Question about Frigidaire ATF6000ES Front Load Washer
Washer skips the spin cycle
My washing machine skips the spin cycle most of the time, which means the clothes come out soaking wet. Is this a failure of the timer? Motor speed sensor?
  • Jerry Goggins Sep 22, 2008
    Some of the water drains out (the pump is running OK, which I previously fixed). Is that a significant point here?
  • Jerry Goggins Sep 25, 2008
    I replaced the timer, but the machine still skips the spin cycle. Also, the drain pump removes some of the water, but there is still a lot of water in the drum when the cycle is completed. The water also has a lot of soap in it. What could this be?
  • 116 Answers
Does it drain any at all? Do not think its the sensor - this would give a fault - could be the timer or motor control. If its the timer - maybe just a bad contact or bad relay on motor board
Regards
Posted on Sep 22, 2008
  • D Clare Sep 26, 2008
    For many machines the spin circuit is not the same as the wash circuit such that the circuit for the spin circuit may be open - this may be the harness or the coil in the motor. Spin opposite to the normal wash direction. Need to isolate and test motor.
    Regards
  • 13,433 Answers
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
My clothes are soak and wet after the spinning cycle ends
Could be a gearcase problem or a motor coupler problem or a clutch problem .Best off to call a reputable service company such as Sears.
Feb 06, 2010 | Washing Machines
When the cycle is done my clothes is still soaking wet
Hello becca_m2012 ,
Is the machine a FAV6800A or FAV9800A. If it is one of those models are you failing in Spin Cycle of the Wash Cycle with a dC or Uc error code to the display? Lets nail down the model number and I will try to point you the repair path......Rich
Nov 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Jan 07, 2009 | LG WM-1832C Front Load Washer
Machine won't run the spin cycle
It is most likely a defective speed control or a defective timer. Pull out the timer and clean all metal connections first and if it doesn't work then that is the cheapest part to replace first and see if it is causing the problem. Loose connections or bad wiring might be a possibility as well.
Sep 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Soaking wet clothes
Burly Bob,
Is this the same model as listed by the previous poster? If so, does the washer ATTEMPT to go into the spin cycle? That is, does the timer advance to spin cycle properly, and can you hear the transmission or drive motor engage?
May 31, 2008 | Kenmore 22422 Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
