Question about Vizio L32 32 in. LCD HDTV
Vizio L32 HDTV 10A - Won't Turn On
Unit won't turn on at all. There is a faint yellow blinking light in the far right next to the power switch. Have unplugged several times with no luck for a reset. Vizio is telling me the "bulb must have burned out" and gave me the number for Repair Solutions. Unit is 2 years old. Can anyone help me? turns on and off by itself. when it's on can't turn it off by remote or tv on/off switch? won't turn on by remote or tv on/off switch?
  • 4 more comments
  • Anonymous Sep 23, 2008
    Exact same problem! Is there a solution?
    exact same problem! Any ideas?
  • kirganamily_ Oct 16, 2008
    same problam help would be great
  • Anonymous Oct 20, 2008
    i have the same ?"?">:"+#$ problem
  • Anonymous Feb 16, 2009
    My light doesn't blink and my unit is about three years old. Is it time for a new tv? Probably won't be a Vizio based on reliability.
  • Anonymous Mar 27, 2014
    Part number, 10223450045
  • 51 Answers
Bad capacitors in the power supply. Open it up and look for swollen electrolytics.
Posted on Sep 22, 2008
I had the same problem when my L32 was only 9 months old (bought it Oct-06). Vizio sent someone to replace the motherboard because it was still under warranty. They didn't give me any run around, so I think it's a common problem. The TV worked fine until 2 days ago. Now my digital tuner isn't working at all. I have a call into Repair Solutions, their out-of-warranty service provider. 800-732-0796.
Posted on Oct 23, 2008
5 Suggested Answers
  • 34 Answers
SOURCE: Vizio L32 HDTV 10A won't turn on
I would have the Power supply replaced
Posted on May 22, 2008
  • 34 Answers
It could be a inverter board I would try to replace that first
Posted on Jul 24, 2008
SOURCE: tv Vizio VX37L HDTV 10A
Normally new screens run about 100.00 less than a new tv costs and then you have to get it installed! There is now easy way around it. You would be better off just to get a new one>
Posted on Jul 19, 2010
eagle338
  • 4889 Answers
SOURCE: I have a vizio l32
Fter it goes off do you have dull glow on the screen or faint picture when you focus a flashlight on the screen? Please provide this info so that I can tell you what the problem is and how to fix it.
Posted on Jul 05, 2011
No picture no sound on a Vizio HDTV10A. The green light comes on then turns to amber after a couple of seconds
your Main board went bad, common issue with these units. Need to be replaced, in tv land it called main board in computer world mother board. your unit has only two boards power board and that is good cause you get a amber to green to amber led. good luck Vizio field tech
Feb 01, 2013 | Vizio 32" l32 hdtv 10a high definition...
Sound no picture
You have a backlight fault, to verify this, dim the lights in the room. Turn on the set and shine a bright light on the screen. Do you see a faint picture?
Jan 27, 2013 | Vizio L32 32 in. LCD HDTV
No picture or sound and tv won't turn off
Check and replace its main power regulator board as card basis.
Sep 21, 2012 | Vizio L32 32 in. LCD HDTV
Vizio e320vl light changes from yellow to whioe and diplays
I've seen that problem before and for this person it turned out to be a bad ground on the outlet they were using. I've also seen waiting for it to turn it self on after its on off fit sometimes works.
Jul 22, 2012 | Vizio L32 32 in. LCD HDTV
47"Vizio model #XVTSV Led LCD
this is the only way to get rid of the orange light: l3_3_in_hdtv_lcd_television_412611.jpg
  • Connect
  • reset
  • Blurr
  • installation
  • trouble
  • settings
  • service menu
  • set
  • channel
  • parts
  • instructions
  • troubleshooting
  • remote
  • connection
  • drivers
  • blue
  • repair
  • manual
  • bug
  • CODES
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by avatar1.jpgmeg_car on Jul 08, 2009
Vizio TV Repair Power supply troubleshooting Picture problem Sound problem
  • Service by: avatar6.jpgmjsazon
  • 5 Stars
  • Email
Solutions (2) Best Solution That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
+ Add a comment
remove all screws on the back of the tv, carefully pull off back cover. you will see two circuit boards one on the left (Power) and one on the right (Video) on the Video board there is a small plug on the right side with a yellow, white and red wire going into a small white connector. the red wire is what controls the orange light on the front. now that the plug is pulled turn it over and you should see a small white plastic piece that holds each metal connector on the end of the wires in. pry this piece of plastic up for the red wire and pull at the same time, the wire will come out of the connector. now tape the metal connector with electrical tape and tuck it behind something or tape it to the chassis. plug your connector back in. put the rear cover back on. now your tv will only show the vizio logo in white when you have the power on. If you wish to disable the logo for both orange and white just disconnect the white plug completely.
May 16, 2011 | Vizio XVT473SV 47 in. LCD HDTV
I have a Vizio hdtv 32'' lcd the power button is yellow, when I turn the tv on the button turns green but thats all that happens no pic or sound the model is Vizio L32HDTV 10A
I would guess the power supply went bad. The Vizio parts store sells the replacement for $82. Cheap fix for a decent TV.
Replacing it only requires a moderate mechanical skill. Removing the screws from the case is the hardest part. Remember to unplug the TV before you attempt this repair, or contact a local repair shop. They may only charge a small fee to install it for you.
Sep 13, 2009 | Vizio L32 32 in. LCD HDTV
Jul 23, 2008 | Vizio L32 32 in. LCD HDTV
Vizio 32 does not turn on
The tv not not power 0n dead set,1 ic blown out stby sw,how I can fix the board.Thank you.
Jun 21, 2008 | Vizio L32 32 in. LCD HDTV
I bought my 42" plasma Vizio 17 days ago and this problem just happened to me. We were watching and it just went off and it won't come back on. The tv clearly has power as the yellow light is on, but this tv simply won't come on. I called Walmart to verify I could return (I can) and they said they have two others that were returned sitting in back. I imagine this is going to force Vizio to do something soon, I can only imagine how many of these things are going to start failing in the years to come.
May 22, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
1,215 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
