Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
Anonymous Posted on Oct 15, 2011
After scanning documents I then cannot edit the docuuments as there are in PDF format any advice?
Anonymous
Level 3:
  • Master 1,216 Answers
  • Posted on Oct 15, 2011
Anonymous
Master
Level 3:
Answers
1216
Questions
Helped
308060
Points
3630
What are the settings needed to scan documents and save them to my computer?
Dear
you can choose the document size.scanning resolution.color. and the format on which you want to save.ie. jpg.bmp.pdf etc.
also you can choose multiple scan option to make a multi page pdf file. there is another option ocr. optical character recognition. through which you can scan aword document to open and able to edit in ms word application.
these are few.
thanks.
2answers
How to change scanning from picture to pdf
once you have scanned the picture and saved it . right click on the picture icon. click edit. it should take you into a editing tool like paint . then click file . save as and then the bottom option you can change it to save as a pdf or png or jif, anything your heart desires
6answers
Unable to convert into a Word document. It just opens a blank document. What is wrong?
The easiest way to convert a word document to .pdf is to simply right-click on the file to see if there is an option to "convert to .pdf"., then left-click on that option.
Hope this helps. :)
1helpful
Can't edit a scanned document
What format did you save the document in? Different scanners use different default formats.
Open the document and try "save as" a .pdf file,then you have a chance of editing it with any of the freeware pdf editors you can google and download.
It's also possible to import it to Office Word and edit it there,if you have the pdf plug-in for Word.
The drop down menu does not give the option to have the picture scanned/saved jpg format which is necessary for certain sites such as shutterfly
Please follow the steps below to scan and save a Multi-Page PDF with Epson Scan.
1. Launch Epson Scan from your START, (ALL) PROGRAMS, EPSON SCAN.
2. If prompted, select your scanner model. Epson Scan will now launch.
3. Click the drop down arrow next to SCAN, select FILE SAVE SETTINGS.
4. Select PDF for IMAGE format. Click OK.
5. Click SCAN. Click OK to proceed (if prompted).
6. Once the image has scanned you will be prompted to click ADD PAGE or DONE.
7. Click ADD PAGE to scan more documents.
8. Once you have scanned all your documents, click DONE.
9. Your documents will now appear in the EDITING PAGE window. Click OK.
10. The multi-page PDF is now created.
3answers
Want to scan in a text document and edit it in microsoft office I have a epson Dx8450 scanner
you need to see if your scanner has any OCR software. If it does it needs to be scanned and processed through it to create a document you cane dit.
I have a HP Photosmart 6180 series printer. I want to know how to scan multiple document of several pages or more and put into one file? Whenever I have scanned in the past, I have only been able to put 1...
To scan documents, you must choose the PDF scan. Need to figure out how to choose to scan as a PDF. That's in the software or scan buttons. In that setting, there should be a choice of single or multiple scans. After the scans, you choose finish and the program should show you a PDF document and then save to a folder of your choice.
32helpful
Setting PDF as default scan setting on Canon Imagerunner 3035
Additional Functions (hardware button on the panel)
Communication Settings
TX Settings
Scroll down to 2nd page
Edit Standard Send Settings
File Format: PDF
Scanning Mode: Black 300dpi
I want to scan a form and save it, and be able to fill in the blanks later. I can save it as a pdf document, but can't edit it.
When you scan it, the original manufacurer's software should allow you to save it as a Word document or some other editable format. PDF, JPG, TIF, and other image formats probably won't work.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
