Question about Optoma EzPro 739 Multimedia Projector
No power to optoma ezpro 739
I open my projector up to clean it and when i put it a back and plugged it in the was no power going to the projector (no lights on or flashing) and how do u take the top and bottom covers off.
  • 3 more comments
  • papinice31 Sep 23, 2008
    Thanks but tired that and even put in a new bulb still nothing!!
    power cord is fine. There is a fuse inside where is it located and how do I check it? make revision for all connector inside. what do you mean.
    ok from what i can access buy taking the front and back panels off everything is connected I have I can't remove the top or bottom covers to check further you also mention a fuse is there a fuse located inside the projector?
    thanks
  • papinice31 Sep 29, 2008
    marsrover I guess you havent found the manual yet let me know what you find.. ANY ONE out there that can add some input please do!!
Hi,if you still have the optoma ep729 or a spare lamp i am interested on buying it. ozzyris7@hotmail.com
Posted on Jan 17, 2010
  • 682 Answers
Check the door(cover) of lamp not closed firmly open it and close it firmly.
Posted on Sep 22, 2008
  • 3 more comments
  • mohamed eltoni
    mohamed eltoni Sep 23, 2008
    check your power cord-or blown fuse inside--make revision for all connector inside.
  • mohamed eltoni
    there are many connectors connect the electronics board with each other and with the other parts of the projector----confirm that all connector are connected in its place and nothing loose or disconnected.
  • mohamed eltoni
    ok--it is the time for service manual befor i can answer your question-and i will search for it and inform you when i find it.
  • mohamed eltoni
    do not mention.
  • mohamed eltoni
    mohamed eltoni Sep 29, 2008
    sorry i did not find the manual.
Over temp
The heat is generated by the lamp whether or not there is an input signal. If the unit seems to be hotter than normal, check the air input grill and be sure that it is celar of dust and debris. You can also gain access to the fan and be sue that the fan is clean.
Dan
Nov 17, 2008 | Optoma EzPro 739 Multimedia Projector
Projector has no power
close lamp compartement door firmly because door switch can disconnect power from projector if not closed firmly.
Aug 27, 2008 | Optoma EzPro 739 Multimedia Projector
LCDPROJECTOR LB10SVU POWERS UP BUT LAMP DOES NOT COME ON. REPLACED LAMP BUT DID NOT HELP.
Hi WITT
This sounds like a Ballast problem - (lamp's powersupply)
This would need replacement , rather than repair as repairs to a Ballast almost always has a come back problem a couple of months down the line.
Apr 21, 2008 | Optoma EzPro 739 Multimedia Projector
3M MP8625, temp warning comes on straight away
Hi there
This is normally a faulty Mainboard.
Must warn you that it is quite expensive to have replaced. Try and find a repairer rather.
Apr 15, 2008 | Optoma EzPro 739 Multimedia Projector
My projector has vertical lines on display; what are possible causes of lines. Projector was dropped, I reinstalled lamp, lines went away for a while, now they are back.
Hi there
This is a common problem on a faulty Mainboard of a Projector.
Not much you can do about it except repair or replace the Mainboard
Apr 09, 2008 | Optoma EzPro 739 Multimedia Projector
We have an optoma ep739. when you turn the lamp on, a message 'fan failure' comes on. the fan is running at what appears to be a slow speed. the red temp light goes on and then the lamp turn off.
Hi there
Try cleaning out the fan by blowing it out with a compressor. Most of the time this is only caused by dust.
If the problem stil occurs , try spraying it on the inside with a lubricant.
If the problem stil occurs you will have to replace the faulty fan.
Very cheap to have replaced.
Apr 02, 2008 | Optoma EzPro 739 Multimedia Projector
Optoma color wheel issue
Hi Brad
You'll have to go into the service menu and check if all the colours are showing the same percentage.
We normally set all of them on 50%
No Power
me too anyone find a fix?
Dec 09, 2007 | Optoma EzPro 739 Multimedia Projector
Open Questions:
Optoma EzPro 739 Multimedia Projector Logo
502 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
