Question about Estate TEDS740JQ Electric Dryer
Estate teds680eq1 in the middle of drying it just stopped.when i tried to reset it and pressed start it won't come on.
  • Mark Owens Sep 24, 2008
    Hey thanks buddy, you were right on the money. I will tell others about you.
  • 943 Answers
Hi thanks for the question i would check the thermal fuse located at the back of the dryer remove back panel you will see on the air duct a small piece with one screw holding it on 2 blue wires going to it replace this part but also vacuum the venting and the rest of the dryer as this fuse will fail again if venting is not right thanks the appliance doc
Posted on Sep 22, 2008
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 | Dishwashers
Estate dryer modle TEDS680EQ1 turns on but wont get hot
Check all the thermostats for continuity.
Dec 01, 2012 | Whirlpool Dryers
Turns on wont heat up TEDS680EQ1
Check all of the thermostats for continuity.
Dec 01, 2012 | Estate Dryers
I can't get the control panel to reset. The wash cycle light comes on but it just beeps and the dishwasher won't start. I press the start button and it stops beeping for a minute but it still...
II might need the actual model number. However, you can go to page 9 on this manual and check if the flashing options can fix the problem. I am assuming you have already tried to turn the power off and back on.
The ohter thing to try is the reset sequence. Within 6-7 secs press High Temp/ Heat Dry/ High Temp/ Heat Dry/ High Temp/ Heat Dry. All lights should light up, press Start button to exit.
Jun 24, 2011 | GE Nautilus 24" Built-in Dishwasher
I have an asko T760 Butterfly dryer. It is stuck on P2 but will not run. I shut off the unit, turned back on. The LCD flashes between P1-P4 and what they are, such as extra dry, dry, normal dry, & iron...
Hi.
The machine is telling you that there is overfill, f2 and 4 are faults with overfill system. Lights blinking, pump running and controls dead also indicate an over fill fault :
"1. Disconnect the power to the unit
2. Remove the lower access panels and check the tray under the dishwasher (you will probably find it is full of water)
3. Use a towel or a sponge to remove the water
4. There is a float that should stop the operation of the dishwasher and run the pump if water is in this tray. Check this pump to see if it is functional
5. Test the dishwasher
6. If there are no leaks from the dishwasher into the pan, check the drain hose under the sink
7. THE DRAIN HOSE MUST RUN UP TO THE TOP OF THE UNDERSIDE OF THE COUNTERTOP THEN DOWN TO THE DRAIN. (If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overfill the tray"
Here all diagrams.
Regards.
Ginko.
Apr 26, 2011 | Asko T761 Electric Dryer
Whirlpool estate electric dryer model teds680eq1 starts spins heats up then quits 15 minutes later
The operating thermostat has probably failed. When the dryer haets up, it gets too hot and the high limit thermostat turns the machine off. After it cools down, it will start, again.
Apr 15, 2010 | Whirlpool Dryers
My dryer just stopped working in the middle of drying a load of clothes. now it doesn't do anything when I press teh start button. I've checked the circuit breakers, power ,etc.. any suggestions?
Is the motor still running...did you check that?
If the motor is running then sounds like you have a broken belt or a belt that has slipped off the pulley of the motor
Sep 25, 2009 | Estate Dryers
Estate Dryer Model TEDS680EQ1
check the thermostats and see if your belt is still there if not put a new belt in
Mar 25, 2008 | Estate TEDS740JQ Electric Dryer
Estate TEDS740JQ Electric Dryer Logo
192 people viewed this question
Top Estate Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Terry Schneider
Are you an Estate Dryer Expert? Answer questions, earn points and help others
