2000 GMC Jimmy Logo
Posted on Oct 15, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2000 gmc Jimmy . I'm going to change the
brian soufane
Level 3:
President:
  • Master 693 Answers
  • Posted on Oct 15, 2011
brian soufane
Master
Level 3:
President:
Answers
693
Questions
Helped
511690
Points
4903
Locate the idler pulley to the left of the crankshaft pulley. The idler pulley bolts to the idler arm. The idler pulley is replaced with the arm because they are sold as one unit.
  • 2 Place a 3/8-inch ratchet driver into the square hole on the face of the idler pulley and pull up on the handle. This releases tension on the Sonoma's serpentine belt. Pull the belt off the idler pulley, lower and remove the ratchet handle.
  • 3 Remove the two bolts that secure the idler arm to the engine block using a socket and ratchet, and discard the old idler arm.
  • 4 Place the new idler arm against the engine block and secure it using the socket and ratchet.
  • 5 Put the ratchet driver into the square hole on the new idler pulley, pull up on the handle and place the serpentine belt over the pulley.
  • 6 Lower and remove the ratchet handle.
  • Add Your Answer
    4helpful
    2answers
    Steering wheel has to much play
    Idler arm and or pitman arm most common.could also be excessive play in steering gear box.Tie rods/center link but usually its my first 2 choices go bad bothe of them idler and pitman common wear parts.
    How do i remove and install the steering gear box in a 1993 jimmy?
    here hope this helps for a 98 model but very similair
    1998 GMC Truck Jimmy - 4WD ' Blazer, Bravada, Jimmy, S10 Pickup, Sonoma VIN S/T Service Manual ' Steering ' Power Steering System ' Repair Instructions ' Document ID: 416283
    Steering Gear Replacement (4WD) Removal Procedure Tools RequiredJ 24319-B Steering Linkage Puller
    Notice: Do not rotate steering shaft after steering column has been removed. Damage to SIR components may occur.
    1. Remove the air cleaner assembly. Refer to Air Cleaner Assembly Replacement in Engine Controls 4.3L.
    3. Place a drain pan below the steering gear.
    4. Remove the inlet and the outlet hoses from the power steering gear.
    5. Cap or tape the ends of the hoses and the gear fittings in order to prevent dirt from entering the system.
    6. Remove the intermediate shaft shield from the steering gear.
    8. Remove the lower intermediate shaft coupling bolt.
    9. Draw alignment marks on the lower intermediate shaft coupling and the steering shaft.
    10. Remove the lower intermediate shaft coupling from the steering shaft.
    11. Raise the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
    12. Remove the steering linkage shield. Refer to Steering Linkage Shield Replacement in Steering Linkage.
    14. Remove differential carrier shield mounting bolts.
    15. Remove the differential carrier shield.
    17. Remove the pitman arm ball stud nut at the relay rod.
    19. Disconnect pitman arm from relay rod using J 24319-B .
    21. Remove the steering gear mounting bolts and the washers from the frame.
    22. Remove the steering gear.
    23. Remove the pitman arm. Refer to Pitman Arm Replacement in Steering Linkage.
    Idler arm LF,idler bracket LF,pitman arm LF,tie rod sleeve LF, inner tie rod LF, tie rod end LF, need to repair
    you will need a pitman arm puller, tie rod separator and a good set sockets(6 point preffered)and some penetrating oil, measure all distances between points before removal,and get the vehicle aligned
    1helpful
    Is a special tool required to remove inner tie rod from relay rod on 2001 Tahoe.? Also what should torque be?
    Relay Rod Removal & Installation To Remove:
    1. Raise and support the vehicle
    2. Remove or disconnect the following:
      • Engine protection shield, if equipped
      • Steering damper from the relay rod, if equipped Note: Use the proper tool in order to separate all the tie rods and the ball joints.
      • Tie rod ends (F) (See: Tie Rod Ends)
      • Idler arm ball stud nut (J) and discard the nut (See: Idler Arm)
      • Pitman arm nut (H) and discard the nut (See: Pitman Arm) Remove the idler arm from the relay rod gm_trk_sub15_idler_from_relay_rod.gif
      • Relay rod from the idler arm ball stud using the J24319-B or other suitable puller Remove relay rod from pitman arm ball stud gm_trk_sub15_relay_rod_rem.gif
      • Relay rod from the pitman arm ball stud using the J24319-B or other suitable puller
      • Relay rod from the vehicle
    3. Inspect the threads on the tie rod ends for damage
    4. Inspect the ball stud threads for damage
    5. Inspect the ball stud seals for excessive damage
    6. Clean the threads on the ball studs
    To Install:
    1. Install or connect the following:
      • Relay rod to the vehicle
      • Relay rod to the pitman arm ball stud
      • Relay rod to the idler arm ball stud and make sure the seal is on the stud
      • New pitman arm prevailing torque nut
      • New idler arm prevailing torque nut and tighten the idler arm and pitman arm nuts; Torque to: 46 ft. lbs. (62 Nm)
      • Tie rod ends
      • Steering dampener to the relay rod, if equipped
    2. Lower the vehicle
    3. Check the wheel alignment
    4. Test drive the vehicle to confirm the repairs
    I took my 98 gmc jimmy into have an alignment done on it and they told me I needed to replace a bunch of parts first. I replaced everything except the pitman arm is there a place I can go to online to...
    You might want to try your local library. Many libraries have do it yourself books online. The pitman arm is the "bone" type part from just below the steering box to the rods. each end is a ball joint. Just a matter of removing nuts from the pitman arm and prying them off. They may need a little persuasion to come out they they will eventually. Good Luck.
    How to replace a idler arm and pitman arm need to replace it on my 98 gmc suburban 4x4
    You will need the proper tools to remove them which can be rented at auto parts stores. The pitman arm has to pulled off with an pitman arm puller also have to drop steering box I believe to change it. I know we did on my 1996 Tahoe the idler arm can be seperated with a front end fork also available at parts store. You just drive it between the idler arm and tie rod after removing castle nut and cotter pen.
    1helpful
    3answers
    How do you replace the pitman arms on a 99 surburban
    You will need a pittman arm puller and a tie rod puller to remove this item. Some shops such as NAPA & Auto Zone rent these tools
    8helpful
    How to change the pittman arm and idler arm on a 1999 S10 Chevy Blazer 4x4?
    Pitman arm requires a pitman arm puller, and a tie rod seperator or "pickle fork". Remove the cotter pin on from the joint on the pitman arm and center link, then remove the nuts from both ends of pitman arm. Use the pitman arm puller to remove the pitman arm from the steering gear, then use the tie rod seperator to remove the end from the center link. Reinstall and retighten nuts, do not leave out the cotter pin.
    Idler arm will require tie rod seperator. Remove the cotter pin from the end at the center link, use the tie rod seperator to seperate the joint there. Unbolt the idler arm from the frame, and remove. On reinstalling remember to install a new cotter pin. It would be best to have the front end alignment checked after replacing these parts.
    2answers
    I HAVE A 1998 GMC JIMMY 4X4 .. IT SEEMS AS THOUGH WHEN I PUT IT IN 4 WHEEL DRIVE IT PULLS ALL OVER THE ROAD . IT KINDA FEELS LIKE IM DRIVING AGAINST SOMEONE .. I HAD MY UPPER AND LOWER BALL JOINTS DONE AND...
    inspect frt end tie rods,idler arm,pitman arm,inner tie rods,steeringbox,control arms upper and lower bushings.1or more of these parts could be worn
    Top GMC Experts
    ZJ Limited
    ZJ Limited
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    john h
    Are you a GMC Expert? Answer questions, earn points and help others
