Question about Refrigerators
Kenmore refrigerator door wouldn't swing shut on its own
  • 3 Answers
Raise the front higher than the back.........
Posted on Sep 22, 2008
Can i replace the glass doors on my cooler to the solid doors?
If they are swinging doors yes but if they are sliding doors probubally not, but you could get doors and brackets made up if you really wanted to I wouldn't recommend it
Sep 06, 2012 | True TBB-2G Commercial Refrigerator
Side by side door not shutting properly
There are magnets inside the seal this is what keeps it closed. Either the seal is damaged or the magnets are worn out. They do wear out but usually not for at least 10 years depending on the usage.You can go to www.appliancehelponline.com for a diagraam or illustration of your specific model. The parts also come with installation instructions.
Mar 31, 2010 | Kenmore 57029 Side by Side Refrigerator
I have a kenmore top freezer refrigerator model 253 about 1 1/2 years old. The fridge door sticks at the bottom of the door and the bottom of the fridge inside. There are scratches on the fridge bottom...
i had the problem my self :)
you need to take the freezer door out then the fridg door and add small ring like 1mm to the hinges of the fridg door poot all back and see if it rais the door a bit....
what i did is on the top of the freezer there is option to move the door from side to side ...the plastic that go into the freezer body its a ring with long tube.. i cut the tube and use that plastic :) good luck
Jan 03, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerator door does not swing shut, if it swings at all, it does not close fully unless pushed.
It will have to be adjusted. You can adjust them on the top. You will need a 5/16 wrench. Adjust both at the same time. Make sure the space between them is the same from top to bottom.You will ba able to adjust them so that they both will close when you release them.
Oct 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a Kenmore Elite refrigerator, model # 52603100. How do I level it so that the door easily swings shut?
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
To level the entire unit the front or rear legs should be threaded for adjusting.
Aug 21, 2009 | Refrigerators
Freezer door closing problem
to keep freezer door from popping open close main door more gently try extending front legs a little to help the door swing shut
Aug 04, 2009 | Refrigerators
How do you get the doors on a side by side model to swing shut?
Hi, There are adjustments on each side in the front corners. Turn the bolt clockwise and the front of the refrigerator should raise up. This will cause the doors to shut on there own.
If there is resistance when the door is swinging, check the hinges and see if the nylon washers/closers are warn.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 18, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Doors don't swing shut automatically
The GE side by side refrigerator has 2 cams on the bottom hinge that helps shut the door. If the cam wears out then the door will not close properly. One of the cams is riveted to the hinge assembly and an extra cam is shipped with it. The cam assemblies can easily be replaced by using the information on the Partselect.com website that refers to the GE TFX22R refrigerator.
Apr 25, 2009 | GE GSH25JSTSS Stainless Steel Side by Side...
Want to reverse door swing on Kenmore refrigerator model # 795
Actually, I have a Kenmore 795 model with the top door and bottom drawer freezer. I just tried this, based on "guru's" advice. Unfortuately, though the TOP hinge on this model is reversible, the bottom hinge is NOT. I got it all apart before I discovered this problem. Also you might want to note that the 7/16th wrench is too big for my bolts and the 3/8ths is too small. I had to use an adjustable wrench...maybe they are metric.
An allen wrench will get the handles off for you. You will find little ports for it if you look carefully.
Nov 27, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Can the doors of both the refrigerator and freezer be reversed to open from the other side?
yes take off handles remove center hinge between doors then top and bottom now put all on other side replace doors and handles Thank you
Jun 25, 2008 | Kenmore 64702 Top Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
