Question about Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac
Poulan bvm pro 200 gas blower not getting gas
How do I repair the pouilan pro bvm 200 gas blower, it is not getting gas ( spark plug is dry)
  • 5 more comments
  • lbjallthe wa Oct 03, 2008
    I have the same model blower and essentially the same problem. It worked fine then the next time that I tried to use it she just wouldn't start. I changed the spark plug and It has a good strong fire at the plug. It has plenty of gas but still wont start. I used starting fluid directly into the cylinder and still no start. I removed the fly wheel to check sheer pin and all was good. The blower is still disassembled and I am needing some professional guidance. I suspect the ignition module is not firing in the correct sequence but since there is a strong spark at the plug I am not sure about the module.
  • Anonymous Oct 16, 2008
    My BVM 200 was running great till I went to start it again. Spark and gas but no go.....I think the compression is gone.
  • Anonymous Oct 19, 2008
    doesnt work
  • debbyontour Nov 11, 2008
    blower worked first time and then next time would not fire. Was told head gasket blown and was fixed. Worked again 1 time and now will not fire.
  • hilgendt Nov 18, 2008
    Unit just quit running. Worked fine for about 10 min. Checked plug
    and it is dry. Can not get any fuel by pushing the primer. When you
    push the primer is forces the fuel back to the gas tank.
  • loudhockeyfn Nov 25, 2008
    Fired up my Pouland blower for the first time last weekend, fresh gas... no go. It actually fired for about 2 seconds, and then quit... I was never able to restart it. The spark plug is cool to the touch, so I'm wondering if this suggests something wrong with the ignition sequence?
  • Anonymous Dec 16, 2008
    I replaced the fuel line hose in my BVM 200 since it became brittle. Since I put it back together the carburator isnt getting fuel and the spark plug is dry. The primer bulb when pressed stays down and will not pop up again unless you wait like 5 minutes. Any solutions?
    Problem Solver:
  • 6 Answers
As a service center for Poulan products the usual problems for not starting I see is compression or the cylinder has come loose from the crankcase. Compression needs to be 115 psi minimum. If you remove the plastic muffler cover you can see the cylinder-crankcase joint. Wiggle the spark plug to look for any movement at that joint. If there is any movement the cylinder screws are loose.
Poulan has an excellent 2 year warranty and any service center should be happy to repair it under warranty for any problem.
Posted on Nov 19, 2008
    New Friend:
Apparently the carburettor gets clogged if you don't run it dry before putting it away for a while. You need to take it off and clean it and probably need to renew rubber diaphragms.
Posted on Nov 30, 2013
My poulan pro 25cc does not have the power it use to
Posted on Oct 18, 2008
What type of oil does the poulan pro BVM 200 EL use and is the gas:oil ratio 40:1?
use - husqvarna , sthil brands high quality 2 stroke oil
as directed on bottle 50:1 that is 20 mils of oil for every 1.0 litre of petrol that you use
if you want 2 litres mix put in 40 mils of oil into petrol container
then put in 2 litres of petrol only and give good shake and fill the blower
cheers
Sep 01, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
What is the air gap for Poulan pro BVM 200 blower. I am not getting any spark with a new coil. Thank you
.010 make sure its not on backwards some have an arrow molded on them to show wich way flywheel turns and make sure grounw wire is not pinched against metal that will shot the coil hope this helps
Aug 17, 2010 | Poulan Pro Reconditioned BlowerVacuum 25cc...
What type spark plug for the Poulan Pro PBV 200 LE
RCJ6Y is the plug number, you can get them at any home improvement store for about $3
Sep 05, 2009 | Poulan Garden
My Poulan Pro 200 model #200pbv200le will not start.Replaced the carb, fuel, fuel filter,plug. When I pull the cord sometimes I see a spark, sometimes- most of the time I don't see a spark.Replaced fuel
Check your compression...if it reads anything less than 100psi you need to tear it down and replace the piston ring. Looking for the spark is unreliable, get an in-line spark checker and check for spark. Loss of compression due to a stuck piston ring is very common in the pbv200 series.
Aug 31, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I have a poulan pro bvm200 leaf blower, was running and then it stopped and have not been able to start it. I took all the parts off and all are clean. Throttle is clean, push button for fuel is working....
the bvm 200 model has a 25cc piston and ring the rings are infamous for getting clogged and baked into theyre seat,this creates a compwesion problem and it will not start,gets fuel spark but without compresion it'll just not run or start,if careful you can remove the piston soak it with ring atached in carb cleaner and get it springy again or replace the ring with a new one it has a 1.353 (34.38)mm bore and a ring thikness of .061 hope this helps
Apr 29, 2009 | Poulan Garden
Gas line connections
The thicker of the two lines goes on top nearest to the primer ball
Mar 21, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan/Weed Eater No. Bvm200le 711482 24cc Gas Blower/Vac Logo
2,559 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
