Question about MSI KM4M-L Motherboard
MSI motherboard model 6734 AGP interface
How do I know what standards (i.e. 1X 2X 4X 8X) on the AGP interface of the model 6734 will be supported ? I just don't know what AGP card to get.
I would like to get a decent graphics card, and one that the motherboard will work with, but I don't want to break the seal on an anti-static bag only to find out it won't work with the model 6734 board. Will an 8Xbandwidth card work in a 1X slot, and can the board support 8X ?
Thanks,
Don
CPU:
AMD Athlon™ XP Processor 2800+ (2.083GHz) QuantiSpeed™ architecture
Operating System:
Genuine Microsoft® Windows® XP Home
Monitor Bundle:
eMachines® 17" eView™ 17f2 Monitor
(16" Viewable, 0.27mm dot pitch)
Chipset:
VIA KM 400A2 chipset
Memory:
1Gig DDR (PC2700)
Hard Drive:
120GB HDD
Optical Drive:
48x. Max CD-RW Drive; 16x Max. DVD Drive; 3.5" 1.44MB FDD
Video:
VIA S3 UniChrome™ 3D Graphics (1 AGP slot available for upgrade)
Sound:
6-Channel Audio
Network:
10/100Mbps built-in Ethernet
Modem:
56K ITU v.92-ready Fax/Modem
Peripherals:
Premium Multi-Media Keyboard, 2-Button Wheel Mouse, Amplified Stereo Speakers
Ports/Other:
6 USB 2.0 ports (2 on front), 1 Serial, 1 Parallel, 2 PS/2, Audio In & Out, 3 PCI slots (2 available)
Dimensions:
7.25
  • DPD1 Sep 23, 2008
    Thanks Ugifer for your answer. It was spot on and solved my problem.
    Best Regards,
    Don
    Scholar:
  • 55 Answers
Looks like your motherboard is a MSI KM4AM-L detailed here:
http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=572&maincat_no=1
If so, then it has an AGP slot which will run at 4x and 8x.
Remember to check the BIOS settings after you install it to make sure it is set to 8x, if that is what your card will take.
Posted on Sep 22, 2008
Hi... Can you help me in the software of my pc the Video Controller (VGA Compatible) It was gone when I was reformat the PC. Motherboard Manufacturer: Company Name Micro-Star International Motherboard...
Field Value North Bridge Properties North Bridge SiS 661FX Revision 11 Memory Timings CAS Latency (CL) 2.5T RAS To CAS Delay (tRCD) 3T RAS Precharge (tRP) 3T RAS Active Time (tRAS) 5T Memory Slots DRAM Slot #1 256 MB (DDR SDRAM) DRAM Slot #2 512 MB (DDR SDRAM) Integrated Graphics Controller Graphics Controller Type SiS 330 Mirage Graphics Controller Status Enabled Graphics Frame Buffer Size 32 MB AGP Controller AGP Version 3.05 AGP Status Enabled AGP Device SiS 330 Mirage Integrated AGP Aperture Size 64 MB Supported AGP Speeds 1x, 2x, 4x, 8x Current AGP Speed 8x Fast-Write Not Supported Side Band Addressing Supported, Enabled Chipset Manufacturer Company Name Silicon Integrated Systems Corporation
Jul 16, 2010 | Microsoft Windows XP Professional SP2
What AGP graphics card is compatible with AGP
AGP 4X (1.5 Volt)
http://www.firingsquad.com/hw/1719/Iwill_P4S/
Suggest you use a graphics card that is AGP 4X/8X
Example, ( Not an advertisement for graphics card manufacturer, nor website),
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4103516&CatId=318
Jan 14, 2010 | Computers & Internet
Vga card
high resolution is supported by high resolution monitors or LCD no matter what type of Video card are you using so first check monitor compatibility with the resolution
Oct 05, 2009 | EliteGroup K7SOM Motherboard
Compatability
You have an AGP expansion slot for a graphics card.
(Accelerated Graphics Port)
It uses either 1x, 2X, or 4X graphics cards. Since the only AGP graphics cards out there are 4X or 8X, the 1X, and 2X are moot points. (They were also Junk anyway!)
Your AGP graphics slot only supports AGP graphics cards that are 1.5 volts. There are AGP graphics cards out there, that are Universal. Universal in that they will run as AGP 8X, (.8 volts), or AGP 4X, (1.5 volts)
This is an example:
Don't expect to play the high end new intense games with this. I'm afraid you'll have to update your motherboard, processor, ram memory, and a better graphics card to do that.
(Example? XFX Nvidia nForce 680i LT SLI motherboard, Intel Core2 Duo E8200 cpu, Corsair XMS2 PC6400 ram memory, 1GB x2 of them, (DDR2 at 800MHz), and XFX Geforce 9800GTX+, vid card. (Plus OCZ SteathXStream 600W power supply)
This won't break the bank, and will slam some games to the wall!)
Jun 05, 2009 | Intel D845GBV (BOXD845GBVL) Motherboard
Is my MSI PM8M-V AGP or PCI???
Hi there
Graphics support is AGP (66MHz) for 8x/4x mode for that model motherboard.
Thanks for using Fixya!!!!
Feb 01, 2009 | MSI PM8M-V Motherboard
AGP 4x-8x compatability on msik7t turbo
El único manual que pude encontrar es en Inglés, sino que debe contener información de conexión (inc diagrama) que puede utilizar.
Si el vínculo con el manual en la parte superior de la página da problemas, puede encontrar los enlace de descarga para que, en la parte inferior de la página; http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=422&DetailName=New&DetailDesc=741GX-M%20%20&MenuID=0&LanID=8
May 29, 2008 | MSI K7T Turbo Motherboard
Graphics card support to motherboard D845GBV
AGP 2.0 and 3.0 4x and 8x feed with the 1.5v spec. AGP 1.0 1x and 2x was fed at 3.3v. In short, you should be fine.
May 15, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
Recording DVD-RW
Make sure the discs you are using are the same as the ones listed as compatible in the manual:
• DVD-RW ver. 1.1 / 1x / 1x to 2x, ver. 1.2 /
2x to 4x / 2x to 6x
• DVD-R ver. 2.0 /1x / 1x to 4x /
1x to 8x / 1x to 16x, ver. 2.1 / 1x to 8x / 1x
to 16x
• DVD+RW 1x to 2.4x / 1x to 4x / 3.3x to 8x
• DVD+R 1x to 2.4x / 1x to 4x / 1x to 8x / 1x
to 16x
• DVD-RAM ver. 2.0 / 2x, ver. 2.1 / 2x / 2x to
3x / 2x to 5x, ver. 2.2 / 2x / 2x to 3x / 2x to 5x
• DVD-R DL ver. 3.0 / 2x to 4x
• DVD+R DL 2.4x / 2.4x to 8x
Any brand can be used.
Jan 11, 2008 | Pioneer DVR-540HX DVD Recorder/HDD...
VIDEO CARD COMPATIBILITY
All AGP based cards are backwards compatible, so an 8x card should operate at 4x 2x and 1x
however what is important is the voltage of your slot, you can tell by looking at the slot itself,  the AGP slot may have a partition either 1/3 or 2/3rds down the slot, or may have no partition at all,
this slot partition is to prevent you from inserting a card of the wrong voltage.
If there is no partition in the AGP slot then the slot has a switchable voltage, and will automatically switch to the appropriate voltage, (on request from the graphics card AUTOMATIC)
so all you need to check is that the graphics card you buy has slots on the AGP interface that accomodate those on your board
according to the manual
http://www.ecs.com.tw/ECSWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=413&areaid=2&LanID=0
This board has a 4x AGP slot
Oct 09, 2007 | Intel Motherboard
MSI KM4M-L Motherboard Logo
1,010 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
