Question about Dryers
Opening tower fan to allow cleaning
How do you disassemble it to be able to clean it?
  • bcasebob99 Jan 17, 2009
    It's too dusty inside after years of use. Just cleaning it from the outside isn't practical. it needs a thorough cleaning.
    Gerryferret asked, and i concur: How do you disassemble it to be able to clean it?
  • kerrinarodri May 03, 2009
    i need to know how to disassemble the fan to allow for inside cleaning.
  • 3 Answers
I was successful in cleaning my Aloha Tower fan yesterday. I took out the screws from under the handle and the one at the lower part of the fan that is covered with a screw cover. I then removed the black cylinder by removing two screws from a brass colored plate at the top of the black cylinder and one screw from the bottom of same. The cylinder can then be taken out completely and everything is easier to clean. I put it back together and it is working great
Posted on Oct 25, 2010
Posted on Dec 22, 2008
I have am Aolha Breeze Fan Model 87001 and i do not have the instruction manual and can not find find any # on the internet to reach the company to obtain one. All I basically want to know is how do I clean it? Any help would be appreciated.
THANK-YOU
Posted on Sep 28, 2008
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
If the Seville Tower fan is a similar unit ...e mail me for a pictorial how to word doc.
cp_ent@msn.com
Posted on Jul 26, 2010
There is only one solution .... never buy one!!! ...... I have a filthy fan that I can't clean .... never buy Lasko products again!
Posted on Jul 22, 2010
  • Chris
    Chris Oct 26, 2010
    I have sent the photo essay out to many folks that have asked me for it ...it's quite simple actually ...just have to be gentle ...I sent a photo essay to the manufacture too....LOL
    Now maybe they can dis assemble it..??!!
How do I take the front off of the fan to get to the blades in order to dust.
Posted on Nov 02, 2008
How do I clean my clean living tower fan?
Usually there would be a few screws in the base that need to be taken out and the outer case pulls out. This will expose the fan and filters inside. Hopefully that will allow you to clean the inside. Would not spray any cleaning agents. Just a light vacuum and wipe with clean moist cloth.
Aug 27, 2014 | Tower Dryers
Honeywell Quietset
Disassemble , clean and lubracate. Replace worn parts.
www.honeywellfansavings.com/fans/customer-support/
Jul 08, 2014 | Honeywell HY-048BP Tower Fan
How do I clean a Bonaire oscillating tower fan btf4002
The easiest way to to use pressurized air. Buy a can or use compressed air.
May 23, 2014 | Bionaire Slopeflow 40" Tower Fan with...
Hy108tgt
Our HY-108 (not a HY-108TGT) does not have a filter when it was purchased new from a Retailer.
IMHO, Honeywell/KAZ designed these Tower Fans to be disposable if they fail to work or need cleaning.
These Fans are hard to disassemble for service or maintenance, OEM replacement Parts are unavailable to the general public, service documentation is hard to find, and the Tower Fans tend to have a short Product lifespan. THEY BREAK EASILY! The OEM Service Manual points to replacing complete parts assemblies because few electronics diagnostics and no schematics are provided.
The HY-108 case can start to be disassembled (I have done so on ours) by *First* removing the screws and separating/removing the plastic Base from the main Case assembly. *Second* remove the Phillips-Head screws on the back of the Case. *Third*, the internal plastic 6 Tabs that keep the 2 halves held together need to be gently separated - careful, they break easily. You need to gently loosen the internal plastic "Tabs" by using a thin flat-head screwdriver to gently and carefully separate the outer shell cover.
Apr 19, 2014 | Honeywell Dryers
Hampton bay tower fan user manual
It works thank you.
There is 4 screws in total. Behind fan.
Mar 28, 2012 | Hampton Bay Dryers
How to clean them
Clean your air tower fan by using small paint brush and wet rag(s). Turn off power and unplug, then open the fan by using screw driver either flat or crossed type. Eliminate dust and dirt using paint brush and rub it with wet rags. When disassembling put screws in box and be observant so that you'll able to assemble it later. Do not wipe motor with wet rags only the propeller, front back cover and so on.
Good luck.
Jul 17, 2011 | Lasko 48" Xtra Air Tower Fan with Air...
Fan WORKS FINE but has lots of dust and mold inside that needs to be removed,and I've taken the screws out, all except the one near the base, located right above the LABEL. This screw, a Philips head,...
there had to be reason the Fan was not to be disassembled .... yes you will need to buy a new unit... MOLD as you is bad thing. If you're allergic to Mold. you be hard pressed to disinfect the whole unit. for sure you will miss some of the Mold. It will come back.. The Mold is due to too much moisture/ Humidity. on top of getting new Fan unit you will need to get Dehumidifier, to remove the moisture in the room...
If dust collects in the new fan. at least you will able to clean out the dust.... if some of the screws look like a star and not a phillips, you can find 1 at hardware store. take a picture of it with your phone. show it the hardware girl or guy. they will be able show what you need to Disassembling the Fan. good luck shopping list
1. Dehumidifier
2. new fan
3. take a picture of not normal screw, when you need to disassembling fan gain.
Mar 12, 2017 | Aloha Housewares Breeze 29" Tower Fan
How do i clean it ? Do I have to take it apart?
To clean it, you will need a small paint brush, screw driver either flat or crossed, then disassemble it.
Loosen the screw and just be observant what you put apart. Then clean it.
Good luck.
Jun 25, 2011 | Lasko 2644 Tower Fan
Cleaning the WIndchaser WCUFI tower fan
Yeah easy on the back near the handle there are two screws unscrew them next gently tug the back cover off and it will sound like it is break but it is just unclicking. And as always unplug the thing.
Apr 22, 2008 | Windchaser WCUFI WindColumnUltra Tower Fan
Dryers Logo
3,838 people viewed this question
Top Dryers Experts
