Televison & Video Logo
Tyrrell young Posted on Oct 15, 2011
I. Have a panasonic DVD recorder with Freesat HD tuners built in. After a power down at the house the recorder shows F5 108 on the display and the TV screen shows NoDignal. Does anyone have any suggestions for fixing this. I have tried unplugging the box and plugging it back in to no avail.
Lee Cresswell
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 22, 2012
Lee Cresswell
Contributor
Level 1:
Answers
Questions
0
Helped
151
Points
0
I had the same problem. The display is simply showing that the unit is tuned to Freesat channel 108. I connected a SCART cable (rather than HDMI) and was able to get an output. I am planning to try a replacement HDMI cable as the video quality is obviously much better than with SCART. I hope this proves to be the problem rather than there being a bigger issue with the box itself. I hope this helps...
4 Related Answers
JoRIck
Rick
  • 50 Answers
  • Posted on Mar 20, 2008
SOURCE: DVD SETUP
Quick answer, You can't record HD on a regular DVD recorder. It will only record in SD (standard) format.
Anonymous
  • 196 Answers
  • Posted on Oct 12, 2008
SOURCE: record and watch different channels with freesat
I believe that the Humax can only output 1 channel and because it has no built in hdd and twin channel capabilty that is all you can record 1 channel (unlike sky +/sky HD) so that means also that unless you watch a different source (like the picture from your aerial (terrestial channels)) you are stuck with having to watch the channel you record
Anonymous
  • Posted on Nov 05, 2008
SOURCE: I have installed a new
Took advice from a work colleage and have managed to sort it
Anonymous
  • 6 Answers
  • Posted on Apr 28, 2009
SOURCE: Will this DVD recorder work with Verizon FiOS?
6200_stereo_tv_vcr_dvd.jpgThis is the setup for the 6416 and the vcr.
We have a Freesat Panasonic Blu Ray recorder DMR-BS750 Which will not record BBC1 since it went HD. We can record BBC2 HD and most other channels.
It's possible that your Freesat Panasonic Blu Ray recorder DMR-BS750 may not be compatible with the specific HD format used by BBC1. Here are some troubleshooting steps you can try:
Check that your Freesat Panasonic Blu Ray recorder is updated with the latest firmware. An outdated firmware can cause issues with recording.
Check if the recording schedule is set up correctly for BBC1 HD. Make sure that the start and end times are accurate and that the program is not set to record in series.
Try resetting your Freesat Panasonic Blu Ray recorder to its factory settings. This will clear any possible software errors and may help to resolve the issue.
If none of these steps work, you may need to contact Panasonic customer support for further assistance. They may be able to provide additional troubleshooting steps or recommend a firmware update or other solution.
It's also worth noting that some broadcasters may use proprietary or non-standard HD formats that are not compatible with all devices. If this is the case with BBC1 HD, it's possible that your Freesat Panasonic Blu Ray recorder may not be able to record this channel.
Panasonic dmr-bs850eb Freesat has lost bbc1 Channel 101 after the recent HD upgrade - can it be fixed?
Sorry no answer but can confirm I have the same issue with a DMR BS750 (same machine smaller hard drive ) connected to a Panasonic TX-L37G10B. DMR no BBC1 but BBC 1 ok on the TV have you had any luck with an answer?
[email protected]
Will the Panasonic DMR-E30 DVD Recorder replace my STB to receive the digital free to air stations on my tv?
Only if it has a built in digital tuner, and, if it does, the digital is only SD (standard definition). If not, you would still need the set top box to receive HD (you could connect the box to the DVD recorder (for HD and/or SD) as required if you wish to record channels). Most set top boxes have both SD and HD channels in their tuners, so it would most likely be the next best option if your DVD recorder does not have a built in digital tuner. You can check your DVD recorder's on screen setup menu to see if digital services exist within it. Either way, keep your set top box just in case.
2helpful
When connected to the Panasonic DVD player I get a message when on One HD and any channel above that - "Unable to decode HD". How can I connect to these channels through the player?
You can't, without an external HD set top box connected via the recorder's inputs. HD is not a standard digital tuner format for this or any model Panasonic DVD recorder that I am aware of. Panasonic do not offer a way for the user/owner to skip the HD channels (which cannot be decoded) in these units. You can only skip analogue channels in VCRs/DVD recorders (which feature an integrated SD digital/analogue tuning system) - stupid really. It just means you need a separate box to get all the available HD channels through the unit.
Yes, 7mate (channel 73) is HD (but it isn't specified on their website or in the EPG) as is Gem ( channel 90) and of course One HD.
I assume your machine has a built in SD digital tuner.
I have DMEZ 47V DVD recorder/VCR combo and panasonic digital/ HD tv...when I set up to pre record the equipment seems to accept the information ok but when i try to playback all i get is ..."cannot...
The reason for this is simple; the built-in digital tuner does not support HD, only SD. You cannot fix it, at least not economically where the recorder combo is concerned. But you can obtain a separate HD set top box, and connect the outputs of it to the inputs of your combo if you really want to record HD channels. It's crude, but cheaper and easier in the long term, and it doesn't damage your machine.
1helpful
How do i connect my samsung dvd recorder sh853m to my free sat box? Also is it possible to record a channel from free sat onto my samsung recorder while also watching a different free sat channel.
If it's a Standard-Definition (SD) FreeSat box then a SCART cable would be the normal method of connection to your DVD recorder. This would connect to the SCART/EXT OUT socket on the back of the FreeSat box and the SCART/EXT IN on the DVD recorder. However, this depends on whether your FreeSat box has multiple SCART outputs and whether you are using a SCART cable to connect to the TV.
If there is no spare SCART output socket on the FreeSat box, then you need to use an alternative connection which is common to both devices, i.e. co-axial, and make sure you are connecting from an OUT socket on the FreeSat box to an IN socket on the DVD recorder.
If you have a FreeSat HD box, then you need to connect it to the DVD recorder using an HDMI cable or another cable type that will carry an HD signal.
You will only be able to record from a different Satellite channel if you have a Dual LNB with 2 feeds to the FreeSat box. The LNB is the receiver that attaches to the arm on the satellite dish. You can determine whether you have a Dual LNB as you will have 2 cables from the Dish to the FreeSat box. They may be joined as one cable, but there will be 2 F-plugs (threaded co-axial plug) on each end.
If you don't have 2 cables then you will only be able to record the same channel as you are watching. To record another channel, you need a FreeSat box that supports this feature and each channel needs also a separate feed from the dish.
Hope this helps. If you need any further assistance please post back with the brand model number of your FreeSat box and details of the connections you are using between the FreeSat box, the TV and the DVD recorder.
Regards,
BElectric
1helpful
3answers
I GET TO THE WINDOW TO PROGRAM A RECORDING BUT FOR CHANNEL SELECTION I ONLY GET L- L-2 OR L3 I NEED TO BE ABLE TO SELECT THE CHANNEL LIKE 6 THIS IS A NEW HD TV. I AM ABLE TO PLAY EXISTING SHOW ON THE DVD...
Hi.
You will need to connect an antenna and program channels to internal tuner if you want to use the built in tuner.
It is not clear if your problem is with the HDTV or with the DVD recorder.
Both have an internal tuner, and both can tune channels , L2 and L3 are the input lines used when you connect for example to an external receiver.
Regards.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
