Question about GE JE1590 Convection / Microwave Oven
JE1590 light bulb replacement
Hi.  You had posted about replacing the light in the JE1590 microwave oven.  Thanks for posting; yours was the only info I could find!  Could you give some  more detail?  Is there a specific panel to remove to get to it?  Is replacement pretty straight forward, or not?  Is there just one light bulb, or are there more than one?  You can contact me directly at djk104 (at) hotmail.com.
Thanks!!
  • djk104 Sep 27, 2008
    Thanks for the response.  A question: Are you sure that the bulb can be bought at "normal" type stores (as opposed to appliance parts stores)?  I want to avoid taking apart the microwave and then finding that the bulb is one I need to order and have to wait a week to get it.  On the other hand, I don't want to order it from an appliance place for $15 if I can get it at Lowes for $5.  Here's the link to the bulb: http://www.appliancepartspros.com/partse...
    if it is available at "normal" stores, do you know the style or part number?
    Thanks!
    Dan
  • Anonymous Nov 18, 2008
    JE1590BC01 NEEDS A LIGHT BULB REPLACEMENT. CAN IT BE DONE SAFELY AT HOME AND WHERE DO YOU BUY THE BULB.
  • GE Master
  • 9,098 Answers
On this model you need to remove the outer cover.
The bulb mount will be located on the right side next to the side wall of the cooking cavity.
It's above the damper door assembly as shown in the attached drawing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
The bulb should be available at local grocery stores, hardware stores, and places like Wal-Mart and Lowe's.
Posted on Sep 27, 2008
  • William Miller
    William Miller Sep 28, 2008
    Looking at the photo, it does seem like it might be an assembly after all.
    In other words, the bulb may not be meant to separate from the socket.
    So indeed, I would tend to doubt that it would be available commonly.
    It might be best to check with a local appliance parts store or order it from the link you gave.
    The original GE part # is WB36X10131.
Amana Microwave over the stove. Need to replace light bulb. So what is the part number?
If the model number is correct in your post and I assume you are talking about the over the range light and not the cavity light then you need 53001905 halogen bulb, charcoal 53001442 still available
Jan 17, 2015 | Amana AMV5206AAS Microwave Oven
Steamed out the control panel?
Hi!!
Repair and parts for a microwave oven, (exept replacing the light bulb) are so expensive that I recommend just getting a new one. I fixed a couple myself and after one thing comes another one. Better off buying a new one.
Don't forget to rate this post. Good Luck.
May 13, 2010 | Maytag MMV5156AAS Microwave Oven
How to replace the bulb in our GE Microwave Oven,
the outter cover wrapes around unit remove screws, be careful high voltage is present even with power off just replace bulb reassemble
Jan 13, 2010 | GE JE1590 Convection / Microwave Oven
Replacing GE Spacemaker Light Bulb inside Microwave Oven...
Here is the GE download page for your manual. Page 35 of your  manual gives the light bulb replacment instructions.
http://genet.geappliances.com/DocSearch/Dispatcher
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
JE1590
A special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Some folks just use a hammer to tap and loosen the screw, then a small flathead screwdriver can be used to remove the screw, as shown in the photo.
Another creative solution is to use a hacksaw or a Dremel tool to carefully cut a slot in the head so a flatblade will fit it.
Sep 25, 2008 | GE JE1590 Convection / Microwave Oven
Lamp bulb is out
You must remove the outside cover of the microwave to change the bulb.
The light cover inside the microwave should not be removed. It is held in place with contact cement.
For disassembly help see:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The bulb should be available at most grocery stores, home centers, hardware stores, and places like Wal-Mart.
Sep 24, 2008 | GE JE1590 Convection / Microwave Oven
Ge spacemaker
Here is info from another person having that problem on fixya.
I had to go down to an appliance parts shop in PHX to get the lamp after I had taken the microwave out of the corner cabinet and disassembled it. Found the light bulb toward the right front top corner after taking the frame all apart. It was a pain but it's done !! BTW, I'm a female licensed electrician and GE told me over the phone that I would have to call a service tech to come replace the lamp (about $200). I searched the websites for the part number to get the lamp (it wasn't printed on the lampbase), searched for local appliance part stores and found the part number (WB36X10131) to pick it up. The "cavity" lamp cost me $8.65 then the cost of the gas (about 40 miles) to get it but my micro was back up and running before Thanksgiving dinner --just in time to make Lean Cuisine !!! HAHA Thanks for your reply Guru !! Have a great weekend !! Julie
Mar 04, 2008 | GE JE1590 Convection / Microwave Oven
GE Profile JE1590--light bulb
The type of screw attaching the casing is called a Torx Tamper Proof screw. You need a Torx Tamper Proof Screwdriver to remove the screws. These screws and screwdrivers come in various sizes. I think the size you need is T20H.
Nov 19, 2007 | GE JE1590 Convection / Microwave Oven
Ge advantium 120 microwave
It's pretty simple as long as you have an offset phillips screwdriver...
Of course, be sure to disconnect power to microwave and be sure not to touch the new halogen bulb with fingers.
STEP-BY-STEP:
First, remove upper vent panel and remove inner filter (same directions for just replacing inner carbon filter):
Then, remove inner plastic grille (2 screws) and final screw on left side of metal "air duct" - here's where you'll need the offset screw driver (and a little patience!):
Then, you can gently lift the sheet metal panel, find the light housing, squeeze and remove/replace :)
That's it...just replace bulb and reverse for reassembly. Be sure to keep track of screw locations there are various sizes/lengths used.
Doug
May 21, 2007 | GE Advantium 120 Convection/Microwave Oven
GE JE1590 Convection / Microwave Oven Logo
988 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
