Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
BLACK GAP ON RIGHT SIDE OF TV SCREEN
I NOTICED THAT ON THE RIGHT SIDE OF MY TELEVISION SCREEN, THERE IS ABOUT A 3 INCH BLACK SPACE. IT LOOKS LIKE THE PICTURE IS NOT FITTING THE SCREEN. ANY SOLUTIONS? I HAVE DIGITAL CABLE ONLY AND NO HI-DEF TV.
  • Sony Master
  • 5,568 Answers
This is a sign of an aging horizontal deflection circuit. Go through your initial setup menu and see if the set gives you the option to adjust 'width.' This may have enough range to stretch the video to the edge but it will also affect the geometry of the displayed video.
As of now, the component most likely growing old is an electrolytic capacitor in the horizontal circuit that has lost value. It is usually a bipolar capacitor in the range of 4.7 - 33 uFd. It will likely continue and become more annoying and if you look closely, you can probably see that the geometry of the picture on that side is not as it should be; it will often appear 'squashed' together.
Allowing it to just grow may result in the failure of the flyback (a high voltage transformer) and/or the main power transistor that drives it.
Posted on Sep 22, 2008
I run on Windows XP, pack3 and I use a CRT ViewSonic EF70 ... 17 inches The screen is not filled completely with the image from Microsoft Internet Explorer, nor with Outlook Express .... there is about 3...
two things you can do, first right click on your windows screen and look for "settings" this will open a dialog box where you can set the screen resolution. Set it lower and see if your screen is now filled. if that doesn't work go into the monitor setup (buttons on the bottom or side of the monitor) and try to set the verticle and horizontal size, since its only 3/4 of an inch you should be able to stretch the screen to fill up the space.
Mar 11, 2011 | ViewSonic E70f 17" CRT Monitor
Right edge fades to black (Approx 2")
ok! you have defective horizontal linearity check horizontal section then check capacitors! like 180uf 200v or 200uf 200v. the problem is defective capacitors!
Sep 28, 2007 | Toshiba 44NHM84 44" TV
On either side of our screen there is a blank space about one half inch wide on each side. Can you tell me why this would happen?
You could be in 4:3 aspect ratio when you, in fact need 16:9. Look in your menu options for something that says "wide screen" or "full screen." this will change the aspect ratio to fill those gaps!
Please rate if this helped at all :)
Mar 07, 2011 | Westinghouse LTV-46w1 HD 46 in. LCD...
Samsung HPR4272X/XAA has 2 black bars going from top to bottom.
I really do not know there is the "Stuck Pixel Fixer programs" I think that Program Breakdown another IC. For this issue is absolutely the Plasma display panel have problem. You shall exchange it.
Apr 17, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
How to center a screen?
Horizontal centering is performed in the service menu. Beware! You can mess up a lot of stuff in this menu.
Aug 02, 2009 | Toshiba Televison & Video
Vertical section problem
I have found an fix for this a capacitor 2494 needs to replaced.
Aug 21, 2008 | Philips 27MT3305 27" TV
Sone TV Picture not aligned.
This looks like Pincushion problem. nothing you can do. Only a Trained technecian can do this adjustment to reproduce a perfectly aligned image. It requires a pattern Generator and other tools. call the company tech.
May 10, 2007 | Sony KV-36FS100 36" TV
Shrinked picture of 29 inch television.
It is a pincushion problem. There is a bad cap and or a bad diode in the horzontal section.
Oct 29, 2006 | Toshiba 27A51 27" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
73 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
