer before contacting a technician.
  1. Kenmore 80 Series dryers may not run for several reasons. First, make sure that the power cord is plugged into a working power outlet. You may need to plug a different device into the outlet to check that it is receiving power. If the second device does not run on the power outlet, you may have blown a fuse or tripped a circuit breaker. Check your fuse box or circuit breaker box and make the change as needed.
    Next, make sure that the dryer door is fully shut. The dryer will not run with the door ajar.
    Finally, check that the "Start" button was fully pressed and that a cycle was chosen on the machine. If you do not choose a cycle for the dryer, it will not run.
  2. If your Kenmore 80 Series dryer does not heat up during use, check that a heat cycle has been chosen for the load. There are several different dryer cycles you can choose, some of which do not use heat. Make sure that you have chosen a heated cycle.
    As above, check that you have not blown a fuse or tripped a circuit breaker. The dryer may use more than one fuse or breaker: one is used to power the drum, and the other for the heating element. Make sure that both fuses or breakers are in working order.
  3. There may be times when Kenmore Series 80 dryers do not fully dry your clothes. When this occurs, check the lint screen and clear out any lint. The air may not flow as well if the lint screen is clogged.
    Next, check to see if the exhaust vent is clogged. Lint and other particles may clog the exhaust vent over time, restricting air flow and making it more difficult to dry your clothes. To check the vent, run the dryer and hold your hand under the vent. If you do not feel any air flow, clean or replace the vent.
    If you used cold water to rinse the clothes it may take longer than normal to dry. The same is true if the load of laundry is very wet or is filled with items that are very absorbent.
    Finally, check the load size. The more clothes in the load the longer it will take to dry. If you want to reduce drying time, separate the clothes into piles of light and heavy items and dry them separately.
  4. please comment on these solution by saying how helpful.
Dec 22, 2010 | Kenmore Dryers
We have a Kenmore 400 Series dryer. It heats up but our clothes is not getting dry. We have to cycle it twice to get our clothes dry on high heat. Any idea why it would take 2 cycles to dry?
This was the out vent of my dryer... If it gets this bad... open up the dryer housing and clean inside too. Also make sure the intake is free of lint.
Aug 23, 2010 | Kenmore 74602 Gas Dryer
Kenmore Series 80 gas dryer, clothes take 3 hours to dry
Hello, This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas safety valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Nov 04, 2009 | Kenmore Dryers
Hello I have a Kenmore clothes dryer (80 series). It takes multiple cycles to dry the clothes.
Remove the connecting vent on the rear and run a timed load 45 minutes. If it dries correctly repair the vent blockage.
Oct 26, 2009 | Kenmore Dryers
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
I have a kenmore 80 series dryer.When using the auto cycle the clothes come out damp
Kenmore Dryers are all almost the same therefore am sending this;
http://www.youtube.com/watch?v=lHkIK8oy1K4
How to Clean a Dryer Vent Video
http://www.youtube.com/watch?v=5Dj4im31lRY&feature=related
Why is so inportant to clean the lint?
http://www.youtube.com/watch?v=9kxbF31Oh4s&NR=1
It was helpful?
May 15, 2009 | Dryers
the heat thermostat are not functioning well/need to replace parts.
Dec 31, 2007 | Kenmore 659 Electric Dryer
Broken Kenmore dryer 80 series
Hi Dave. The problem is the drive belt. They aren't that difficult to replace and can be done with just a few tools. I'll need the exact model number off of the dryer to explain how to gain access to it, though. The number can be found behind the door on the cabinet (it'll start with 3 digits then a decimal point then more digits, like this; xxx.xxxxxxx)
The part number for the repair is 4392065. This is a complete maintenance kit for your dryer. I recommend it because since your belt wore out, there are other parts that should be taken care of at the same time. Here's a picture and a place to order if you can't find it locally.
Oct 18, 2007 | Dryers
Kenmore 659 Electric Dryer Logo
438 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
