Question about Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Door won't latch, interior light stays on, dryer will not start
The door to my Whirlpool Duet Gas dryer won't fully close. It doesn't "click" when you close the door therefore the button for the interior light is not fully depressed and the light stays on. The dryer thinks the door is unlatched and therefore will not operate at all. Nothing seems to be physically blocking the door as it basically closes almost all the way, it just won't latch. Thanks!
    Problem Solver:
  • 8 Answers
It appears that someone bent the door or the hinge. that is my first guess.
Posted on Oct 25, 2008
I had a similar problem with my dryer. It turned out the door open switch was jammed. I couldn't hear it click when I depressed it with my finger. Oddly enough, I gave the door a good slam and it unjammed the switch. Now it is working fine. I dare not slam it again though because it may jam again. Good Luck.
Posted on Nov 09, 2008
2 Suggested Answers
  • 32 Answers
SOURCE: Door won't fully latch, light stays on, dryer won't function
There is typically a small plastic piece that catches the door and keeps it latched. The door has the male side and the frame of the dryer has the female side.
Either the male part on the door has broken off (or bent) or the the female part on the frame has broken. Replace this part and you'll be back in business. It is typically called a door latch and it comes with both the male and female parts.
Here is a picture
of a typical one.
Posted on Sep 23, 2008
The Door won,t stay closed on our gas Magic Chef Dryer
Latch is broken and needs replace or may just need reset. Probably been slammed one time too many.
Aug 07, 2014 | Magic Chef CYG4000AWW Gas Dryer
Dryer shuts off after one minute
  1. Lid Switch Doesn't Latch
    • A Whirlpool Duet dryer has a latch on the interior frame of the door. It essentially locks the door closed when the dryer is operating to keep you from opening the door and becoming injured by the tumbling drum. The dryer can only run when the latch is secured. If the latch breaks, a dryer might start but shut off prematurely. Open the door and press the latch down with your finger. It should make a ticking sound when you release it. Replace it if it doesn't.
    Unsteady or Damaged Power Cord
    • A dryer's power cord delivers electricity from the electrical outlet to the machine. If the power cord isn't firmly plugged into the outlet, it can interfere with the electricity transfer. While your Whirlpool Duet dryer might start, it probably will shut off soon afterward if the cord is wobbly. Also, if cords wires are visible through the rubber encasing, the cord might be defective. Though the dryer turns on, a faulty power cord might not be able to sustain the dryer's long-term operation.
    Triggered Thermal Fuse Faulty Control Panel
    • The Whirlpool Duet dryer's control panel operates with the support of multiple wires that link to various dryer components. After you choose a drying setting and turn on your dryer, the control panel begins running elements of the dryer. If one of the wires fails, it can disrupt the performance of your dryer. Contact a dryer repair specialist if you suspect that the control panel might have short circuited. If your dryer is still under warranty, rather than replace the corrupt wire, he might recommend replacing the entire panel.
Dec 11, 2013 | Dryers
Whirlpool duet does not turn on when the power button is pushed no lights come and no sound the interior light works and then theres the odd time you push the power button and it works fine
sounds like the door switch/latch is going bad. You can test it here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Dec 26, 2010 | Whirlpool GEW9250 Electric Dryer
When i push and hold the start button the timer light flashes but it doesn't start. the interior light stays on even when the door is closed. door switch maybe???
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 09, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer door will not stay latched and causes dryer
ew whirlpool duet steam dryer door will not stay latched and causes dryer to stop
Dec 20, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Whirlpool Front Loader Dryer Door will NOT stay closed
I have the same issue with the door popping open. If you push hard on the bottom of the door then it snaps in. I think the bottom latch is broken or misalligned.
Oct 17, 2009 | Whirlpool GEW9250 Electric Dryer
Blinking light cycle won't start
sounds as if you have a bad door latch assy, the unit is not recognizing the door closed, so when the button depressed probly only beeps 3 times at you. check the lock/latch for an obvious broken part
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Steam Dryer Beeps 3 Times But Does Not Start
Brand new unit - same problem. After an hour of investigating, I found the issue.
You don't actually have to SLAM the door. If you look closely, there are 3 separate pins that must latch. One is a simple push-button style which latches no problem.
The others are little prongs at the top and bottom of door. The bottom prong latches cleanly, but the top one will not latch because the door is a bit too flexible.
Close the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. The dryer starts normally.
Yay!
Nov 02, 2008 | Dryers
Here is a picture
of a typical one.
Sep 22, 2008 | Dryers
Duet dryer
yes, it may be as simple as a broken clip where the door opens & closes
Jun 02, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer Logo
1,234 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
