Question about Lexmark Optra R+ Laser Printer
Optra R+ Memory Upgrade
I have a Lexmark Optra R+ printer and I just ordered 32MB of memory to upgrade it from the original 2 MB. However, I cannot find any references to how to install this memory into the machine. I cannot find a manual or resource on the web. Help!!!!
  • 73 Answers
Make sure the printer has no power before changing memory. Turn off printer, unplug printer and disconnect from computer. It is also a good idea to leave with power off up to 24 hours drain capacitor power as a added precaution.
Try raising the top of the printer up. ( There is a small handle underneath the front that you squeeze which releases the top latch, while lifting up.)
On the right side on top there is a metal bar with a blue sticker next to the print ID. (Push this lever down to release the latch which opens the right side panel.)
Inside you will see the memory slots. (Two running horizontally on top left of control panel and two more running vertically down from top left side of control panel.) ( This is the older type that interlocks with a clip, just lift up from the control panel and then pull out of slot.) (Align the memory to be installed, slide into slot and push toward control panel to lock in place.)
I can send you a picture if you like.
Posted on Jul 27, 2009
  • Pam Garza
    Pam Garza Jul 27, 2009
Amount of ram Hp designjet 500 plus 24 inch and amount of ram support for Hp designjet 500 plus 24 inch.
According to the service manuals there is no memory upgrade for the 500 and standard memory is 16mb.. The 800 and 510 only have upgrade capability.
Apr 05, 2015 | HP Office Equipment & Supplies
200E freezes up
A 200e that locks up usually need a memory and a firmware upgrade. The original 200's only have 32mb of internal memory. The upgraded mini print board that is used in the 730 has 64mb of memory. This 64mb board was used in the 200 as a upgrade and this stopped the lock up problem. Also over the years Bernina has improved the firmware and this also cures the lock up problem. The latest and probably last firmware version for the 200e is version 5, also called the cutwork version. The easiest thing for you to do would be to take your 200 to a dealer and have them install a 64mb mini print board and also upgrade your machines firmware to the latest version 5. Also if you have loaded embroidery designs in your machine, remove them as they use up the machines memory. When you get too many designs loaded even if you have a 64 MB board in your machine you can still have lockup problems.
May 28, 2014 | Bernina Artista 180
I want to increase the memory ram of my lap top: HP pavilion ze4910us What kind and how much memory can I install ?
You can upgrade, have a look at the specs;
Pavilion ze4910us Memory Specifications Standard Memory 512 MB (removable) Maximum Memory 1.0 GB Memory Expansion 2 sockets Memory Comments PC2100/2700 DDR SDRAM SODIMMs CPU Type 1.4GHz Intel Celeron M 330 Model Comments 400MHz FSB Memory Upgrade for HewlettPackard Pavilion ze4910us Laptop, the HewlettPackard Pavilion ze4910us Laptop takes the PC2100/2700 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your HewlettPackard Pavilion ze4910us Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for HewlettPackard Pavilion ze4910us Laptop.
Hope that helps.
Dec 15, 2010 | Computers & Internet
Information on what type of memory upgrade device
Standard Memory: 512 MB - (MegaByte)
Approximately 1 million bytes','300')" onmouseout="hideddrivetip()" href="http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=25761&mfr=eMachines&model=eMachines+T3104&search_type=&root=us&LinkBack=http%3A%2F%2Fwww.kingston.com&Sys=25761-eMachines-eMachines+T3104&distributor=0&submit1=Search#" ;>MB
(Removable)
Maximum Memory: 2 GB - (GigaByte)
Approximately 1 billion bytes, or exactly 1 byte x 1,0243. (1,073,741,824) bytes.','300')" onmouseout="hideddrivetip()" href="http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=25761&mfr=eMachines&model=eMachines+T3104&search_type=&root=us&LinkBack=http%3A%2F%2Fwww.kingston.com&Sys=25761-eMachines-eMachines+T3104&distributor=0&submit1=Search#" ;>GB
Expansion: 2 Sockets
CPU & ChipSet: AMD Sempron
Bus Architecture: PCI; USB - (Universal Serial Bus)
Standard connection for peripherals such as digital cameras, scanners, printers etc. Allows for quick and easy data transfer. Uses the plug and play facility available with Windows 98 / ME / 2000 XP or Macs.','300')" onmouseout="hideddrivetip()" href="http://www.ec.kingston.com/ecom/configurator_new/modelsinfo.asp?SysID=25761&mfr=eMachines&model=eMachines+T3104&search_type=&root=us&LinkBack=http%3A%2F%2Fwww.kingston.com&Sys=25761-eMachines-eMachines+T3104&distributor=0&submit1=Search#" ;>USB
Mfgr's System P/N's: N/A
Comments MODULES MUST BE ORDERED AND INSTALLED IN PAIRS for Dual Channel.
KVR400X64C3A/512
KVR400X64C3A/1G
KVR400X64C3AK2/1G
KVR400X64C3AK2/2G
Jul 22, 2010 | E-Machines eMachines Desktop PC
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Can the memory be upgraded (increased) from the basic (factory installed) 512mb on the Sony PCV-W300G?
Hi there.
As far as i know you can upgrade the RAM to 2GB, 2x1GB 184pin PC2100 DDR DIMM Desktop RAM modules is what it can take.
Thanks for choosing FixYa!!
May 28, 2009 | Sony VAIO PCV-W300G PC Desktop
Manual for RAM upgrade
Memory Upgrade for Dell Color Laser Printer 3100cn Printers, the Dell Color Laser Printer 3100cn Printers takes the PC133 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Dell Color Laser Printer 3100cn Printers to up to a maximum of 576 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed.
http://www.memorystock.com/memory/DellColorLaserPrinter3100cn.html
You should be able to get crucial or the likes to send you the correct memory - as for where it goes that will be in the manual
May 25, 2009 | Dell 3100cn Laser Printer
I have been printing chapters in a book. One chapter will not print. The message on the Lexmark screen is "flushing buffer". does anyone know what this means or why it will not print?
The 'flushing buffer' is most likely due to a corrupt file or file to large for the printer memory. You can check the file size and reduce it. Also you might want to upgrade your memory for the printer. Also might want to check your printer settings if the page you are having trouble printing is different from the other pages printed, such as text & graphics, etc. There is also a possibly of print program incompatibility or Windows OS Patch required but I doubt this since you have printed other pages without any problem. If you need to re-install Lexmark driver: http://downloads.lexmark.com/perl/downloads/downloads.cgi Or, if you need the Lexmark user's guide & reference guide: http://www.lexmark.com/publications/eng/optras/index.html
May 17, 2009 | Lexmark Optra S 1255 Laser Printer
How to change the RAM
The Designjet 500 did not have a direct memory upgrade slot. You will have to purchase a HPGL2 (formatter) card first. This then has a memory slot on it for further upgrades. The plotter had 32Mb memory on board, the card another 32Mb and then you can upgrade by a further 64Mb (waste of money) or the best is 128Mb. This is then added to your original Ram giving you approx 164Mb which is then normally more than enough. The HPGL2 (formatter) card is sold by any HP supplier on order only. Part number is C7772A. Standing in front of the plotter its located in the left side at the back. Look behind the left cover and you will see a small cover in a sort of L shape near where the roll holder slots in, thats it, slip the small cover open (you will see an arrow on it showing how to open it), look if there are any additional cards in the machine, if not it means you still need to buy the card, otherwise you will simply need the RAM.
Feb 21, 2009 | HP DesignJet 500ps (42 in.) InkJet Printer
Lexmark Optra R+ Laser Printer Logo
735 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
