Question about Dell 3000cn Color Laser Printer
Dell 300 cn printer's back door
I cant seem to close the back door of this printer. Any ideas?
  • hiakbarali Oct 19, 2008
    I had the same problem and needed to lift the back door to close it. I think Dell needs to note this issue and come up with a solution!! These are expensive printers!!
I had the same problem, I tried lifting up but that didn't work. I held the bottom third of the printer and did a short sharp snap action with my thumbs. It worked.
Posted on Jan 05, 2009
There is a little hole in the bottom of the printer that that you can stick a pen through and lift the flapper a enough to close the rear door.
Posted on Nov 03, 2008
Yep, same problem. I pulled it up and to the right, jiggled it a bit, did a dance, and it fit! What a pain...
Posted on Oct 30, 2008
I have the same problem. I lift up and try to close. This has solved my problem - it might solve yours.
Posted on Oct 06, 2008
Reset fuser reading in window display what should I do
Open the fuser door and pull the fuser unit out, top of printer or top rear. Should see 2 oval looking handles I believe they are blue, grab the handles and pull the fuser should pull straight out. Then re-seat it back in to printer. And by the way do this procedure while the unit is sill turned on.
Jul 31, 2012 | Dell 2130cn Laser Printer
Hi there, My Dell 1815dn printer makes a clicking sound when I turn it on, and displays an error message "fuser door open", even when the door is closed. I have removed the fuser and turned...
There is a switch that should "close" when the door closes.
But, that switch either is damaged, or it is not sending the "now closed" signal to the printer.
Check that there is no obstruction blocking that switch, nor any dust plugging it up.
Jun 08, 2011 | Office Equipment & Supplies
Dell 922 printer will not print
Better would be to delete them and update again. Else, try using the opensource driver installtions available.
Regards,
HP
Aug 28, 2009 | Dell 922 All-In-One InkJet Printer
Hello My printer(3100 cn dell) every time I
This means that loose toner powder has gotten in the way of the lazer "eye". If you open up the front door, you will see a blue tab toward the right, pull that toward you, then look on the right side of the printer, you will see that a door has opened. Pull that blue stick out as far as you can and you will see some toner powder on that, clear it off, and make sure the little pad is clean. After you have cleared the powder off, slide it back in and out a few times, this will clean the eye. Run another document through, if the line is still there, just clean another time. Should go away. I have this problem alot.
Aug 13, 2009 | Dell 3100cn Laser Printer
RESTART Printer
The new magenta cartridge you put in is bad. If you put the old one back in then you get the low toner message. Take the new cartridge back and get another new one.  I found the answer on the dell troubleshoot website
Feb 03, 2009 | Dell 5100cn Laser Printer
Fuser paper jam on Dell mono laser mfp 1125
Please double check if all doors --- including the paper tray cover --- are firmly (repeat FIRMLY !) closed --- seemingly all such are designed as precautionary measures for safety operations.
Jan 28, 2009 | Office Equipment & Supplies
Close tray error when printing.
http://forums.xkcd.com/viewtopic.php?f=20&t=14495&start=0&st=0&sk=t&sd=a
Go here, it covers your problem in detail
Dec 01, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
Prnter driver for Del 5100 cn - Need be Mac OS X compatible
download Gassan-Mac-9-MR2RC2.sit from dell site (printer site, drivers, mac os) and unpack it with stuffit expander.
it contains drivers for mac os 9 and mac os x.
then just install it and select driver from the list when adding modifying printer
Sep 03, 2008 | Dell 5100cn Laser Printer
Dell Printer 3000cn - Back Panel won't close
Hi. Try gently pulling the door up and out (away from the printer) and then bring it back to the closed position. It's something in the hinge that's off...
Nov 15, 2007 | Dell 3000cn Laser Printer
Dell 3000cn Color Laser Printer Logo
131 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
