Question about Datamax M-4208 Thermal Label Printer
Datamax I4208 Gives me position fault. Error message (I think) is 08.03J? Any help
  • talal_elias Feb 10, 2009
    give me position fault
  • 52 Answers
Position fault is normally a problem with either the formatting or the printer is not calibrated correctly.
Hold the feed button down until at least 3 labels pass by the sensor.
Also check to see the sensor is directly over the die cut on the label if more than 1 up label
Posted on Feb 25, 2009
I have to reset my datamax i4208 every time I print. I cannot do more than one print job at a time. Help.
I need more information. What system are you using to drive the printer with? If it is a Windows computer it is almost certain to be a faulty/outdated driver.
Nov 17, 2016 | Datamax Office Equipment & Supplies
Reset my devise
Do a hard teset by removing battery for ten minutes. Not sure why you are getting error messages every time, if it is the same error message it could be a fault in the machine or it could be that you are doing something wrong when you use the machine. Make sure you read and keep all the instructions that come with the machine. Hope this helps.
Mar 22, 2014 | Sidekick Blood Glucose Testing System - 50...
"no water" message
is the water on? sorry had to ask. after that, you have a valve fault (probably) or board fault (unlikely). with a multimeter check there isn't an open circuit over the valve terminals. if so, get a new valve and chuck it in.
Nov 10, 2013 | Electrolux EIFLS60JIW Washer
I am using Bartender software and a I4208 printer. It won't print on the first 1/10th inch of a 1inch x 4inch label. It also won't present after printing. Any help would be great. This printer is set up as...
In Seagull driver/Bartender software, Present Distance may be called Tear Off and can be adjusted after checking Post-Print actions in Document Properties, Stock tab. Standard setting is 0.40 inches.
On the same tab, right below that, is "Top Offset", and that adjustment may get you the lower Start of Print you want. Ok to try negative number here.
Sep 25, 2013 | Datamax I-4308 Thermal Label Printer
Won't print the leading edge of the label
Sep 25, 2013 | Datamax I-4208 Thermal Label Printer
Hi my printer PIXMA MP780 all in one is not working when switched on it gives me the erra message ##357. everything is on but its not working. Please help
357 ASF paper feed (AP) position error
Cause: An error occurs at the AP positioning in the ASF (Auto Sheet Feeder) unit.
Solution: (1) To reboot, press [OK] button or turn off and then on the power.
(2) Replace the SHEET FEED ***'Y.
(3) Replace the SPCNT board.
Nov 16, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Hello, i have a datamax i class he give a fault "top of form fault" i don't no what that is
The error is indicating that it cannot calibrate the media. Try holding in the feed key for approx 10 seconds and see if it will calibrate. Experiment with the position of the media sensor. It will slide horizontally.
Sep 25, 2010 | Datamax DMX-I-4212 Label Printer
Hi we are using the Datamax Mclass printerwhen we switch on the printer it comes with error on the display screen as out of stock and position fault. could any one please help?
Check to see if you are using the right settings for your paper stock - could be a mark or a gap - this is in your printer settings.
Always check your paper sensor to make sure it is in the right position to see your paper stock.
Calibrate the printer - hold down the FEED button (should have printable stock loaded) and wait till the printer cycles 8-10 times. Will say "Calibration Complete".
If it says "Can not calibrate" then you probably need to check your paper sensor position again.
Hope this helps.
Jul 17, 2010 | Datamax M-4208 Thermal Label Printer
Datamax M-4208 Thermal Label Printer Logo
1,754 people viewed this question
Top Datamax Office Equipment & Supplies Experts
pkwc
kbtkbt
rongg
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
