Question about Kenmore 63942 Dryer
Dryer timer counts off to fast
I have changed with a new timer
    Scholar:
  • 32 Answers
The only thing that I can think of is that you are using a dryer intended for Europe in the US. While they both run on 220V, the timer motor will be specific for the frequency of the country. The US uses 60 Hz. Europe uses 50 Hz.
To keep the explanation simplistic, your timer motor expect 50 electric (frequency) "beats" per second but instead is getting 60 beats per second. Your clock is turning an extra 12 seconds every minute.
Posted on Sep 22, 2008
Does the timer count down on sensor heating
On a sensor drying, timer shows ONLY estimated time to finish. It might add some time, or finish sooner depending on the size of load, fabric, and saturation.
Dec 23, 2014 | Samsung DV5451AEW Dryer
Why doesn't the timer count down? The dryer runs & heats but the Timer doesn't move. I replaced the Timer block but nothing changed. Is this related to a bad sensor?
go bak to 4 prong. why did u change it out? souns lik this isa 220 unit and not a 110? chk the book that came with the unit. lol.
Jul 22, 2014 | Maytag Dryers
The timer starts counting down fast but the dryer does not move
Check the thermistor located on the blower housing. The thermistor should have a resistance reading. At room temperature it should read around 10,000 Ohms. You can test this with a multi-meter. Here is the part to order if you should find it bad.
The part comes with a 365 day, any part, any reason return policy.
Nov 10, 2012 | GE DBVH512EFWW Dryer
My dryer timer counts down to 7 minutes and then continues drying
replace the sensa board and make sure the wires on the sensors are ok
Jun 07, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer will not turn on, i can hear the timer counting down
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 06, 2010 | Crosley CDE6000 Electric Dryer
Kenmore Elec Dryer timer & Heat Element Failed
if you set timer on time dry it will count down but if you have it set on more or less it will not advance without heat,change out the heater and you will be fine
Nov 04, 2009 | Kenmore Elite HE4 Electric Dryer
Microwave timer counts down super fast
try unplugging it for about 15 minutes. if that doesnt work, you might as well get a new one. i fix everything myself for just the cost of parts and i have found that what parts cost for a microwaves, its cheaper just to buy a new one.
Oct 17, 2009 | Sharp R-540DK Microwave Oven
Run A Way Dryer
the timer runs faster or slower in sensor dry that is normal. if your problem is that it counts down to fast and turns off and your clothes are still wet, id say your sensor could be bad or dirty with lint or wax buildup from fabric sheets. i would first try and clean out the filter housing area and the sensor bars. two strips about 4-6 inches long mounted to the filter housing.can clean those with water and a rag. the housing can be cleaned out with a vacuumm. if that doesnt help then your sensor bars can be bad. hope this helps
Sep 17, 2009 | Dryers
My Kenmore drier won't stop now! Perhaps timer isn't working?
Hi there. this is a timer issue. it counts down but, the actual shut off dial embedded in the timer mechanism is damaged for some reason. replacing the timer assembly will correct this issue. there are two parts to a timer. One, it times and last, it initiates the shutoff. the second action is not working properly. to be sure, check the relay before you purchase the new timer.
I have also provided you with a complete manual set that you can access and print out if you would like.
Click here for your manual
Click here for your instructions Guide.
Mar 06, 2009 | Kenmore 84052 Dryer
Timer on dryer counting down too fast
Now that there is a good one. Everything you are saying leads to a control board failure. Did you replace the board yourself, or have someone else do it? I have before gotten a new control board of the shelf, and it be as bad as the one I was replacing. Just a thought. Let me look around and see if I can find some other information, just really sounds like a bad part.
Feb 13, 2008 | Kenmore 62062 Electric Dryer
Kenmore 63942 Dryer Logo
141 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
