Question about Dell Computers & Internet
Dell Flat Screen monitor
Yesterday the monitor began showing the desktop, taskbar and all programs went vertical. It looks as if someone placed it on portrait setting vs the normal reading or landscape setting that it is best to use it on.
There are hotkeys for the graphic display ctrl alt arrow key right turns normal, 90 180 270
Posted on Sep 23, 2008
My computer had not been used in a couple of weeks and when I turned it back on it started beeping and the monitor will come on but cannot see screen
The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Sep 02, 2012 | Dell Inspiron 530 Desktop Computer
The taskbar is upside down and at the top of the screen
On Windows computers, you should have what is known as the taskbar. This is the gray strip that runs across the bottom of your computer and which displays icons for quickly accessing programs you frequently use. The taskbar also shows the "Start" menu, clock and icons for your Internet connections. Sometimes icons do not appear properly in the taskbar. This usually is because the computer is new and hasn't had icons placed in the taskbar manually, or because a default setting is off in the OS properties. Both are simple fixes.
1.Right-click the "Start" icon and select "Properties."
2.Select the "Taskbar" tab in the "Taskbar and Start Menu Properties" dialogue box.
3.Uncheck "Lock the taskbar" and "Auto-hide the taskbar." Check "Show Quick Launch." Since the Quick Launch box isn't available in some systems, you may need to right-click on the taskbar area, choose "Toolbars" and then select "Quick Launch."
4.Navigate to the programs you want to show on the taskbar through the "Start" menu or on your desktop. Right-click the program and drag it to the taskbar. Choose "Create shortcuts here" from the menu that appears. The icon for the program should appear in the taskbar.
Sep 19, 2011 | Dell Latitude 2120 Notebook
Monitor is only showing vertical/horizontal gray/white screen
Your video card has fried unfortunately. If you are familiar with the internal workings of a PC you can open it up and check the power cells on the video card itself, they will usually show signs of damage such as cracking etc. I would have a qualified professional take a look at it. I would recommend www.tigerdirect.com as a starting place for finding a new one
Apr 14, 2010 | Acer AL1715 17" LCD Monitor
My computer screen has a vertical white line running from top to bottom
If it's there all of the time, but you can still see your desktop and programs - chances are it's a monitor screen defect. Dell had this happen on some laptops and was replacing the defective flat panel screens. Borrow someone else's monitor or take it to a friends house that will let you hook it up to their computer monitor. If the problem goes away - then it's your monitor screen.
Jun 26, 2009 | HP Computers & Internet
Screen turned black
your monitor got a hardware problem:
1) the LVDS controler board out of work, only change or repair it could be fixed.
2) if you can see some show like smaller signal detect windows in the centre of screen a very short time (bright flashing one time), this is inverter board damaged or worn lamps, thay all need repair or replace
hope give you some idea. please take a rating let me know how much helped you thanks!
May 20, 2009 | Dell E176FP 17" LCD Monitor
Screen was blinking then when i tried to restart it wouldnt go on
yes there are fix for that.. just replace the blown capacitor in the board...you can replace it with the same value.
Mar 13, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor not working
It may well be dead. Try testing the monitor on another working PC. Also try a working monitor on the problem PC. Then you will know whether it's the monitor or the PC graphics card that's faulty.
Jan 09, 2009 | Dell Dimension 2400 PC Desktop
Dell e193fp
Use ctrl+alt+ up Arrow key on your keyboard (you can also use use ctrl+alt+ left/right Arrow key)
Good Luck
Dec 19, 2007 | Dell E193FP 19" Flat Panel LCD Monitor
Monitors on/off green light flashes
Try first unplugging the monitor and the computer from the wall for 12 to 24 hours. If this does not work, hook up another monitor to the puter to see if the problems with the puter or the monitor.
Sep 22, 2006 | Dell E171FPb 17" TFT LCD Flat Panel...
Computers & Internet Logo
61 people viewed this question
Alun Cox
