Question about Daewoo DWC063R Air Conditioner
No drain hole
My daewoo freezes up. It was bought Jan 2006. there is no drain hole and there is no clearance, the in side parts sit flat down against the casing..
  • ritalovesten Sep 28, 2008
    did al the above, the repair service said the compressor is still under warr./ must bring the unit to them./ pay for labor, appro $ 200/ for a $175 unit. thanks for your time
  • 32 Answers
Try to clean your air filter, condenser and evaporator out. If they are plugged with lint the air can't do it's job. Also make sure the fan is working if there is one inside the compressor cabinet. If all these are in good shape you may need to get a leak fixed in the closed system. You probably have a 3 year warranty on it at least. Just call the repair or service number, or check online for a website for that brand.
Posted on Sep 28, 2008
Bottom of Daewoo fridge freezer freezing up and pools of water on floor
your drainage hole in the back panel has become clogged.. and what was condensate during the free/thaw cycle of frost free systems, is not draining out, but down.. then refreezing.
look at the back panel, about 1/3rd of the way up.. there is a full width "V" shape and smack bang in the middle will be a drain hole.. linked to a pipe that takes the water to a cup container that sits on top of the compressor, which is warm, enough to help it evaporate.. I use some cheap pipe-brushes from the local cheap-store where the brush is only about the thickness of my little finger.. clear that pipe properly from one end to the other, and your problem will evaporate... like the water.
Apr 24, 2017 | Daewoo Refrigerators
Sony KDL-V32XBR1 that is giving me a High Temperature Warning
Check the tv is not against a wall and the air vents are not clogged with fluff. A flat screen tv expensive to repair.
Dec 24, 2014 | Sony KDL Televison & Video
I just bought a 1994 suzuki RF900, i was told that the previous owner purposfully drained the oil to have some minor damage looked at. So, naturally I tried putting oil in her and it all leaked out th
It does appear to me that the crankcase must be holed somewhere. That is the moist likely reason the previous owner drained it (or rather it all ran out). I would have a good visual look at the crank case to see if there is an obvious hole. If it is damaged then it would obviously need a new crank case but first, take the fairing off and have a look.
Aug 05, 2014 | 1994 Suzuki RF 900 R
Hi Have a problem with a whining noise in the drive train on daewoo lanos it gets louder when turning right and quitens down when back to the left. where do I start looking???
Whining could fit so many categories...
Do a visual inspection of the complete braking system, also, while the wheels are off the ground, check for excessive wheel bearing clearance. Wheel bearings make a whining/growling sound when really getting bad. The inner and outer CV Joints should also be inspected for signs of leakage, looseness. You'll have to view both sides of the CV Joints to identify any lack of movement on the inside, while having someone rotate the wheels back and forth.
If you hear the whining when sitting still, it's your power steering or your transaxle requiring maintenance.
EASY OUT: Get a free brake estimate from a local shop and you may get luck and identify the problem while there!
Oct 01, 2013 | Transmission & Drivetrain for Daewoo...
Why is ice building uo in the draining hole on my ge side by side refrigator freezer part model no GSH25JSTA SS
Some refrigerators are just prone to water freezing in the drain opening. Some are caused by the refrigerator not being properly leveled and the water begins to freeze as a pool of condensate on one side until it reaches the opening it freezes over. Most are cause by gunk that accumalates in the turns as the water drain down to the tray below the refrigerator and about the only way to clear it out is to force a soft cord down through the drain line until it reaches the pan below the refrigerator. More on this page=> Leaking Refrigerators! In some extreem cases you can make a heater for the drain opening by twisting copper wire around the defrost heater element and place the other end of the copper wire into the entrance of the defrost drain opening. The heat from the defrost heater will follow the copper wire to the opening and warm the area during each defrost cycle. In most cases the gunk is somewhere in the drain line and once you clear that out you should not have the same problem for a long time. I am here if you have questions Thanks Sea Breeze
Apr 10, 2013 | GE Refrigerators
AMANA FRIG MODEL TJ18MW KEEPS FREEZING INSIDE THE EVAPORATOR DRIP TRAY. HAS NEW DEFROST TIMER AND DRAIN TUBE HAS BEEN CLEANED SEVERAL TIMES. POUR WARM WATER DOWN THE DRAIN TUBE AND IT FLOWS
Thats an old problem,Haven't seen one of those in a long time.The Styrofoam block that sits between the refrigerator and freezer has become saturated with moisture which is freezing around the drain tube and causing the drain tube to freeze up.You can either replace the block part number R156842  $80 if it's still available,or you can cut a piece of solid copper wire no insulation,wrap it around the heater(the black rod that runs anlong the bottom)a couple times and then run the other end down into the drain tube to transfer some heat into it to keep it open,it's an old trick but it works perfectly,just don't run the wire all the way through the drain.only through the middle carefull to keep it away from the plastic tube.
Sep 24, 2009 | Refrigerators
Need to check transmission fluid . It is a sealed transmission on a 2000 Daewoo Nubira
you will have to raise the vehicle. Look on tranny. You will see two plugs, a lower side drain plug and a higher side check/fill plug. Remove higher side plug, stick your finger in the hole. If you can feel the fluid at top of hole, then it is full, if not, then you will have to add some which is always the tricky part.
Aug 07, 2009 | 2000 Daewoo Nubira
Where does the water come out of a Daewoo DWB-126CH Air Condition
I am not sure what this unit looks like.Is suppose to be like through the wall unit?Or is this one of those new styles that sit on the floor?If so then you will need to run a drain from it.
Apr 05, 2009 | Daewoo Heating & Cooling
Water is building up in the bottom of my side by side freezer and freezing.
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
May 07, 2008 | Freezers
Water leaking frigidaire frs23h5as
yes remove the rear panel in the freezer where you see the drain hole. Clear the ice from the drain hole. It will take a while for the water to start to drain because the ice is deep in the insulation. A small tube is helpful to draw some hot water in and stick in in the drain hole and squirt the hot water down in the hole.
Nov 25, 2007 | Frigidaire FRS23H5AS Side by Side...
Daewoo DWC063R Air Conditioner Logo
329 people viewed this question
Top Daewoo Heating & Cooling Experts
Tim Whalen
armandog07
armandog07
Steve
Are you a Daewoo Heating and Cooling Expert? Answer questions, earn points and help others
