Question about D-Link High Speed 2.4GHz (802.11g) Wireless CardBus Adapter for Apple® PowerBook® [ DWL-G650X ] (114868)
WiD-Link 802.11g/2.4GHz I cannot link to Internet .Should there be a second CD to set it up? All I had was a manual cd.
  • 600 Answers
There are a few pitfalls here, first have you accessed the D-link from safari?(try hhtp//192.168.0.1) did you set up a password? if so re do it and make it 13 letters long (the software autofills your password to make up 13, the default infill varies but only the correct one will work! just add anything to make up the total, even As) try this and get back to me
Posted on Sep 04, 2009
I lost the CD for this router. Is there a way to install the router?
All the CD does for you is provide a wizard-like interface. You can still set it up manually.
Connect your computer to one of the wired network ports on the router (not the WAN port - that's the uplink to your Internet feed). Use your web browser to go to the router admin page. The default address for D-Link products is usually http://192.168.0.1 and the default username/password is admin/admin. If you've ever changed the default password, use the one you selected instead. If you can't remember it, you can reset the router to defaults by holding the reset button for about 10 seconds while powering it on.
Once logged in, there are various settings you might like to tinker with but mostly the defaults should be okay. It's too much to list here. Check the D-Link site for details. There is a user manual here.
If your Internet feed and computer are plugged in and the router is powered up, your computer should get an internal IP address in the 192.168.0.xxx range from the router. Use IPCONFIG from the command line to check. You should now be able to browse the web.
Feb 18, 2011 | D-Link Wireless N 150 Home Router 4Port...
I dont have the d-link cd
to use a wireless router you never need a driver cd... connect your computer to the LAN port of the router using an ethernet cable...check wat is the default gateway ip address... Type the default gateway address in address bar of internet explorer... you can see the user interface of your router... you can configure the settings manually...
Aug 07, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
How to instal printer on dilink dir-888
i 1 D-Link DIR-855 User Manual 0
Section 2 - Installation
If you are connecting the router to a cable/DSL/satellite modem, please follow the steps below:
1. Place the router in an open and central location. Do not plug the power adapter into the router.
2. Turn the power off on your modem. If there is no on/off switch, then unplug the modem’s power adapter. Shut down your computer.
3. Unplug the Ethernet cable (that connects your computer to your modem) from your computer and place it into the Internet port on the router.
4. Plug an Ethernet cable into one of the four LAN ports on the router. Plug the other end into the Ethernet port on your computer.
5. Turn on or plug in your modem. Wait for the modem to boot (about 30 seconds).
6. Plug the power adapter to the router and connect to an outlet or power strip. Wait about 30 seconds for the router to boot.
7. Turn on your computer.
These instruction are on the CD that came with the router
Here is the start:
D-Link DIR-855 User Manual 13
The DIR-855 includes a Quick Router Setup Wizard CD. Follow the simple steps below to run the Setup Wizard to
guide you quickly through the installation process.
Insert the Quick Router Setup Wizard CD in the CD-ROM drive. The step-by-step instructions that follow are shown
in Windows® XP. The steps and screens are similar for the other Windows operating systems.
If the CD Autorun function does not automatically start on your computer, go to Start > Run. In the run box type
“D:\DIR855.exe” (where D: represents the drive letter of your CD-ROM drive).
When the autorun screen appears, click Install Router.
Section 3 - Configuration
Configuration
This section will show you how to configure your new D-Link wireless router using the web-based configuration utility.
Web-based Configuration Utility
To access the configuration utility, open a web-browser such as Internet Explorer and enter the IP address of the router (192.168.0.1).
Select Admin from the drop-down menu and then enter your password. Leave the password blank by default.
If you get a Page Cannot be Displayed error, please refer to the Troubleshooting section for assistance
Click Launch Internet Connection Setup Wizard to begin.
If you want to enter your settings without running the wizard, click Manual Configuration and skip to page 19.
follow the prompts.
You also can go to D-Iink.com for setup instructions
Apr 20, 2010 | D-Link DIR-855 Wireless Router
I cant get my second alarm to be set on the alarm sound how do i get my second alarm off of radio of cd mode
products.bose.com/pdf/customer_service/owners/og_wrcd.pdf
copy and paste the above link in your internet address bar under a new tab. It is your entire manual.
Hold down ALARM SET and press ALARM MODE. The Alarm 2 indicator flashes. You now have 10 seconds to begin setting Alarm 2. Note: The Alarm 2 indicator must be flashing while setting Alarm 2 wake up time or sound. To set Alarm 2 wake up time, hold down ALARM SET and press either TUNING button
For manual copy and paste this link in your internet address bar under a new tab:
Oct 14, 2009 | Bose Wave Radio
Don't know how to change the time or set stations
Okay, this is an easy one. Here is the link to the owner's manual.
http://resources.jvc.com/Resources/00/00/99/FSUN3105-631.pdf
copy and paste the above link in your browser and you can save a .pdf file version of the owners manual.
Apr 17, 2009 | JVC KD-S550 CD Player
Lights are on all the time
Hi, maybe try resetting it.
You will loose of the settings by doing this, so make a note of the settings by logging into the router. You can do this by typing 192.168.0.1 into your web browser address bar. The username is admin, the password is either password, 12345 or leave it blank. You can save your settings to your pc by logging in too.
Or you can use the cd from your internet provider to set it up once its reset.
To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process. Wait about 30 seconds to access the router. The default IP address is 192.168.0.1. When logging in, the username is admin and leave the password box empty.
Now its reset you can restore your settings, manually, with internet providers cd or by using a back up file.
Let me know how you get on.
Jan 26, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Driver lost
You can go to the store (like best buy or even shopo-ko maybe) and go to their computer section of the store then look in the computer gameing area and it should be in there... :)
Dec 27, 2008 | D-Link 802.11g Wireless Router WBR-1310...
How to fix my wired router
You can try first to reset the router to refrest its settings, To reset it press and hold the reset button for 25 seconds while the power is on, Then after that if you still have the setup CD just run it again to reconfigure the router. If you dont have the setup CD you can manually reconfigure the router to manually configure it I advice you to call Dlink tech support so they can walk you through with the process and reconfiguring the router for internet connection so your 2 computer can have internet via the router...
Hope that helps.............
Sep 12, 2008 | D-Link Computers & Internet
D-link wireless internet
It is always a good thing to start the different peripherals in an order. First, you start your modem. Wait 30 seconds. Then, start the router; wait another 30 seconds; then the computer.
Aug 24, 2008 | D-Link Wireless Cable/DSL 802.11G Router...
Computers & Internet Logo
46 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
