Question about HP Officejet 5610 All-In-One InkJet Printer
Photo paper too thick causes jam
I have used 9 mil photo paper for a year. No problem. I received some new photo paper and it causes jams. It will not print. I think it is too thick. Is there an adjustment for this paper?
    Novelist:
    Scholar:
  • 111 Answers
You said that the photo paper you used to use was 9 mil, which seems to be well within the product specifications. You don't say the actual size of the photo paper you are using now, just that it is too think. Have a look at the product's specification's page. Scroll down to the Paper Specifications section of the page and see if the paper you are currently using is supported. If not, you'll have to go with thinner paper. Here's the page:
HP's Product Specifications
Posted on Sep 30, 2008
Fix paper feeder that keeps jamming. How to clear jam and fix on-going jamming problem
What thickness of paper are you using? Also is the paper new/fresh or are you re-using paper that has gone through the printer already?
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
I am positive there is no paper jam with my printer (Z2420) but message of paper jam still appears and it won't let me clear it.
Sometimes a very small piece of paper can still be in the printer paper path after clearing a jam especially if the paper tears while removing the jam. The piece of paper may be too small to notice. Try blowing out the paper area with compressed air. Other causes could be the thickness of paper you are trying to print on, ie photo paper, thicker bond paper. Make sure the print settings match the paper thickness. I have a Lexmark laser printer, and I will get feed problems if the settings are not set for the correct paper type.
I hope this helps.
Alex
Feb 10, 2015 | Lexmark Z2420 USB 2.0/ 802.11g Wireless...
Paper thickness error
From page 88 of the User Guide.
For your printer you can use the following types of paper and other media.
??  Size
• Standard paper: From Legal size (8.5 x 14.0 in.) to A5 size (5.83 x 8.27 in.)
• Non-standard paper: From 3.54 x 4.72 in. to 8.5 x 23.0 in.
• Others: Envelopes (US Com. #10 and European DL)
Important ?ž₪ Do not use the following types of paper. Using such paper will not only produce unsatisfactory results, but can also cause the printer to jam or malfunction.
• Folded, curled or wrinkled paper
• Wet paper
• Paper that is too thin (less than 17 lb.)
Paper that is too thick* (more than 28 lb.)
• Picture postcards
• Postcards with an affixed photo or sticker
• Envelopes with a double flap
• Sealed envelopes
• Envelopes with an embossed or treated surface
• Paper with holes (such as loose-leaf paper)
* non-Canon branded paper
??  Weight
17 to 28 lb.
Do not use paper heavier than this (except for supported Canon-brand media), as it
could jam in the printer.
??  Types
The following types of media can be used. For more information about the media and the
printing methods, refer to the specific sections.
Plain paper: Refer to the printed Quick Start Guide.
?ž¡ Envelopes
?ž¡ High Resolution Paper HR-101N
?ž¡ Glossy Photo Paper GP-301/GP-301N
?ž¡ High Gloss Photo Film HG-201
?ž¡ Glossy Photo Cards FM-101
?ž¡ Photo Paper Pro PR-101
?ž¡ Photo Paper Pro PC-101S
?ž¡ Transparencies CF-102
?ž¡ T-Shirt Transfers TR-201
?ž¡ Banner Paper
If you are receiving a paper thickness error (are there lights flashing?) is the thickness greater than 28 lbs? You can refer to the User's Guide beginning on page 140 for infomration on error light patterns.
Have you set the Paper Thickness Lever properly? Looking at the printer from the front; To the left for normal paper; To the right for thicker product (e.g. envelopes, t-shirt transfers, banner paper).
Trust this is helpful. Please vote. :)
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/s_series/s520#ServiceAndSupport
Dec 16, 2010 | Canon S520 InkJet Photo Printer
Is there anyway to enable the 3650 printer to print on Kodak Premium Photo Paper. Paper weight 66 lb. thickness 8.5 mil. Printer jams each time I try to print
Hi Jerry
This is a budjet printer and ity's not really made for anything ohter than standard weight 'copier' typer paper.
66 lb. paper is equivalent to 240G paper here and that doesn't go though machines easily unless the paper feed is from the back. HP printers traditionally roll the paper around a roller and feed it back on itself. This paper (it's almost card) is too thick to go around the roller.
If you want to print a lot of this paper you are going to have to buy a new printer. I would recomment a Canon MP560.
Aug 09, 2010 | HP DeskJet 3650 InkJet Printer
Problem to feed photo paper
pls... change the a3 photo paper to 230 gsm because the sensor can not load because of the thickness of your photo paper. change it to small gsm.
Sep 29, 2009 | Office Equipment & Supplies
Photo paper jam what thickness of photo paper should i use for a hp photosmart 8250 i keep getting jammed up and think the paper is to thick
Be sure and check the printing properties before printing. make sure that you specify the kind and thickness of the paper. This way the printer expects that thickness when printing. Sometimes, glossy paper makes the printer jam easily. Try putting around 25 regular paper on bottom of special paper and see if that helps.
Sep 13, 2009 | HP Office Equipment & Supplies
Not printing glossy A4 paper / paper jam / no paper feed
dont use thick photo paper like 230 gsm up, instead use 180 gsm papers. but if you dont want to waste the purchased thick photo papers, you can open the back and manually insert the paper once the printing process started. i tried this as a trial & error basis until i had perfected it.... hope it works with yours.
Aug 06, 2009 | Brother DCP 130C All-In-One InkJet Printer
HP Photosmart C7280 Paper Jams
It isn't always about the paper. The video shows a few other things to check.
May 04, 2009 | HP Photosmart C7280 Printer
Error 3, paper jam
use an antistatic vaccum or canned compressed air to clean the interior of the printer.this problem may cause by dust and debris inside the printer.inspect for any broken part in the paper path.if u find any u will have to investigate repairing or replacing the printer.
try using different weight paper .some printers work best with the particular weight of paper and if you use paper too thick or too thin jams can usually occur.thanks
Apr 19, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
1,012 people viewed this question
Ben Johnson
